Question about Hotpoint Dishwashers
I have a hotpoint dishwasher model number HDA 460-03 AD and is dialed controlled when I turn the dial nothing turns on. no water no sound no nothing just a click. What could be wrong with this unit?\r\nCould it be the motor and how can I check that?
  • 833 Answers
SOURCE: Hotpoint dishwasher full of water after cycle complete
If the motor is running, the diverter solenoid valve is probably not functioning. It is attached to the pump. With the power off, take the solenoid apart and remove whatever is jamming it. Toothpicks are a favorite as are any large food particle. It may also be bad. Not the problem...you may have a defective timer or your outlet hose is clogged or kinked.
Posted on Feb 10, 2008
  • 93 Answers
SOURCE: Premature drain on Hotpoint HDA 3400 dishwasher
hello my name is gilles the problem you have their is something stuck in your drain valve causing the valve to stay open remove the valve clean out reintall every thing should be fine thanks
Posted on Mar 15, 2009
  • 58 Answers
SOURCE: I need the user manual for a HDA-465-01 Hotpoint
follow this link...
http://genet.geappliances.com/DocSearch/pdf/39-51481.PDF
Posted on Jun 21, 2009
  • 351 Answers
SOURCE: Problem with candy dishwasher model CSF 456M.
hi it may need a new inlet valve,can you hear a humming sound when its due to fill.or is it doing nothing.if its not humming change the valve,also these dishwashers are well known for overheating and sticking on cycle.
Posted on Jun 02, 2010
  • 244 Answers
SOURCE: I have a hotpoint HDA 3700 dishwasher that is
Make sure your water temperature is hot enough to dissolve the detergent, because the unrinsed residue could be undissolved detergent. If, however, it's food residue, you probably need to check your sprayer arms. The upper arm attaches to a tube in the back of the dishwasher. If the support clamps come loose, the upper spray tube will not be flush with the tube and can't carry water to the sprayer arms. Also the sprayer arms can become clogged with paper remnants, bone fragments, or pieces of peeling. You'll need to remove the sprayer arm and flush it at your sink. If there is a jet that is clogged, tweezers will help remove the residue.
Finally, the bottom of the door INSIDE the washer often get covered with gunk. Be sure and gently wash the bottom of the door INSIDE. You can open the door, spray some window cleaner on the bottom and then gently brush away the 'gunk.' Rinse with hot water from a pitcher or your sink sprayer and this can eliminate some of the residue that is showing on your dishes.
I hope this helps. If it does, please come back to Fixya and rate my answer.
Posted on Jun 10, 2011
Dishwasher stays on, no water going in and dial not turning. Thank you.
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
heatman101
Mar 08, 2011 | Hotpoint Dishwashers
I'm trying to find out info on Hotpoint dishwasher catalog # 40mc20
That number is not a factory Hotpoint model number, you need to get the Hotpoint model number, which starts with #HDA*******(example#HDA1100NWH) then go to www.hotpoint.com and you will find info on the dishwashers.
GOOD LUCK !
Aug 09, 2010 | Hotpoint Dishwashers
Jun 01, 2010 | Dishwashers
Not draining and washer arm not spinning
Have you cleaned the drain filter? The symptoms you describe indicate that the filter are totally clogged.
Cleaning filters should be done every other week to maintain good function in dishwashers, it is not uncommon people forget that.
You access the filter by removing the perforated stainless steel plate at the floor of the washer tub, usually there is a round plastic knob in the middle that you turn counter-clockwise then lift it up. Underneath this plate you will find the main filter, take it out and clean with a soft brush under running water.
May 24, 2009 | Hotpoint 24 in. HDA2130Z Built-in...
GE Dishwasher not working...
Sounds like you have a one of four possible issues. More info to diagnose would be helpful. (age, which mid cycle) If the motor runs when you turn the timer dial than it is a belt/motor pump issue. If the motor does not run than a bad motor start switch or the water level switch. More than likely the motor/pump assembly as this is usually the problem on these models. If newer check with whirlpool the manufacturer to see if it is covered by warranty.
Nov 06, 2008 | KitchenAid 24 in. KUDI01TJ - Multiple...
Dishwasher
if you say it washes it may be confused with the drain pump running all the time
if this the case the machine may have a flood switch in base of machine this means that the machine has flooded or has a leak so you need to pull machine out take outsied and check for leaks
Feb 24, 2008 | Hotpoint 24 in. HDA2000Z Built-in...
Dishwasher not washing
sounds like the wash pump (wich recirculates the water during wash) has something stuck in the impelor or the wash pump motor is faulty. someone qualified would have to check this for you
Feb 18, 2008 | Dishwashers
Feb 10, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Hotpoint fdw20p dishwasher
You need the control panel to reset before anything else can happen. To do this TURN OFF THE PLUG SOCKET FIRST AND UNPLUG. Then you need to drain ALL the water from the machine. Turn off the water supply feed and place the wastage pipe as low to the floor as poss ( 1-2" off floor). Water will gush out so use a large shallow tray and keep emptying the tray. Tilt the dishwasher over slightly to make sure all the water is out.
This will allow the control panel to reset itself which wouldn't normally happen if the base of the dishwasher was holding even a small amount of water.
Re connect the water, plug back in , select the RESET setting on the dial and close the door and switch on.
Leave for about 20 seconds and then turn off.
Rotate the selector switch to "A" Intensive wash and switch
I found this on another site and it really did work for me
Dec 12, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Dishwashers Logo
117 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
