Question about Nikon D300 Body Only Digital Camera
I have put the card wrong way in nikon D300. Know iI can not put any card. How can I fix this?
  • 98 Answers
You suould give it to a qualified technician.
Posted on Oct 05, 2010
My nikon d300 will not format the SD card....
Hi, Dear
Nikon D300 does not use SD card! It use CF card.
But if you have format problem in camera then I recommend format from a computer using memory card reader. And then put the memory card into camera and try to format! Here it does not, then you should show to your local repair shop and it will cost between $120 to $265 usually. In minor problem case it will be replacement of memory card acceptance unit replacement. But the problem come from main pcb then the estimate will be totally different!
Hope You Luck! A Professional Camera Clinic Guy
Apr 05, 2015 | Nikon Cameras
My nikon d300 will not recognize any card. when I put the card in it shows chan in the window that shows how many pictures you have. It has never happened before and i checked my cards on my other camera...
I am a Spanish amateur photographer and I repaired my Nikon D300 with the same fault. In my blog there is a tutorial. In Spanish, but you can translate it with Google.
Mi Blogg.
Good luck
Mar 20, 2011 | Nikon D300 Body Only Digital Camera
When I want to take a photo, the monitor is blank, rather than showing what I am pointing the camera at. Last time I used it, it was ok... what has gone wrong? Thanks
If the D40 monitor showed you the image while taking the picture, there was something seriously wrong with the camera, which now appears to have fixed itself.
The D40 works as SLRs have worked for half a century, giving you the image through the viewfinder. The LiveView capability, allowing you to use the LCD monitor like a point&shoot camera, is a relatively new development, which Nikon introduced with the D3 and D300 a year after the D40.
Dec 17, 2010 | Nikon D40 Digital Camera with G-II 18-55mm...
What is 15r error message for Nikon D300?
HI there 15r error occour when the memory card is not working properly. May be damaged or virus infected. So i suggest you please replace the memory card and use a new one, your problem will be solve then.
Thanks.
Mar 10, 2010 | Nikon D300 Digital Camera
Today I removed my Sandisk memory card from my Nikon D300 before going on a photo job to replace it with an empty one but couldn't get the new one to go in-or the one I had just removed. The camera shows...
CHA error message means that the memory card is unusable. You should format the card by inserting it in a card reader or try another card.
Let me know if you need more help,
Sai.
Jan 18, 2010 | Nikon D300 Digital Camera
D300 cards not accepted chr message
try the last card you had in it before this problem occurred sometime the processor in the camera doesn't realize the disk is gone sort of like your computer once it starts reading a disk and you remove it half way threw the load. Well usually before yu can go any further on the computer you must put the **** back in and close the program out. This issue is usually case on cameras when the disk is removed before the camera is turned off.
Oct 08, 2009 | Nikon D300 Body Only Digital Camera
Nikon SD card for D80 / D200/ D300
You should have no trouble using the SDHC cards. SDHC stands for Secure Digital High Capacity. The images should load directly from camera to computer, without the need for any additional hardware.
Feb 12, 2008 | Nikon D80 Digital Camera with 18-135mm...
Nikon TC-17E II with Nikon 70-200mm f/2.8
You may have a dirty contact on the tc cpu pins. Try cleaning the pins with a clean pencil eraser or some methanol. You could also have a loose connection between the tc and the lens or body. Try applying a rotational force in both directions...see if you notice any change in behavior. If you have a local shop, see if you can try another copy on your lens.
The 17e may have slow-ish performance in low light, but it should still be usable. If neither of these issues is apparent then it may need to be exchanged or serviced.
Jan 10, 2008 | Nikon TC-17E II for AF-S, AF-I 1.7x Lens...
Nikon D300 Body Only Digital Camera Logo
37 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
