Question about Kenmore 23313 Whispertone Bagged Canister Vacuum
Was using kenmore whispertone stopped suddenly disconnected brush unit will not switch on ????
  • 171 Answers
If you took the hose out of the wand assembly then it may not turn on as the hose handle has a power button on it and must be connected to turn on the unit.Also check the powerhead for a reset button (small red / or black button on the back of the head){back of head not the bottom}
Posted on Oct 07, 2010
When vacuuming the belt stops turning
Your belt is probably stretched, replace it. Also check to be sure nothing is lodged in the brushes
Sep 03, 2012 | Panasonic Kenmore Canister Vacuum Hose 116...
The brush roller is not rotating on my Kenmore Whispertone. It will pick up on floor surfaces. Help!
Be sure that there are no fibers wound around the roller or lodged in the wheel well of the brush roller. That is usually the cause of a brush roller not rotating. You might need to use scissors to clip the fibers and then pull them from the roller. The fibers might range from human and pet hair to carpet fibers, threads, string, yarn, embroidery floss. They wind around the roller and eventually "tighten up" so that the rotator will not move. I have found that, depending on my current craft project, I may have quilting thread, knitting yarn, embroidery floss, or other such goodies wrapped around the roller. When our daughters were at home we would have long, beautiful blonde hair tangled in the roller. I hope this helps.
Nov 10, 2010 | Kenmore 23313 Whispertone Bagged Canister...
Sears Kenmore Whispertone Vacuum Problem:
If you push inwards on each side of the light cover on top you can remove it. With the light cover removed remove the (2) access screws. Now you will be able lift of the entire top cover from the base. You will then see the belt and roller brush, remove the old belt and replace with a new one. You can get the replacement belt you need here:
Kenmore Whispertone Replacement Belt
Oct 28, 2009 | Kenmore 23313 Whispertone Bagged Canister...
While using the vacuum, the brushes stopped turning.
check the drum. Hair will rap around the axxel and stop the brush from turning. Cut this hair with a razor and place a small drop of oil on the end of the axel.
May 08, 2009 | Kenmore 23313 Whispertone Bagged Canister...
Belt keeps breaking.
your brush roller isn't turning unplug the vacuum and see if you can turn the brush roller and also notice if it turns freely or is it stiff,take the roller out and remove strings,carpet strands and hair.if you can pull the ends off clean the ends good and maybe add just a little drop of machine oil on the bearing on the inside the roller where the bearings are.clean the motor shaft.there is probably old burnt rubber on the motor shaft.you can use a pice of emery cloth ,clean it till you see the polished finish .but i would say your problem is in the brush roller and the motor shaft.i hope i was some help to you.can you please leave some feedback
May 03, 2009 | Kenmore Whispertone 29512 Vacuum
Power head for Kenmore Canister Vac
Another potential problem for the increase in difficulty in turning the beater bar (drum) could stem from extremely dirty bearings, located at each end of the beater bar. I've seen hair knotted up to the point it chokes the bar and significantly reduces its ability tpo turn.
Mar 11, 2009 | Kenmore Whispertone 29512 Vacuum
Kenmore Whispertone 100 connection issues
find a used one at a vac repair shop, its just worn out
Aug 01, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Motor just stopped working
Kenmore Whispertone Model 26512690 PowerMate Brush motor does not run. The machine has no suction coming from the Power Mate Brush. However, I do have power in the main machine.
Jul 17, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore Whispertone
The cover over the light, push in on the sides to release the tabs, then remove 2 screws. Using a screw driver, put it in the slot, one on each side, from the bottom, pry up to release the tabs, cover will come off and you can get to the belt and brush roll.
Sep 30, 2007 | Kenmore 23313 Whispertone Bagged Canister...
Kenmore 23313 Whispertone Bagged Canister Vacuum Logo
277 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
