Question about Nikon FG 35mm SLR Camera
Do you need film in camera for the light meter on the inside of the camera to light up and work?
  • 98 Answers
No not at all. It is indipendent of the film inside.
Posted on Oct 05, 2010
Light meter
The light meter in an SX-70 is not adjustable. If the film is overexposed either the film is bad or something is blocking the light meter eye. Look for dust or debris on the eye surface and clean.
Feb 09, 2014 | Polaroid SX-70 Film Camera
Nikon fg light meter not working
Light meter only works with the back door shut and the film counter is at frame 1 or more !!, Also if the camera is set at M90 or bulb (B) mode, Meter will not work there ether,
Nov 13, 2013 | Nikon FG 35mm SLR Camera
Nikon F100 does not advance film to start of roll,
Jim, it really sounds like one of threethings. Either will require a repair shop.
1. the film sensor is not recognizing film in the film chamber, or film across the back, therefore not telling the advance motor to advance film...
2. The film advance motor itself needs replaced.
3. The rear door latch switch needs replaced.
Since everything else seems to do OK, I doubt the main computer board is bad.
Feb 03, 2010 | Nikon F100 35mm SLR Camera
When film loaded it is not rolling on properly
film not advancing? film not rewinding? film transport motor dead/ needs replaced.
Rewinding but counter not resetting and light meter dead? Prolly bad connector or ic inside camera = repair shop.
Oct 16, 2009 | Photography
35mm film broke rewinding in camera
Take the camera with the film still inside to a reputable business that develops and prints pictures. The usually have a means of retreiving the film with out futher damage. If you want to do this yourself, you will need a place that is totally dark. You will also need something that is totally light tight. A solid plastic film canister may be sufficient. Take your camera into the "dark room" , open the back and gently try and release the film avoiding as much as possible only touching the edges of the film. You can turn the lights on once you have the film inside the light tight canister.
Aug 26, 2009 | Nikon FE 35mm SLR Camera
Light meter not working
Make sure the battery lid is securely screwed on, The meter wont work before the '1' frame. i just found out last week about this. make several clicks till the '1' mark appears, now check the meter if its working. [A] - aperture prio
Jun 09, 2009 | Nikon F3 35mm Film Camera
Canon ae1 film advance
On the very bottom inside the plate there are many cog gears with levers and retractor springs. One may had come off causing your problem
Sep 13, 2008 | Canon EOS-AE-1 35mm SLR Camera
Film = no light meter
jackson rook,
the speed of the film may be to high if your camera has dx coding contacts in the film chamber. otherwise---- film in camera or not it has no effect on meter operation. move the advance lever to the right slightly and push down on the shutter release button slightly to turn meter on.
Sep 10, 2008 | Vivitar V4000 50MM 35mm SLR Camera
Light meter does not turn on
The frame counter must be at '1' for the meter to work on this camera
Dec 13, 2007 | Nikonos V 35mm Point and Shoot Camera
Light meter failure and shutter button sticking
Set your camera to B and release the shutter ( camera will work in this mode without batteries ) if you can wind ok and release shutter fine then all you need is new batteries. If however your camera is not working when set to B then it is either the shutter or the transport mechanism that need looking at. From experience ( have repaired 100s of Me-supers ) it is likely that your shutter needs attention : rubber components ( and foam rubber ) inside the shutter ( and the mirror box locking mechanism especially ) have perished and need replacing.
Sep 21, 2007 | Pentax ME Super 35mm SLR Camera
Nikon FG 35mm SLR Camera Logo
135 people viewed this question
Top Nikon Photography Experts
Bart Pulverman
michael galang
Are you a Nikon Photography Expert? Answer questions, earn points and help others
