Question about Dryers
I have a 4 prong cord and im not sure where they go on my new dryer
  • 5,911 Answers
The following link explains step-by-step how to properly install an appliance cord on your dryer:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
If you have any questions, please post back and let me know. I hope this helps you.
Posted on Oct 05, 2010
Hi.i got a new dryer and its 3 prong but the house is 4 prong so i got a 4 prong and im not sure where the wires go. The diagram shows L1 N L2 than the green ground but the new 4 prong only has green red...
Ok. Let's simplify this for you. First and foremost you will want to remove the copper strip that goes from your center cord post the to case/cabinet of the dryer. This is to seperate your neutral and grounds within the machine. Some models used a green jumper wire instead of a copper strip but the idea is the same.
Now on the new cord the green (ground) wire is supposed to go to the connection point the copper strip used to go to on the cabinet. The white wire (neautral) is supposed to go to the center terminal connection on the terminal block and the red and black (L1 and L2) wires can go to either of the outside terminals.
The only difference in a four wire cord application is the segregation of the electrical neutral and the ground wires.
Good luck, hope this helps you!
Jun 26, 2010 | Frigidaire GLER341A Electric Dryer
Wiring for three prong power supply cord
If you desire to convert an appliance from a 4-prong to a 3-prong, make sure you reconnect the bonding strap and/or ground wire to the Neutral (white) wire at the terminal block.
Connections
New
Picture shown is for a range cord but is exactly the same for a dryer connection.
Feb 03, 2010 | Roper REX4634KQ Electric Dryer
I need to change out my 3 prong dryer power cord with a 4 prong dryer cord, but unable to figure out where the wires go on the new 4 prong power cord, because the one on there is grey and not color coded...
Changing from 3 to 4 wire hookup on a electric dryer:
Power cord help for 3 & 4 prong dryer cords
This is an example of a three wire connection dryer cord hookup. Notice that there is a ground strap connected from the common center terminal to the frame of the terminal block. Place the center wire of the cord on the center terminal [ one with the ground ******** it ] and the other two wires will be placed on the outer terminals and it doesn't matter which wire goes right or left. Get the center wire of the cord right and you are in business.
This is an example of the 4 wire dryer cord hookup. Notice that the ground strap has been removed from the terminal block frame and folded back onto the center terminal for storage. You can see the colors of the other hookups. TIP: White always to the middle.
Below are a few websites.
http://www.applianceaid.com/general.html#3to4
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=10&newsdesk_id=5
Nov 13, 2009 | Kenmore Elite HE4 Electric Dryer
Same dryer but I need to switch to a 4 prong cord.Please help!
WARNING! I believe you want to replace a 110V-120V plug with a 220V. Don't do it until you know for sure. Sounds dangerous! Not an expert, just some free advice from a novice.
Aug 17, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Changing from a 3 prong to a four prong
grasshopper_2.gifWiring in a new power cord for your electric dryer? Upgrading your electric dryer outlet from the old three-prong to the new four-prong outlet? Well, grab hold of those two large lumps at the base of your spinal cord and let's romp through the wild and wacky world of dryer cords and outlets.
tn_3cord_dryer_terminal.jpgtn_4cord_dryer_terminal.jpgThese two pictures illustrate the power wiring on a the terminal of an electric dryer. The one to the left here is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown to the right. These are just just thumbnail pictures that you can click for a larger view. But I'll bet you already figured that out, didn't you?
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
tn_3prong_dryer_outlet.jpgtn_4prong_dryer_outlet.jpgIf you need to re-wire the outlet, these pictures will explain the anatomy of the three-prong (left) and four-prong (right) outlets. Once again, these pictures are just thumbnails--click 'em for a larger view.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Jul 23, 2009 | Dryers
Wire 3 prong cord
Electric Dryer How To Hook Up Cord pixel_trans.gifFor Three Prong Cords
the Center cord wire goes on the center terminal,
the left on the left ,
and the right on the right.
Note: There should be a ground strap or wire that runs from the center terminal to the dryer case.
For Four Prong Cords
the White cord wire goes in the center,
the Red on the Right,
the Black on the Left.
The green cord wire goes to the case or the external ground screw.
Note: Be sure to disconnect the ground wire or strap that runs from the center terminal to the case. In this Photo (A Whirlpool Dryer) I have ran the wire that runs from the center terminal, the Light Green wire, back to itself rather than cutting it off, just incase I need to put a 3 prong cord back on it some day. The whole purpose of this 3 prong / 4 prong thing is it separates the neutral from the ground. pixel_trans.gif pixel_trans.gif3 Prong Cord Whirlpool Dryer Example terminalblock.jpg 4 Prong Cord Whirlpool Dryer Example 4prongcord_small.jpg
Jul 02, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Have a three pronged power cord, need a four pronged power cord
four prong sould be installed as followed, black and red go to eitehr ends( amkes no difference which, white goes to middle and the green wire gets screwed directly to the dryer cabinet itself( usually an existing green screw just outside the connectin box. if there no power after that then check to be sure oyou indded have 220v going to the outlet
Mar 28, 2009 | Whirlpool Dryers
4 prong dryer cord to 3 prong dryer cord
YES NEUTRAL GOES IN THE MIDDLE L1 AND L2 WHICH ARE HOT GO TO THE LEFT AND TO THE RIGHT LIKE THE CORD IS LAID OUT
Dec 11, 2007 | Dryers
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
