Question about Frigidaire Dishwashers
Dishwasher does not fill completely with water. The vavle is clean and looks to work properly.
  • 901 Answers
Check the inlet water pressure. Clean the strainer attached to the hose near the machine body. The knob can be turned by hand and remove the filter for cleaning. Filter is a small piece pushed in and kept in the plastic pipe submerged, where you removed the knob.
Lastly check the level switch or pressure switch attached to the m/c tub.
Posted on Oct 05, 2010
GE dishwasher GSD6260JSS doesn't clearn as well as when new
water temp should be a minimum 140 degrees at inlet this can be checked with meat thermometer at kitchen faucet,also need proper fill of water entering dishwasher proper water pressure and fill also important for proper cleaning of dishes,if water is slow entering you may have sediment inside fillvalve screen if on well water in this case you will have to disconnect water supply line and take valve apart the screen is in side valve reassemble and test operation...if this does not work you may have to replace inlet vavle
Oct 21, 2012 | Microwave Ovens
I have a KitchenAid model KUDI01ILBT2. It was working fine until recently...The lights work fine, but when I push the start button it's delayed before it actually kicks on, and then it will...
sounds like you have a bad or clogged fill vavle,,you have water running to unit but not in unit,,,its still trying to dry dishes as if they wash...most dishwasher are hard wired to breaker and or not grounded,,,but only if you can shut of power pull dishwasher out remove water connection,,see if any **** is blocking vavle use flash lite if present...if so replace it..good luck you can not clean a dishwaser vavle..
Sep 03, 2011 | KitchenAid 24 in. KUDI01IL - Multiple...
Dishwasher does not clean dishes completely model # kudso3ftss3
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound.
If it seems as a low water pressure then check the fill valve. Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete. Try cleaning the spray arm with a soft brush. The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes. Hope this helps...
Daniel
Mar 24, 2011 | KitchenAid Dishwashers
The top drawer of my FP dishwasher is not cleaning everything properly. The glasses or dishes in the front left side are always dirty and are covered with crumby dried residue when the cycle is complete....
Hi
Feb 20, 2011 | Fisher and Paykel 23 in. DD603H SS...
Dishwasher does not clean properly
Hi
Daniel
Nov 27, 2010 | Whirlpool Dishwashers
Spots are left on the dishes after washing. Dishes don't look clean
Hi
Daniel
Nov 26, 2010 | Kenmore Washing Machines
Dishwasher won't drain properly. Dishes aren't properly cleaned
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Hope this helps...
Daniel
Oct 25, 2010 | Jenn-Air 24 in. JDB2150AWP Built-in...
Dishes don't seem to be coming clean in dishwasher. Plasticware seems cloudy and etched. Other plactic pieces look cloudy. Whites plates appear clean.
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it’s kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Please post back for any further assistance.
Daniel
Aug 27, 2010 | KitchenAid Dishwashers
Detergent is left in the dispenser cup. Dishes are not clean after going through a complete cycle.
Hi
Daniel
Aug 02, 2010 | GE 24 in. GSD6660GSS Built-in Dishwasher
Water not flowing into the dishwasher.
may have bad fill vavle or the inlet screen on the fill vavle is clogged. the fill valve is the part on the dishwasher where the water line connects.
Aug 30, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwashers Logo
90 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
