Question about Kenmore 57029 Side by Side Refrigerator
Why doesnt the water and ice work on my side x side kenmore refridgerator
    Problem Solver:
  • 10 Answers
1st-Make sure you have water entering the unit. 2nd- If you have recently replaced the water filter- make sure it is properly installed. When you press the water dispenser, you should be able to hear the water valve energizing. If all fails, your best resource is to have a Sears tech service the unit specially if Ice-maker continues Not to function. It might be costly but they warranty the work without any stories.
Posted on Oct 05, 2010
peyton32034
  • 410 Answers
SOURCE: Bad tasting water and ice from refridgerator.
i agree with rpbuice but in addition to flushing the water line you may need to replace the line then using the water dispencer run out about a gallon of water thru the door. this will clear the reservoir of bad tasting water. for the i/m throw out all of your ice then let it make a couple of batches and throw out that ice as well be sure to clean your ice bucket very good to remove any lingering tastes from the old ice.
fyi bad tasting water is generally from bad water supplies. good luck..
Posted on Jan 20, 2009
ginko
  • 19396 Answers
SOURCE: Ice maker stopped working
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Posted on May 22, 2009
FreeTech
  • 426 Answers
SOURCE: Our Hotpoint side by side refridgerator, the ice/water not workin
It sounds like you have a failing relay/valve that wont stay open when current is passed through them, check there first otherwise your control board could have water/heat damage remove inspect and if necessary replace let me know how it goes :)
Posted on Jul 11, 2009
  • 3368 Answers
SOURCE: Kenmore side by side: ice maker works...ice
Probably a broken plastic tube from the solenoid valve to the water outlet tube. It will stay dry until you try to get water then it may take a few days to dry out.
Good Luck,
Gilsh
Posted on Nov 27, 2009
  • 3 Answers
SOURCE: ED2KVEXVL Whirlpool refridgerator - not cooling in refridgerator
Tip: Most self-defrosting household refrigerators that loose part or all of their cooling in the freezer or fridge are having problems with the self-defrost system. Three components to check: defrost timer; defrost heater elements (esp. on side x side units); and evaporator fan. All cold air is normally produced in the freezer, then circulated via evaporator fan to the refrigerator section. About every 12 hrs. a defrost timer turns off the compressor, and turns on the defrost elements to melt the frost from the evaporator coils. This normally takes about 20 minutes to complete, then the timer turns off the heaters, and restores normal cooling operations. If the cycle does not complete properly, the coils will "ice up", restricting proper air circulation through the freezer and refrigerator sections. Worse yet is if timer sticks in defrost mode (rare), it will turn the freezer into an oven. If the defrost system seems to be working normally, then you should check the condensing coils for excess dirt, and vacuum &/or bush the dirt and lint out to restore proper head disipation. It's recommended that you vacuum out a condensor that's located on the bottom of the unit once a year. You should also check the condensor fan (if present) for proper operation. If the condensor fan fails, heat can not be properly released from the condensor, and will cause the refrigerator to 'run all the time' yet not cool efficiently. There are many things to check on modern frost-free refrigerators, before turning to the actual sealed refrigeration system and compressor unit.
Posted on Jan 11, 2010
Is there a water filter in my 7102 kenmore refridgerator
There could be one in the water line that feeds the ice maker.
Apr 03, 2014 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Whirlpool refridgerator is leaking water on the freezer side (side by side refridgerator) onto the floor. The ice machine was overflowing with ice and has frozen ice in the ice maker that won't budge. We...
WAS IT LEAKING FROM INSIDE THE FREEZER OR FROM BOTTOM OF FRIDGE? ONCE IN A WHILE YOU NEED TO TAKE OUT THE ICE BIN AND DUMP ICE OUT AND CLEAN IT. HOW CAN THE ICE MACHINE OVERFLOW WITH ICE WHEN THE ICE IN THE TRAY WON'T BUDGE? NEED CLARIFICATION. SOUNDS LIKE YOU EITHER HAVE A BAD ICE MAKER MODULE OR THE SOLENOID FOR THE ICE ON THE WATER VALVE IS BAD.
Jan 24, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice works, water doesn't kenmore side by side refridgerator
HI, make sure that the lines are not frozen. This will happen if the unit is set to a temp that isn't manufacture standards. Once you have verified that the lines are not frozen, This will confirm that the inlet valve is malfunctioning. have it replaced asap.
Sep 05, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
I WAS WONDERING ABOUT THE ICE MACHINE,IT ISN'T
check for water then check water valve where hose connects. the see if the is water in ice maker if so then wait for ice, if no water it could be the valve
Jul 28, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Jul 11, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
May 18, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore refridgerator #25351694102
check for a lock button on dispencer controls
Aug 05, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Kenmore no water
does the machine have a lock out button on the despenser that you can push to activate the water and ice
Apr 06, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker not working
I recently had trouble with both my water dispenser and my ice maker. I determined that my filter was clogged, so I replaced it. That fixed the water dispenser but the ice maker still wasn't working. I investigated further and found that the water inlet tube was frozen solid. Aparently, when the filter was clogged the water came in so slowly that it froze before it got to the icetray. I tried pouring hot water over the inlet tube to melt it and it mostly worked, but there was still some ice in the tube further back where I couldn't reach. Finally I defrosted the freezer so all the ice could melt and turned it back on and now it works great! Hope this might help.
Dec 17, 2007 | Kenmore 21.7 cu. ft. Side-by-Side...
Kenmore 57029 Side by Side Refrigerator Logo
82 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
