Question about Honeywell Heating & Cooling
I flip the switch to "Cool" and nothing comes on. How do I turn the AC on? It's central ac.
First Check that all ckt brakers are on.
Posted on May 28, 2008
When I turn the furnace on the ac comes on also.
If you have both heat and ac running that means that the Yellow , AC and the White heat circuits are both being energized with the Red 24 volt hot leg that enters the tstat on the R terminal, note the Auto fan switch between Yellow and Green if Normally closed that is the Auto setting and high speed fan comes on for the Cool mode via the fan relay,
while the Heat speed is low speed and controlled not by the fan relay but the temperature or time delay, you need to determine what speed you have running now, low or high? if you flip the fan switch to ON and it speeds up then it was on low, if it makes no difference you have high sped running already.
Oct 06, 2013 | Dometic Rooftop RV Air Conditioner
Central Air- Breaker flips when AC is turned on
IT SOUNDS LIKE YOU HAVE A BAD COMPRESSOR OR A DEAD SHORT SOME WHERE IN THE UNIT
Aug 31, 2009 | Dometic Rooftop RV Air Conditioner
MY CENTRAL AIR CONDITIONER IS RUNNING BUT NOT COOLING
If your house is not getting cold enough when your A/C is turned on, It is time for a good cleaning. There are a variety of factors that may cause your A/C to not cool your house. With that said, here is a diagnostic article that provides the most probable causes of your A/C's failure to cool your house, and from there you can read it and then, step by step, rule out each possible cause listed in the article:
http://yourhandymanzone.com/Your_Handyman_Zone_How_To_Pages_Home_Improvement_Zone_Cooling_Ventilation_Systems_Central_Air_Conditioning_Does_Not_Cool.htm
Of course, a low level of Freon/refrigerant may be the problem, but there may be other problem causes as well, as noted in the article---it may just be that debris is obstructing your AC as well. Read the article, and, actually, your best bet may be to take advantage--towards the END of the above-linked article--of the text-link for Free four (4) quotes from local AC contractors in your area, and "pick the brain"--seek the advice--of these local technicians who offer you a free quote to discern what could be the problem. Also, since you may need a Freon/refrigerant recharge, you'll ultimate need this AC contractor to do it for you, since federal law prohibits the selling of Freon/refrigerant to anyone other than licensed AC contractors/technicians.
Aug 08, 2009 | Heating & Cooling
My breaker pops when i switch the unit to coo
Sounds like compressor has shorted
Aug 07, 2009 | Heating & Cooling
Turned AC thermostat to Cool today - AC didn't come on. The last time we used AC (March 2009) it worked fine. I can hear the AC Relay Board, inside the trailer, click when switching from Cool/Off &...
Just clicking is all your getting from ceiling assembly? No other modes work such as fan, or furnace? If that's the case, check your circuit breakers to make sure it didn't trip.
Jul 28, 2009 | Dometic Rooftop RV Air Conditioner
Ford Taurus Heater won't switch over to AC
I guess first thing to find out is why compressor is not coming on, as without that running you won't get any cool air. May just need a recharge, but I would have that checked out first. If system is low on freon, it won't engage, and if it is low, why, as in where is leak & how much to fix it, would be my first concern.
Jun 28, 2009 | 1998 Ford Taurus
AC unit turns on blower doesn't come on
The thermostat is the controller.
Jun 19, 2009 | Heating & Cooling
My central ac unit is blowing air that is cool but not cold
Ek chiz sukha ho to 2kg gila ho to 1kg and jal jaye to 3kg its urgent please
May 18, 2009 | Heating & Cooling
AC Problem
possibly faulty fan or fan relay also check that 24 v are coming out of the transformer
Sep 03, 2008 | Carrier 38CKC036 Air Conditioner
I'm trying to turn on the central air conditioning in my new apt, and it's not working. I'm flipping the switch on the bottom right to Cool. It's blinking "Cool On" but also says...
Remove the front cover off the thermostat and jumper the power wire= r- to g==fan & r-to y==cool if it works, then its the thermostat!
Sep 01, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
54 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
