Question about Sony Televison & Video
How to repair a TruSurround By SRS On A Sony 57-Inch HDTV
OPFloridaGuy
  • 3 Answers
SOURCE: Samsung SRS TV
Have you attempted to go into the menu and adjusting the convergence.. Check in the menu and line up the bars. If this does not work it might need to be adjusted manually.
Thanks Steve
Posted on Mar 27, 2008
Ecollier2012
  • 3459 Answers
SOURCE: My Hitachi 57 inch HDTV 57F500 model has a convergence problem
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Apr 03, 2009
ladywinn
  • 5138 Answers
SOURCE: What does a bad optical block cost to repair on a
Call UED for price of rebuilt one 1-800-648-6657 Light Engine
Posted on Sep 27, 2009
  • 597 Answers
SOURCE: 57H84 57 in. Rear Projection HDTV-Ready Television: tv screen turns red then shuts off the tv is a 57 ...
call tech support...tell them # of flashes
Posted on May 20, 2010
  • 57 Answers
SOURCE: This gray box won't go away on my uncle's TV. It
hello my name is rico, you have bad main board, and it needs to replace it, for the square box to go away. if you need more help, call me anytime. 602-810-7149.
Posted on Jan 07, 2011
How difficult is it to replace a blown speaker on a E500 Vizio TV?
Easy if you can get inside the case.
Audio Speakers 2 Subwoofer No Effects SRS StudioSound, SRS TruSurround HD, SRS TruVolume Total output power 20 watts
Read more: http://www.digitaltrends.com/tv-reviews/vizio-e500i-a1-review/#ixzz3vkDj3Zwp
Follow us: @digitaltrends on Twitter ' digitaltrendsftw on Facebook
Or you could buy a surround sound speaker bar which disables the internal speakers.
Dec 29, 2015 | Vizio E500i-A1 50" LED TV 1920x1080, 120...
Screw
Many screws work but in the field I use lag screws. usually a 7/16th by about 3 inch (depending on sheet rock thickness). You will need to hit the studs with these.
Jun 14, 2013 | Philips 50PFL3707/F7 50-Inch 60 Hz LCD TV...
Soundbar will not turn on
1. Check the power cord is plugged in properly by removing it and replacing it. 2. Try a different outlet on the surge protector.3. Most surge protectors have a reset button, try resetting it.
Is the sound bar the only device plugged into the surge protector?
Oct 25, 2012 | Vizio VSB200 40" Soundbar - SRS...
This gray box won't go away on my uncle's TV. It says "Video 5 Cable Box" and appears at the upper left-hand corner and won't go away. It has been there for a few days. It's a first. The TV has...
Jan 07, 2011 | Sony Grand WEGA KDF-60WF655 60" Rear...
Intermittently my Vizio model e370va volume will rise on its own and get distorted then turn off and in a few seconds, turn on the TV. Visio tried replacing the power board. Same problem. Replaced the TV...
I was having the same issue. I found this on Fixya and it seems to have worked.
Okay I just called and found this out. I have the 32 inch vizio hd flat screen. My problem with weak and fluctuating volume, was that I have a cable box. Go into menu, then audio and under the advanced audio section you will see srs trusurround HD and srs trusurround. Basically this function automatically adjusts volume levels for satelites and whatnot. But because cable boxes automatically have this feature you could just turn off the srs trusurround. Hopefully that should help you.
Dec 06, 2010 | Vizio VU42L 42 in. LCD TV
I have a Sony TV Projection TruSurround by SRS, its showing blurriness on the Screen. It has red outlining on the words, i think it may need to be re aligned or possibly some of the hardware may need to be...
See attached photos, it sounds like a convergence problem.
The model indicated uses two of the STK-392-560 chips for this. Usually replacing both will fix the problem.
Total parts cost on EBAY for this repair (I use the seller) will be under 25 dollars and repair takes less than a hour.
I have fixed over 1,000 sets with this problem--I can assist you if you need help.
If this told you something you did not know or you want more information, rate this solution as very helpful as I do this here for you for free.
SD TECH
92236ed.jpgTypical convergence chip---your set's should have STK-392-560 PRINTED ON THE FRONT OF THEM.
Aug 25, 2010 | Sony KP-51WS510 51" Rear Projection...
My Vizio Tv volume does not work properly. When its at volume 100 it sounds like volume 50. What could be the problem? My question is how can I fix it? Let me know...
May 10, 2010 | Vizio VF550M 55 in. LCD HDTV
Can't Turn On SRS Tru Surround XT On My LG 42LH7000.
Found this on a forum somewhere. Clear Voice II is probably turned on. When this feature is on, SRS TruSurround is not available. You'll have to turn off Clear Voice II to enable SRS TruSurround. Someone mentioned that once you turn on TruSurround you can then go back on turn on Clear Voice again.
Apr 08, 2009 | LG 42LC2D 42 in. LCD HDTV
Sony 52in Projection TV
Thanks for including your model number! Just change the lamp and it should be good to go.
Jun 22, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Televison & Video Logo
42 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
