Question about Reddy R70ET Utility Heater
How to measure the clearance on a Reddy Heater Rotor?
  • 232 Answers
Before testing check for lateral movement of the shaft which would indicate a bad bearing.
According to a doc from ReddyParts.com the pump body is adjustable by loosening the 2 adjustment screws. Slide the pump body down to meet the rotor, then raise the pump body so that there is .003 to .005 clearance. Then tighten the 2 screws. Manually spin the fan for a test.
We have always used a piece of heavy grocery sack for clearance.
Posted on Oct 06, 2010
Adjust reddy heater pump pressure it will not pump passed 2half psi i need it to go to 4half psi
To adjust the pump pressure on this type of heater, turn the threaded adjuster clockwise to increase the air pressure, but if the adjustment makes no difference, there maybe a loss of air pressure caused by a crack in the plastic filter end cover, the rubber seal at the end of the nozzle may be broken, gone hard, cracked or missing, there could be a crack in the burner head (where the nozzle screws in), leaking air supply pipe between the compressor and the burner head, the rotor and/or blades may be worn or damaged, or if contaminated with dirt,paint spray or oil, one or more blades may be stuck in the rotor If contaminated they will need to be replaced, but if doing so, remember to reset the clearance between the top of the rotor and the pump body, your manual will give you the correct clearance.
Jan 15, 2014 | Master Heaters Heating & Cooling
I have a model RM200T heater I have replaced all filters, rotor assy., and nozzle assy. pressure is at 6lbs but I get flames out past the end of combustion chamber. How can I stop this problem?
In the back of the heater there should be a screw adjustment which takes a slotted screw driver try turning the screw I believe counter clockwise to lower the flame.
Apr 01, 2011 | Desa International Reddy Heater 200,000...
Reddy heater 60 starts runs a short time and cuts off
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Jan 26, 2011 | Reddy Heater 60,000 BTU Kerosene...
Heater starts, fan runs, injecting fuel but won't fire up
heatman101
Jan 20, 2011 | Reddy Heater 60,000 BTU Kerosene...
Heater won't fire
heatman101
Jan 13, 2011 | Kjb DESA INTERNATIONAL TA100 100K BTU...
I also have a reddy heater 115000 btu fan spins freely until I put the plate on the back of the motor back on. It then instantly tightens the fan so it won't spin. The black circle on the back of the...
Make sure the all the fins (4 of them) are in the right way. I think they are longer on one side than the other. You may need to remove the black rotor and make sure the plastic insert isn't broken and check for build up on the plate behind it and the plate that you have already removed. Do not loosen the metal ring around it unless you have some feeler guages to reset the gap between the ring and the black rotor.The only thing that holds the black rotor on the shaft is the plastic insert. There also isn't very much clearance between the black rotor and the plates that is sandwiched between so it doesn't take much build up on either surface to cause a problem. One more thing, do you have the foam input filter air installed. Without it, the compressor will **** in dust, dirt or what have you and that will cause buildup around the rotor. It will also cause the rotor to break if it gets tight enough.
Jan 03, 2011 | Reddy R115DT Oil Filled Utility Heater
I can't get my reddy heater to light. No fuel
If there is NO fuel then the pump rotor is probably broken. http://www.reddyparts.com/rotor%20replacement.htm
If there is SOME fuel then set the air pump pressure. http://www.reddyparts.com/pressure.htm
Nov 02, 2009 | Desa International Reddy Heater R40 40,000...
I have a reddy heater 60,000,00 btu kerosone
Here are a couple of tips that I wrote that tell you how to troubleshoot aTorpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters Torpedo Heater Pump Pressure Adjustment
heatman101
Sep 19, 2009 | Reddy Heater 60,000 BTU Kerosene...
Replacing rotor on Readdy Heater
Remove top shell. Remove cover. Remove filters. Remove filter base. Then it should pull out. Check clearance on new rotor .003/.004 checked with feeler gage. Reinstall in reverse order. Reset air pressure. Good luck.
Jan 15, 2008 | Reddy R70ET Utility Heater
Reddy R70ET Utility Heater Logo
201 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
T bone 1963
Paul Carew
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
