Question about Home
Tryng to find a replacement light bulb for panasonic model fv-lp003 bathroom ceiling fan w/lighting
3 Suggested Answers
pyroshain
  • 42 Answers
SOURCE: Our new bathroom fan is not clearing the room the
I use to be a chimney sweep. One of my jobs was to clean vents for dryers and bath vents. What could be your problem is that you have a bird nest in the vent system. It sounds to me that you have a vent on the roof for the fan. A bird could have damaged the cap to gain entrance and built a nest. With the cap gone, rain can come in. With the nest, it will not vent out the room. You could call your local chimney sweep company and they will clean it for you. Or if you are capable, Lowe's or Home Depot sell dryer vent cleaning rods. They are sturdy but flexible rods with a 4" brush on the end. Two other handy tools will be a high power shop vac to **** out anything from inside the vent, and a high power blower that has vacuum capability to use out side the house. Cafe full though, if it pulls out a nest, it will shoot it out with great force.
Posted on Jan 23, 2010
aquaman987
  • 927 Answers
SOURCE: breaker box has power but
See if there are any ground fault circuit interrupter outlets in either room. Look especially in the bath. There are black and red pushbuttons on them. Press the reset and see if that helps.
Gary
Posted on Aug 29, 2011
I have a 3 year old Panasonic Whisperlite FV-08VQL4 ceiling fan for the bathroom, with two CFL bulbs (18W each). One of the two bulb locations is bad -- it won't turn on, regardless of replacing the bulb...
Sounds like a loose wire inside the unit. But, I would try this. With the power off, both switch and circuit breaker, try and bend the center contact for the light bulb out; pull it out away from the back of the socket. This may be the bad contact. The center contact on the bulb touches this in order to get power up into the bulb. Using a small screw driver, try and scrape the surface of this contact to clean it a bit. DO ALL OF THIS WITH THE POWER OFF!!!
Hope this helps.
Sep 05, 2010 | Panasonic FV-08VQL4 Fan
Our new bathroom fan is not clearing the room the ceiling is wet and the paint peeling the fan is model #FV-LP003
Jan 23, 2010 | Panasonic WhisperFit-Lite Low Profile...
Replacement bulb for Panasonic FV-11VQL4 fan doesn't fit
It' a unique bulb that is available online. The big box stores don't carry it.
Oct 23, 2009 | Panasonic FV-11VQ2 Fan
Replacement bulb for Panasonic FV-11VQL4 does not fit
YOu can try Panasonic for your light bulb. https://www.amazon.com/Panasonic-FDS18E35-18-Watt-Compact-Fluorescent/dp/B0039PMG2I
Mar 12, 2017 | Panasonic Kitchen Appliances - Others
How do u remove the cover to change the bulbs on panasonic whisper-fit low-pro?
The cover is gently pulled down.
It only comes down so far, as it's held up by springs.
There are four springs. Two on each side. To gain more clearance on one side to replace the bulb/s, you disconnect the end of two springs on one side.
After the bulb/s are changed out, reconnect the springs, ease the cover back into position.
Oct 01, 2009 | Panasonic WhisperFit-Lite Low Profile...
Retrofitting the Panasonic FV-11VF2 bathroom fan
SHOULD BE NO PROBLEM I HAVE REPLACED A FEW MY SELF. THE PANASONIC IS QUITER BUT THE BROAN IS CHEAPER.
Jun 09, 2008 | Panasonic WhisperFit8482; 110 CFM Low...
Installation of a Panasonic Fan FV-05VFL2...
If you are not very handy I don't think I'd tackle this project. There's going to be drywall cutting, backing to install, attic crawling, wiring, ducting to attach, proper insulating. As an electrician I've done this sort of thing in between 1 and 2 hours, depending on how smooth things go. If you find somebody you trust that's done it before who is willing do to it on the side for cash you're looking at $25-$60 for labor. Is it worth it to you?
Feb 25, 2008 | Panasonic Fan FV-05VFL2 WhisperFit-Lite...
Home Logo
530 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
