Question about Maytag Washing Machines
Maytag Washer, model MHWZ600TW01, Fault Code F01
    Genius:
  • 1,028 Answers
Control bd
Posted on May 29, 2008
Maytag Bravos Quiet Series 400: F01 Error code
maytag washer with error code F01 means a obstruction in a hose or tube, not a control panel issue like people say. How can I clear the small tube? see pics
Dec 08, 2016 | Maytag Washing Machines
Kenmore elite he5t washer model 11047789701 flashing F01 fault code- does this mean ccu must be replaced?
Do not take this as definitive answer! I am not an expert. A F01 error is indicative that the Central Control Unit cannot get instructions from the EEPROM. If you have not already done so, unplug the washer for a full 2 minutes to clear any instructions in memory, then plug it back in. If you still have a F01 error I suspicion that it is a bad CCU board. You can try to run the diagnostic on page 8 of the service manual but I do not think it will run if it is a bad CCU board.
Mar 08, 2015 | Kenmore Elite HE5t Washer
Why is my Maytag Epicz model #MGDZ600TW2 not starting amd giving me an error code F01. What does it mean?
F01 is a control unit failure does this come up when you push the start button or did you go into diagnostic to get this code I have seen it come up as a false code check the start button does it spring back like all the other buttons if so replace control if not the button is broke
Jan 29, 2015 | Maytag Dryers
Why is my Maytag Epicz model #MGDZ600TW2 not starting and giving me an error code F01. What does it mean?
The F01 error code is typically a communication fault. You may have a defective main control board. Unplug the dryer or turn off the breaker to the dryer. Double check to make sure dryer has no power. Remove the screws holding the top on at the back of the dryer. Standing in front of the dryer push down and slide the top away from you then lift. With the top removed you will see a metal bracket on the left side housing a control board. Remove the control board from the bracket. You may want to take a picture to reference where the wires go. Remove the white cover of the control board then gently remove the control board from the white housing by pressing in the small tabs. If you see a black mark on the back side of the control board and the white housing replace that control board. According to your model number the main control board is part number W10111606.
Indesit iwde7168 fault code f01 on drying
Indesit F01 is a board/motor fault, as it is happening on dry I would suggest looking at the board again ensuring there are no other blown solders or indeed the repaired solder connecting to another
Apr 07, 2014 | Indesit IWDE7168 Washer Dryer - White
Front load washer displays f 24
Here is a link to the owner's manual for that device.
http://www.searspartsdirect.com/partsdirect/user-manuals/mhwz600tw01-maytag-residential+washer-manual
Mar 19, 2014 | Washing Machines
When i try and turn it on, a code comes up f 01
Model #MHWZ600TW01, this unit would display an F01 error immediately after the start button was pressed. This error is an EEPROM communication failure of the electronic control board and is an internal failure that basically indicates the washer no longer thinks it's a washer. Since the repair requires the board to be replaced, I installed a new control board and now it has started washing again. A word of caution. Whirlpool has been making a lot of changes to the control boards of their front load washers (yes Maytag too) so make sure you are ordering the correct model using the full model number including the last two digits. If you install the wrong board, you may find yourself trying to fix a self induced problem.
Aug 09, 2010 | Maytag EPIC MFW9700S Front Load Washer
Wf860 washer dryer - dryer has no heat and displays f01
Hi, Fault code F01 indicates a problem with the motor triac.Check all connections to and from the motor, the control module, and the motor plug
Apr 08, 2010 | Hotpoint Ultima WF860 Front Load Washer
Error code
I could not find error f01 for maytag, but for for whirlpool, it means CCM(central control unit) unplug washer for 2 minutes then try it.
Jul 12, 2008 | Maytag EPICz Electric Dryer
Washing Machines Logo
691 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
