Question about Kenmore 62602 Electric Dryer
Doesn't start My 90 series Kenmore Electric dryer wont start. The light works and when I hold in the door switch manually the light goes off but the dryer still wont start. When I push the start button I hear a faint single click sound coming from the button itself but no other sounds. I started removing screws and looking at wires and all look okay so far. I have a multimeter and I'm looking for any fuses to test/replace. Can anyone help me locate the fuse(es) or does anyone have any other suggestions.
  • 5,911 Answers
Try this link and see if this helps you diagnose your problem. Please don't hesitate to contact me if you require further assistance.
http://www.fixya.com/support/r385301-thorough_dryer_advice
I hope this helps you isolate your problem. Let me know if you need assistance in locating parts too.
Posted on May 28, 2008
Kenmore 90 series dryer, motor wont start, loud
  • Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
  • If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch.
  • Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Hope this will fix your problem for sure.
May 10, 2010 | Kenmore Dryers
My Kenmore 90 series electric dryer not running
http://www.washerwizzards.com ,,,,check the thermofuse in the back,,it is a white fuse coverd in plastic with 2 wires attached ,,,,hook the 2 wires together and test it
Dec 23, 2009 | Kenmore 63942 Dryer
Kenmore 80 series electric dryer wont start
Push the button manually and see if the light goes off . If it does , then the problem is the thermal fuse (a white slim piece of plastic with 2 wires connected to it ) located on the blower housing beneath the drum .
Jul 22, 2009 | Dryers
Kenmore 90 series Model # 66912691
most of the time if a dryer does nothing it is the door switch done bad or the mine fuse behind the back panel on the blower box,let me know more-mike
Mar 10, 2009 | Kenmore 62602 Electric Dryer
Kenmore 90 Series Model 11060912990 Dryer won't start
check motor (you have 2.4 Kohm ) very high read
for motor must be lower.Check capacitor if hawe.
Feb 15, 2009 | Kenmore 62602 Electric Dryer
My 90 series kenmore dryer won't start
check the door switch to see if its good / if not the dryer wont start
Dec 12, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 90 Series Electric Dryer will not run
chech to see if your belt is broken. It may have a belt switch
Oct 28, 2008 | Kenmore 62602 Electric Dryer
Kenmore 80 series wont start
Common failure of these dryers is the door switch. The switch is located at the top right where the door comes in contact with the tab,
A simple test is to verify that the light is on and goes out when the switch tab is depressed.
If not replace the switch.
Hope this helps?
May 24, 2017 | Kenmore 64892 Electric Dryer
Kenmore 90 Series Electric Dryer won't start
Hi.Thanks for the question I would look to see if the belt is ok.Some dryers have a belt break switch, which is located by the motor.I would check the door switch.on the door try that thanks
Sep 29, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 62602 Electric Dryer Logo
168 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
