Question about LG Washing Machines
After a cycle, the door will not unlock. I have tried unplugging the washer and letting it sit for a few minutes. I have tried pressing the start/pause button, but that won't fix it. I have tried turning it off and then turning it back on, but the door is still locked.
    Problem Solver:
  • 10 Answers
You need to remove the bottom cabinet and on the inside to your right you will find a plastic handle tide to a cord- when you pull it - door should release. Please make sure to unplug unit from electrical. Note: It seems like the door release switch has failed.
Posted on Oct 05, 2010
How do I unlock a whirlpool duet washer
from a previous discussion:
Wait at least three minutes after the end of the cycle before attempting to unlock your Whirlpool washer. The door will not unlock until the motor speed equals 0 and 180 seconds have elapsed since the motor control unit received the "Stop" command. If the water in the washer is warmer than 122 degrees Fahrenheit or the water level is set higher than Wool, Delicate or Hand Wash, the washer must drain before the door latch will unlock 2 Hold down the "Control Lock" button on your Whirlpool washer for three seconds at the end of the washing cycle. Listen, and when you hear the unlatching sound, the door should open.3 If your Whirlpool washer did not unlock at the end of Step 1, press and hold the "End of Cycle" button for five seconds to manually reset your washing machine.4 Unplug your Whirlpool washer and leave it unplugged for 45 minutes. After 45 minutes, plug your washer back in. The washer's programming should be reset and the door should open.5 Manually unlock the door of your Whirlpool washing machine. Make sure to unplug the appliance before completing the manual unlock. Use a screwdriver to remove the metal strip, called the toe panel, at the bottom of the washing machine. Once you've removed the toe panel, reach up inside the front panel of the washer and feel around for the door latch. Locate the tear-drop shaped tab at the bottom of the door latch and pull it gently. When you hear a click, the door should open.
Jan 04, 2015 | Whirlpool Washing Machines
Whirlpool duet washer door will not unlock or complete the cycle
  • Oct 13, 2011 | Whirlpool Washing Machines
    The door wont open . I have tried to put it on for a cycle and you can here the the water for around 5 seconds then it stops and does nothing.
    Check and make sure your pump or filter is not clogged, then next I would suspect you have a faulty door lock mechanism
    More common issues with the door lock.
    Is water hooked up to the washer?
    The door will remained locked while draining water. If during installation the washer was plugged in and turned on without water hoses attached, the washer may attempt to drain for 8 minutes before the door unlocks. Let the washer run until the door unlocks. Do not turn off the washer or unplug the washer.
    Does water remain in the washer after the final spin?
    If water remains in the washer after the final spin, then the door will not unlock. Select Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle. For models that have Rinse/Drain & Spin, push the Extra Rinse button to turn off the rinse to remove excess water.
    Is the door locked and the Add A Garment light on?
    If the Add A Garment light is on, then the washer door will unlock after the Pause/Cancel button is pressed once. Pressing the Start button will restart the washer at the same point where it left off in the cycle.
    Is the door locked and the Add A Garment light off?
    If the Add A Garment light is off, then the washer door will unlock after the Pause/Cancel button is pressed twice. The door will not immediately unlock while the cycle is running due to a possible high-water level in the washer, high-water temperature, tumbling or spinning. It may take up to five minutes for the washer to stop spinning and draining before the door will unlock. You will hear the door click when it unlocks.
    Trying to gain access into a locked door can be a bit frustrating. Upon researching your question I found some links that may help you unlock your washer door. I attached all links below. I hope this helps!
    http://www.managemylife.com/mmh/questions/204092-how-do-i-get-the-door-open-on-my-kenmore-washer
    http://www.managemylife.com/mmh/questions/220303-does-front-loader-door-open http://www.managemylife.com/mmh/questions/134692-why-wont-the-door-open-on-my-kenmore-frontloading-washer
    Jun 10, 2011 | Washing Machines
    Whirlpool duet ht.... Door will not unlock, cancel button turns machine off. will not start, unlock button does nothing. clothes stuck inside, not sure if there is water inside or not, but will not drain...
    Hello there and thank you for chosing fixya
    Here is a few things to check before you do a manual opening of the door
    You may have already done these steps but please try this again in this order ok?
    Check to see if the "Add a Garment" light is lit on the Duet's display. The light will only be on during the first eight minutes of a washer cycle, when the function is usable.
    Press the "Pause/Cancel" button once to pause the washing cycle and unlock the door.Press the Press the "Pause/Cancel" button twice to cancel the wash cycle if the "Add a Garment" light is not illuminated. THIS IS A BIGGIE HERE (Wait for the water to drain. The door unlocks once enough water has drained to enable you to safely open the washer door NOW IF THESE STILL DO NOT WORK THEN HERE IS HOW TO MANUALLY OPEN THE DOOR
    UNPLUG THE MACHINE
    Remove the three screws securing the lower toe panel to the washing machine. The lower toe panel is the small rectangular panel underneath the washer's front door. Pull the panel off the washer once the three screws are removed.Reach up into the front panel of the washer. Feel for the teardrop-shaped tab in the washer's door latch assembly.Pull down on the tab until you hear a click. The click is the sound of the door unlocking.
    May 17, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    Door locked.... tried to unplug and cancel button - still not open??
    Try holding end cycle button for 30 seconds if no. Then try reset process Press "Pause/Cancel" two times to cancel the cycle. Press "Drain/Spin" if there is water in the tub. Unplug the or disconnect power for two minutes, then plug the washer back in or reconnect power.If no then here is the manual open process. Unplug the power cord of the washer from the outlet. Locate the toe panel. This is the section of metal at the bottom of the front of the washer, directly below the door. Remove the three screws on the bottom flange of the toe panel, which connect it to the washer. Lift the panel slightly and pull it forward to remove. Manually unlock door Reach up inside the front panel and locate the door latch assembly on the right side of door.Feel for a tear-drop shaped tab on the bottom of the door latch assembly. This tab will manually unlock the door.Gently pull down on tab about 1/4 inch or until you hear a click. The door should open.
    Dec 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
    SWFT71 washer door not opening
    Two things to try. First cycle through the cycles a few times and see if it will unlock. If that doesn't work, then unplug the machine for a couple of minutes and try cycling through again. If that still doesn't work, then try pounding a little on the machine and rocking it to try and loosen the lock. If that still fails, then you will need to remove the outer paneling of the machine and get to the door/lock from the inside of the machine and get it unlocked. If you are uncomfortable with any of these suggestions, then let someone who is mechanically and electrically inclined work on the unit. Let me know how this works out for you. Benjamin
    Dec 03, 2009 | Speed Queen Washing Machines
    Door popped open and now is locked and will not unlock
    Sometimes unplugging it for a few minutes will cause it to reset itself. Also, if that doesn't work, when the power is back on, try pressing and holding the power switch for about 30 seconds.
    May 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
    Control lock light will not go off.
    Do you have any error codes?
    If water remains in the washer after the final spin, then the door will not unlock. Drain/Spin or Spin Only to remove any remaining water from the washer. The door should unlock at the end of the cycle.
    If Pause/Cancel does not work:
    1. Unplug washer or disconnect power for one minute.
    2. Plug in washer or reconnect power.
    3. Re-select the cycle and press Start.
    NOTE: If the error remains on the display, call for service.
    Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Affinity front load #ATF6000ES
    The latch may just be stuck. Try pressing in on the door at or near the latch point and start then pause / cancel a cycle (while still pressing inward).
    if that fails, put the washer through a spin/drain only cycle and let it run through( no need to press on the door).
    If you are still unable to unlock the door you will have to call for service.
    Jul 28, 2008 | Frigidaire ATF6000ES Front Load Washer
    Washing Machines Logo
    56 people viewed this question
    Top LG Washing Machines Experts
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
    Are you a LG Washing Machine Expert? Answer questions, earn points and help others
