Question about HP DeskJet 932c InkJet Printer
Stuck cartridges there was a paper jam, when trying to pull the paper out, the cartridges wont move, at first they made a humming noise & moved slightly, now there is no noise & they are stuck at one end
Thanks but the ribbon that pulls the cartridges back & forth actually broke,
had to get a new printer
Posted on May 28, 2008
I keep getting an error message about a paper jam for my printer but there is absolutely no paper jammed anywhere in the machine.
Have you tried a new toner cartridge, The toner cartridge has moving parts, and of the cartridge gets stuck, the printer may indicate a paper jam.
Also paper often tears when clearing jams, and the little shreds of paper can stay in the rollers of the printer and keep it jammed. Make sure to inspect all the rollers to make sure they move freely, and do not have anything stuck in them.
Aug 21, 2014 | D-Link D LINK DELL B1260DN MONO LASER...
Cartidges wont move
the cartridge as you call it is the carriage, which houses the inks and printheads, Its supposed to be 'Locked' at the service station until such time as the printer is ready to start printing,
what you should look for is a strip of what looks like clear plastic that runs the lengh of the print surface, give this a GENTLE clean with a cloth damped with WATER, ensure there is no paper blockage along the print path the cycle thhe power allowing the machine to come to ready or fault displayed
Mar 09, 2014 | HP OfficeJet Office Equipment & Supplies
Why doesn't my HP OfficeJet 7500A carriage move? It is jammed
Try to turn it off, open cover and move carriage a little bit by hand; don't push too hard. For some time it'll get back to life.
Feb 02, 2013 | HP OfficeJet Office Equipment & Supplies
I keep getting the message cartridge jam on my hp psc 2355. A paper jam was pulled out of the front so I know this is the cause but how do I fix it please?
It's not saying carTridge jam, it's saying CARRIAGE jam. Something is stuck under the heads.
unplug the power from the unit, and try to manually move the heads off to the left side, checking for paper under the head as you move it over.
Check the head docking area on the right as well.
Plug the unit back in and everything should be fine once everything is cleaned out.
May 24, 2011 | HP PSC 2355 All-In-One InkJet Printer
How to Clear carriage jam on HP PSC 1610 Printer? No obvious paper jam visible.
Dear it's the carriage jam error. so it mean that your carriage is jam not paper. so open the printer where you insert the cartridge. check whether it is jam or what . cartridge carrier is jam kindly turn off the printer and try to move the cartridge head by hand very gently and if seems to be stuck than check for anything which abort him to move freely so than might be anything like dust or else. when you get success in moving the head put some machine lubricant on the rod on which head moves and check it ok.
Dec 04, 2008 | HP Office Equipment & Supplies
Epson 1280 ink carriage making noise and not printing
hello there. try re-seating the cartridge. Take it out, then put it back in.
Nov 28, 2008 | Epson Stylus Photo 1280 InkJet Printer
Paper Jam in HP Deskjet F2100 All in One
1. Check for and remove any paper stuck in the paper in tray
2. clear the paper jam from the back of the printer
a. unplug the AIO
b. Press in the tab on the left side of the rear door to release the door. remove the door by pulling it away from the AIO
c. gently pull the paper out fo the rollers
d. clean the rollers with a lint free cloth that is moist with distilled water
3. Lift the front cover and slowly remove any jammed paper
a. unplug the power cable
b. if necessary pull the input tray down to open it. then lower the print cartridge door
c. gently pull the paper out of the rollers
d. close the print cartridge door
e. plug the power cable
4. Verify that the print cartridge carriage can move freely
b. check to see if the print cartridge carriage can move freely from one side to the other.
c. remove the print cartridges
d. gently move the print cartridge to tyhe far right of the printer
e. remove the paper from the paper in tray, but do not remove the drawer
f. remove the rear acces door
g. with your fingers rotate the rollers "up" three full rotations
h. close the rear access door
i. replace the print cartridges
j. plug the power cable
k. turn the power on
5. reload and test the printer
Aug 06, 2008 | HP Office Equipment & Supplies
Will not print / cartridges will not move back and forth
I had this happen to me the other night and I had to restart the printer to get the print job out of the que. You could try that.
While it's restarting, unplug the power cord and the usb cable. That should reset it.
Jun 21, 2008 | HP DeskJet 5550 InkJet Printer
Won't pick up the paper but the cartridges move up and down the line
Hai Boss it is not the problem with the Catridge . Some of the Spring has begin missing in assemble part . you pull the paper out the problem cause from there never ever pull the paper ..
Feb 12, 2008 | HP DeskJet 970cse InkJet Printer
HP DeskJet 932c InkJet Printer Logo
128 people viewed this question
Ben Johnson
