Question about Ricoh Aficio SP C811DN-DL Printer
Ricoh afico 811 error sc689 and sc547 - Ricoh Aficio SP C811DN-DL Printer
  • 903 Answers
Sc547 is a power supply error that can mean you have a faulty power supply. The service manual does not list an sc689, and it's not in the help desk support database either... are you sure that's the code that comes on the screen?
Posted on Oct 10, 2010
Why error SC547 on ricoh aficio 4501 repeating its self after resetting?
Fixing problem. You have a bad thermistor. This detects heat in the fixing assembly. There are two . Replace both.
Jun 08, 2017 | Ricoh Office Equipment & Supplies
Help with error code SC547-01
sc 547 mean fixing unit error ,you can reset by simply getting into simulation mode and then switch off an the machine ,getting into the simulation mode is simply by pressing 107 and press and hold c ,
Jun 19, 2013 | Ricoh Aficio 450 Copier
When my ricoh afico 1018 printor is on error corde desplay sc320?
SC320 is a polygon mirror motor error. It could be caused by a poor connection or a faulty circuit board, but the most likely culprit is the polygon mirror motor itself. Replacing this motor (part #G0291961) is the most likely solution.
Hope that helps!
Sep 13, 2010 | Ricoh Aficio 1018 Printer
Eror sc547
The error sc 547 refers to a "Zero cross signal malfunction".
This means that the applied power supply AC frequency was detected at over 66Hz or below 45Hz, and the zero cross signals are not detected within a certain period within 500 ms after the main power switch has been turned on.
Possible causes are:
- Power supply board defective
- IOCSS defective
- BICU defective
Try to reset the SC code by entering SP5810 and select 1.
Then hold down the photo mode key and the # key at the same time for at least 3 second.
Then turn the machine off and on again.
If the same issue still appears, try to replace the Power Supply Unit.
Jul 04, 2010 | Ricoh Aficio MP 2000 Black and White...
Error code facsimile error red wrench sc547 ricoh aficio 180
there may be a problem with your electric supply(wall outlet) , wrong voltage or power supply bad
Jan 07, 2010 | Ricoh Office Equipment & Supplies
Need to change fax number programmed in Ricoh, afico 3025
Press the User tools/counter button;
Touch the Facsimile features icon on the touch panel;
select Gen. settings/Adjust tab;
touch Program fax information;
touch Own fax number;
touch For G3-1, then enter your fax number from the blue numeric
keypad then touch OK.
Touch Exit, then press User tools/counter button to go to Standby mode.
Jan 13, 2009 | Ricoh Aficio 180 Laser Printer
Ricoh afficio color 6010
· Hot roller fusing
lamp brown
· Hot roller
thermofuse opened
· Defective main
control board
· Defective I/O
control board
· Defective AC drive
board
more than likely the thermofuse.
Jun 17, 2008 | Ricoh 6513 Copier
Ricoh copier
Must have unplugged the thermister on the coupling connection bank. Reset fuser: Clear modes/ 107/ press and hold clear/stop. Pick copy sp. select mode. exit out of all screens and cycle power.
Feb 21, 2008 | Ricoh Aficio 450 Copier
Ricoh Aficio SP C811DN-DL Printer Logo
842 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
