Question about Fisher and Paykel GWL11 Top Load Washer
My washing machine stops and beeps many times during the fill cycle whether on warm or cold wash. If on warm the hot light flashes. I starts again when the start button is pressed but this may have to be done about 15 times to get it filled!!!
  • 343 Answers
Your problem could be caused by a number of different problems.
F&P machines have a self diagnosing computer system.
An experienced tech, with the binery fault codes should be able to tell you what the problem is (most likely to be) quite quickly.
Parts which are supplied and installed by an experienced tech will be guaranteed. (Unlike self installed parts)
A tech will be able to test the whole machine and save you having a secondary problem, which is not uncommon in F&P machines.
Probably not what you wanted to hear, but a much less stressful solution in the long run.
Get Quotes.
Good luck.......Nomess
Posted on Oct 05, 2010
  • Fisher and P... Master
  • 713 Answers
Hi just read your posting.Now,try this for starters,Turn off the taps to the machine and remove both inlet hoses,noting which hose goes on which side, and then put both ends of the hoses into a bucket.Now turn on the taps to see if you are getting good water pressure from the hoses.Also check the little filters on the water valves where you removed the ends of the hoses to see if these are blocked.Please reply on the water pressure coming from the hoses and if the filter s where blocked.Once I receive this information I will be in a better position to guide you in rectifying this problem.Looking forward to your reply.
Cold water intake just tricking
calcium build up clean inlet lines and screens
Jan 20, 2018 | Fisher and Paykel Washing Machines
I have a Fisher and Paykal Smart Drive 053 washine machine. It has just started doing the following: Start load - Cold, warm or Hot and any size Fills intermittent. will fill for a couple of seconds...
Hi just read your posting.When the machine stops and starts does it beep and show an error code.This error code will be a series of lights that light up and the machine will beep.On the wash progress line of lights which lights are lit when the machine beeps,Is it the 1st and 6th or the 4th and 8th etc.Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Jun 05, 2011 | Fisher and Paykel (IWL12)
Hi I have a Fisher & Paykel MW612 top load washing machine. It will start to fill normally on warm wash then the hot stops coming in and the cold fills intermittantly then the whole ting stops and...
Gary - LEDS 00110010 as you have not mentioned the last LED which will be red if on is 00110011
Ok - your code is 50 indictes a faulty hot water valve - question - have connected the hoses correctly - as per your descriptions - it should always be cold 1st then hot water- cold - then hot etc until it fills.
Pays to check this as the fault code is totally opposite to what your saying..
May 01, 2011 | Fisher and Paykel GWL11 Top Load Washer
Machine squeals when filling
Hi just read your posting.Now what temp of water are you selecting for the wash cycle,is it warm, cold, or hot.Try this,Select hot fill then select cold fill and please reply on whether the squeal stops on either hot or cold fill.Looking forward to your reply.
Oct 15, 2010 | Fisher and Paykel GWL11 Top Load Washer
When going to wash with my GW11 it stops during the was cycle and the cold and hot water light blink and the machine beeps
Hi just read your posting.Now, when the hot and cold lights flash at the same time it means that you are not getting enough or no hot or cold water.Remove the cold and hot inlet hoses from the machine end and put the ends into a bucket.Now turn the taps on to see if you have water coming out the hot and cold hose and if the water pressure is adequate.Try a cold fill on the wash cycle and see how it goes.please reply and let me know if there is water coming out of the hoses at a good pressure and also what water temp do you select on the wash cycle.Looking forward to your reply.
Oct 04, 2010 | Fisher and Paykel GWL11 Top Load Washer
Hi, my washing machine isn't working in cold/cold mode but will work in hot/cold and warm/cold. Meaning that water will not come out at all. I even started it in warm/cold and tried to switch it over to...
My bet is that your cold water screen is plugged...
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Aug 31, 2010 | Frigidaire Washing Machines
Not getting enough water
Hi just read your posting.Now what water temp are you using for you wash cycle?Is it cold , warm or hot?Problem could be your cold water valve not opening enough or your motor controller.If you selected a COLD wash how fast does your cold water come in to the machine?Please reply with additional information on the questions and I can help you rectify this fault.Looking forward to your reply.
Jul 27, 2010 | Fisher and Paykel IWL12 Top Load Washer
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
Feb 16, 2009 | Maytag Neptune MAH5500B Front Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
85 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
