Question about Sharp AL 1631 Copier
I have a sharp al-1631 copier. it was working fine and then i had a bad misfeed. the paper was crinkled like an accordion, but i managed to get it out of the fusing and area and below the fusing area. since that happened, i cannot make any copies
  • 1,110 Answers
You can not make any copies? Is this because it continues to jam every copy in the same location? At the fuser? If so then this means you have a quite common issue with this series of machine. You have a broken fuser drive gear. Part number NGERH0540FCZZ. I have included a picture of the part. All you will need is someone to remove the fusing unit (the part that gets hot) and replace the gear. You can get the part from PrecisionRoller.com
Good Luck and Thank You for using Fixya. Our solutions are being rated this month based on positive testimonials. If my solution is helpful please leave a short testimonial for me.
Thanks!
Posted on Oct 06, 2010
When copying from the SPF the paper misfeeds. It starts through but the goes crooked.
You need to adjust the SPF paper size knob to fit your size of paper freely. Make sure that area is clean or you can wipe with a clean damp cloth the picking roller which is located there.
Dec 23, 2009 | Sharp AL 1631 Copier
There is a red arrow light flashing at the upper feeder area. What does that mean?
There is a paper misfeed so check for a jammed paper inside the copier.
Nov 18, 2009 | Sharp AL 1631 Copier
Sharp al 1631 error code l-1
The problem it in exposere lamp section.The forward scan is not compelet.Cause is the mirror motor control board or mechanical parts.
Oct 03, 2009 | Sharp AL 1631 Copier
Sharp al-1631 misfeed light will not go out
This usually happens when a sensor that detected a paper jam has not reset itself after removing the paper. Make sure that when the jam was removed - all the paper came out and there is/was not a small piece missing that could have been left behind in the copier and is hiding somewhere. If you are sure the paper has all been removed then what could have happened is when the jam was being removed it could have caught on one of the paper sensors. This could pull the little flag that activates the sensor out of place - giving a false paper jam message. there are only a handfull of sensors in the paper path. remove the paper tray and make sure there is no paper stuck behind the tray or in the cavity where the tray goes. look and follow very closely the path the paper takes - look for any sensors/flags the paper would avtivate and make sure the flag moves freely and is not lopsided.
Make sure you also try unplugging and replugging the copier from the wall.
Hope this helps
May 19, 2009 | Sharp AL 1631 Copier
Misfeed
there is most likely a small piece of paper on a sensor/
remove paper tray and look inside, is there paper behind the tray? look at the tires are they bald and sniny? replace. Look at the tires and see if there is any scrap of paper there.
open right door and look down towards the paper tray, do you see any pieces of paper? there is a small black lever there, it's the sensor is it stuck?
look into the fuser (where it gets hot) ,you may have to remove it the paper sometimes gets crumbled like an accordion there, htere is also a small black lever there see any paper is it stuck?
Sep 15, 2008 | Sharp AL 1631 Copier
SHARP AL-841 Paper Misfeed Error? The little paper mis-feed symbol is flashing - though there does not seem to be a jam ANYWHERE. The copier will not re-set.  Can someone help? Thanks, Ron...
open right door and look on top there should be a littl lever there check carefully to see if there is a paper crumbled inside.
remove tray and look where paper feeds out.
Nov 19, 2007 | Sharp AL 1631 Copier
Sharp al-1631
there is some paper path sensor in your machine first you should check the area where misfeed light is coming then check the sensor of that area
Sep 28, 2007 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
49 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
