Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
Replace Lamp I bought a replacement lamp took the back off the tv and can't figure out where it goes. Help
  • 2,322 Answers
Click here to download the instructions on how to replace the lamp.
Let me know if you need further assistance.
Posted on May 28, 2008
When watching tv on any mode...after a few seconds screen goes dark and sound goes out...then a few seconds later it all comes back...happends repeatly...any thoughts?
Time to replace Lamp in TV.
Existing lamp getting weak and causing that problem, replace lamp and TV will be fixed.
Buy Sony original lamp for TV safety and lamp replacement procedure is written in user manual.
Thanks.
Jan 17, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
The tv picture goes out
Sounds like the ballast has gone out. Samsung recommends replacing the smps board(power supply board) when you replace the ballast because it is the smps that takes out the ballast. replacing just the ballast ,machine may work ok for a short time but will destroy the new ballast fairly quickly.
Dec 30, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Replaced lamp. Green standby flashes 50 times, then shuts down
hello when you replace the lamps make sure you fitted the lamp securely and make sure the lamps cover fitted securely aswell
shaun
Dec 18, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
I just heard a loud pop and my picture went to out
the service manual is available in the web site andrewselectronics for sell.
there is a chance to inspect the lamp and see if is damage (normal failure for this popping noise) consult you user's manual ...How to replace the lamp. as i said inspect it and replace it as needed, use original lamp. Toshiba
Feb 23, 2009 | Toshiba 62HM95 62" HDTV
Won't turn on
better to call the manufacturer so they can test it and check for problems. If still within warranty they will replace it, I guess.
Jul 26, 2008 | Panasonic PT-40LC12 40" Rear Projection...
Hitachi #55VS69A
I had this same problem over the summer, I had my TV for two years before it went out. You need a new lamp. The lamp is not hard to replace on your own. However, you MUST make sure that you do not touch the lamp (the bulb part) in anyway. If you do your new lamp will not last as long. You can order the lamps online. They range anywhere from 150-300 dollars online. However, I found a TV repair company in my city that only charged me 100.00 for the lamp and they told me If I took out the box that holds the lamp they would replace the lamp for me. They also gave me a 1 yr warrantee on the lamp. All I had to do was un-screw the box from the back of the TV take the box to the TV repair company and I placed the box back into my TV. My TV works. While going through this process, I learned that these lamps go out all the time, the more you watch the TV the more often you'll replace the lamp. I was told from the repair company it could be as often as every year. The Lamp does have MURCURY in it so if you replace the lamp on your own be careful and have it recycled. If you live in SLC UT the repair company I went though was Village TV Sales and Service.
Jul 15, 2008 | Hitachi 55VS69 55" Projection HDTV
Tv not staying on
If your pic and audio goes in and out evry 10 to 15 second or more then you need to replace the lamp.ITs not complicated to change the lamp.
May 17, 2008 | Sony KDF-E55A20 55 in. LCD Television
WD-52525
I get the same red lamp led indicator, bought the lamp and I am unable to locate the lamp inside the tv, took the lower back panel out and don't see anything that i can make out the lamp housing. is hard to replace the capacitor and where is the power board located. thanks a mill.
Nov 22, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Lamp failure in WD-52525
i actually own this tv myself... that striking you here will only occur when the lamp does not fire. as far as lamp life i have found that mitsubishi has the longest lasting bulbs from my experience. i would check to make sure the connector on the lamp is seated properly into the other connector in the tv. if you know your lamp is 100% i would look at replacing the lamp ballast. ive had this tv for a few yrs now and love it.
Oct 17, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
100 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
