Question about Hardware & Accessories
For an intermatic EJ341 spring wound timer, there are two black wires that are connected to two black wires from the wall outlet. If looking at the back of the timer (not at the dial knob), which wire needs to be connected to the Hot wire and which one for the load?
Switch has 2 wire > one of these wires is Hot and it connects to Timer black wire > the other wire goes to Load and connects to Timer red wire.
If you get these two wires reversed, timer will not run, so switch them. You know timer is running when dial on front of timer rotates with passing time. You can test for Hot wire by taking out switch, separate wires, turn on power, test each wire to bare ground, tester lights up with Hot wire.
Timer white wire goes Neutral. This wire is necessary to run clock inside timer. Locate Neutral wire inside box >> it is usually two or more white wires twisted together and pushed to back of box. If you do not have a Neutral wire, connect Timer white wire to bare ground wire ... until you can hire electrician to run additional wire to box.
Posted on Oct 05, 2010
UL number for Intermatic spring wound Timer FD15MWC
1) Probably not if the timer looks identical and is approximately the same weight, and not a lightweight knock-off product.
Which doesn't make sense why a chinese company would knock off a timer that doesn't sell in giant quantities, and there are so many other similar timers on the market from Utilitec, Woods, GE, Tork, etc.
http://waterheatertimer.org/Countdown-timer-horsepower-ratings.html#FD
http://waterheatertimer.org/pdf/038_FD-series-sell-sheet-with-wiring.pdf
2) The Intermatic brand FD and FF series timers have phillips-head screw terminals for connecting wire, and wire enters on the side.
3) All spring-wound timers are rated heavy-duty for 1HP at 120Volt and 2 HP at 240Volt. Set times are approximate. Timer has 1 year limited warranty against defects in manufacture and will last many years as long as amp-rating is not overloaded.
4) Call Intermatic customer service
5) Add a comment and say what you find
Jan 22, 2013 | Intermatic Hardware & Accessories
I'm looking for a timer to replace the thermostats for 2 furnaces in a riding arena.
1) Yes a spring-wound timer will work.
Woods 59717, Intermatic FD60, etc
There are other models depending on length of time, and color of timer
http://waterheatertimer.org/Woods-timers-and-manuals.html#countdown
2) How to wire to 24 volts
24 volt circuit has 2 wires going to load.
Cut one of the wires and then connect cut wire to timer.
3) Buy Woods 59717 or Intermatic FD60 timers at Amazon.com in home improvement.
Both products have 1 year warranty, and both are strong companies.
Spring-wound timers last many years, and set-times are approximate.
Jan 03, 2013 | Woods 60 Minute Spring Wound Timer in...
Night sentry-solid state timer model ej341-70
Copy following links for EJ341 timer manual:
http://waterheatertimer.org/pdf/EJ341-manual.pdf
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
May 27, 2012 | Solar Intermatic Single Pole Model Ej341c...
Dear Sirs, I try to change Intermatic E1343 solid state timer to normal 2 ways switch. I saw the cable in 3 colors : black, red and blue. do ou know the menaing of each cables? if you can email me...
I think you mean Ei343 instead of E1343.
I have manual for EJ341 and EJ343 that shows wiring for single-pole and 3-way.
I believe the EJ343 is wired same as Ei343 since Intermatic Load rating chart groups these timers together.
http://waterheatertimer.org/pdf/Intermatic-EJ343-timer.pdf
Load-rating chart:
http://waterheatertimer.org/pdf/Load-ratings-for-Intermatic.pdf
Load chart implies this is 120Volt in-wall timer for inductive and tungsten loads up to 400Watts.
Now here's something to remember.
When any timer is wired for 3-way, the timer replaces one of the 3-way switches.
The other 3-way switch remains, but the other 3-way switch has to be rewired differently so that 3-way timer works correctly.
When removing timer from 3-way circuit, don't forget to re-wire the remaining 3-way switch so it works correctly.
To convert your timer to operate single-pole: Timer Black wire connects to Hot wire from circuit breaker. Timer Blue wire connects to wire going to Light. Red wire is capped off.
To see similar wiring illustrations for newer generation Intermatic timer, open following link:
http://waterheatertimer.org/ST01C-program.html#ST01C
Aug 01, 2011 | Garden
Despite the fans working on a plain Jane single pole switches, I can't get these 6515M switches to work for my 1.3 ceiling fans. The fan hums and all I get on the timers are red LEDs. These timers...
1) Leviton 6515 is incandescent only:
http://www.amazon.com/Leviton-6515M-I-2-5-10-15-Electronic-Incandescent/dp/B0007NOZDI
2) Below is list of countdown timers with horsepower rating so they work for fans:
GE15088 countdown timer is rated 3/4 hp
http://www.homedepot.com/webapp/wcs/stores/servlet/ProductDisplay
Intermatic spring wound countdown timers are rated for 2 horsepower
http://www.intermatic.com/products/timers/in-wall%20timers/decorator%20spring%20wound%20timers.aspx
Woods spring-wound countdown timer says bath/ ceiling fans, but doesn't give horsepower
http://waterheatertimer.org/pdf/Wood-59700-series--spring-wound.pdf
Woods push-button countdown is 1/4 horsepower
http://www.amazon.com/Woods-59014-Decora-12-8-4-2-12-Hour/dp/B002C54GH4
Wattstopper RT50 at Grainger shows 1/6 horsepower rating
http://www.grainger.com/Grainger/WATT-STOPPER-Time-Switch-2HTE1?Pid=search
3) Following timers are NOT rated for fans:
Lutron MA-T51 countdown timer specifically says it cannot be used for motors.
http://www.amazon.com/Lutron-MA-T51-WH-Maestro-Countdown-Timer/dp/B001EFV1DA
http://www.lutron.com/TechnicalDocumentLibrary/0301041A.pdf
Pass and Seymour RT1 countdown does not show rating for horsepower, so this timer will probably not work for fan motor
http://www.homedepot.com/Electrical/h_d1/N-5yc1vZ1xg8Zarcd/
Feb 26, 2011 | Leviton 6515M-W Timer Switch, 2-5-10-15...
I nees 15 min. timer for my Newtone bathroom heater. I live zip code 94602 Oakland, Ca. Where to find. Thanks
You need "15 minute countdown timer" for a bath fan.
1) Following page shows selection of timer types and brands:
http://waterheatertimer.org/Countdown.html
There are push button electronic types and rotary dial types.
2) Easiest to wire is mechanical spring type countdown timer, FD series.
No electronics that can be affected by 'electric noise' on fan circuit.
Intermatic spring-wound last for years without problem.
http://www.electricsupplyonline.com/prod/intermatic-springwound_timers.php
http://www.electricsupplyonline.com/prod/intermatic-springwound_timers/fd15mc_w005485.php
3) Another reliable timer is GE 15088 sold at Home Depot.
Timer has preset for 20 minutes, not 15
4) Amazon sells reliable 15 minute Intermatic electronic countdown:
http://www.1000bulbs.com/product/3293/ELEC-EI200LA.html?utm_source=SmartFeedAmazonProduct
5) Timex sells 15 minute spring wound countdown timer. Lower price is probably with reason since Timex are generally sold in drug store/dollar store rather than hardware/electric outlets.
http://www.amazon.com/Timex-Minute-Springwound-Countdown-Timer/dp/B00013K69Q
6) Spring wound timers connect easily to same wires that come off old fan switch.
Old switch has 2 insulated wires, connect them to either terminal on spring wound timer.
7) Electronic timers are wired differently:
Instructions for wiring electronic timers appears on following link:
http://waterheatertimer.org/GE-timers-and-manuals.html#15088
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 23, 2011 | Broan-NuTone Fan,Bathroom Exhaust Broan...
Where can i buy a intermatice ej341? we live in delray beach, florida
1) I searched Intermatic for EJ341 and showed no result:
http://www.intermaticstore.com/
2) I searched internet for EJ341 and showed a guy replacing EJ341 with GE 15086
http://www.fixya.com/support/t6267843-am_replacing_old_intermatic_model_ej341
3) Intermatic makes timer with similar number: EJ351 push-button-dial-type timer, which is available with internet search
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers.aspx
4) You can choose from many timers on market today:
http://waterheatertimer.org/Programmable.html
http://waterheatertimer.org/UPM-timers-and-manuals.html
5) Add a comment for more free help.
Jan 22, 2011 | Solar Intermatic Single Pole Model Ej341c...
10 year old timer will not shut off any more
It's broken.
I have a FF series countdown timer on a water heater circuit that's been used for past 4 years.
The FF and FD series timers are heavy duty, spring-wound countdown timers.
I expect 10 years is a good lifespan.
You can buy a new spring-wound countdown timer at Home Depot or Lowes, but new ones are lighter weight than the good ol' Intermatic.
Grainger sells the FF60 (60 minute, metal cover)
http://www.grainger.com/Grainger/INTERMATIC-Spring-Wound-Timer-6X546?Pid=search
Grainger shows the FD60 (60 minute, plastic)
http://www.grainger.com/Grainger/INTERMATIC-Spring-Wound-Timer-1XC27?Pid=search
Grainger Intermatic timers shows a lot of FF and FD timer choices:
http://www.grainger.com/Grainger/intermatic/ecatalog/N-1z0r56r
There are several pages of Intermatic timers:
FF5minute thru FF12hour
FD15minute thru FD60minute
Nov 09, 2010 | Intermatic FF12HHC Energy Controls -...
I am replacing an old intermatic model EJ341 spring wound timer with a GE15086 digital in wall timer. The old intermatic timer has two black wires from each side (I dont know which one is hot). Each of the...
GE 15086 is a 7-day programmable timer. It has more wires than spring-wound timer because clock motor runs on 120V circuit, just like ordinary electric clock. The clock on spring wound timer operated by a spring.
If I understand correctly, the old timer has 2 wires. One of these wires is the Hot wire ... and that wire will connect to GE timer black wire.
The other wire from old timer goes to Load ... and that wire will go to GE timer red wire.
Instructions on a lot of these timers say, it timer doesn't work, then reverse the two wires described above ... this is because timer only works when Timer black connects to Hot.
You can also turn on power and test each wire that came off old switch to bare ground wire. When tester lights up, that is Hot wire.
GE timer Green wire connects to bare ground wire.
Moving on to GE timer white wire. This wire is necessary for the clock to run. This wire connects to Neutral wire which is usually white. You can test for Neutral by testing Hot wire to each white wire in box ... when tester comes on, that is Neutral.
If you do not have a white Neutral wire, then connect GE timer white wire to bare ground wire. This is not code, but it will work fine until you hire electrician to run Neutral into box.
Oct 03, 2010 | GE Electrical Supplies
Hardware & Accessories Logo
402 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
