Question about Cozy Enclosed Front Console Heater 70,000 btuh Natural Gas
I have a cozy gas heater in my converted garage, and it won't stay lit any longer. I light it, but by the next morning the pilot is out and the room is cold. What part would I need to fix it? Thank you,
  • 59 Answers
If you can re-light the unit all parts are good,if the vent pipe is ran thru the side wall and up this is the problem the vent temps on these unit are low which can not over come the cold air and can not start a draw ans backs into the unit and puts out the pilot.
Posted on Oct 22, 2010
I've got good flame replaced Powerpile pilot won&#t stay lit
The flame sensor is not producing enough volts to hold the gas valve open for the pilot light. Make sure the SIDE of the pilot flame is touching the sensor. If it in engulfed by the flame it won't work right.
Jan 01, 2016 | Cozy Heating & Cooling
I AM WORKING ON A COZY W501E WALL FURNACE AND CANT GET THE PILOT TO STAY LIT. i HAVE CHANGED THE GAS VALVE, THERMOCOUPLE,AND THE SENSOR FOR THE HIGH LIMIT. THE PILOT WONT STAY LIT.
Pretty much the only thing that will do that is the thermocouple not generating enough voltage for the valve to say it's OK.
Usually you need to hold the button for pilot lighting for 60 seconds. You can use a meter to check that it's generating enough power. The thermocouple has to be in the pilot flame properly.
Check this video:
https://www.youtube.com/watch?v=suen7QlJl4o
Gas furnace will not light Thermocouple test with the multimeter
Or see this site:
How to Test Thermocouple with Multi Meter Heating and Cooling
Feb 11, 2015 | Cozy Heating & Cooling
Pilot light won't stay lit on new water heater
1) Get more air to the water heater and see if problem continues.
2) Read the following pdf-s for things that might apply to your situation.
http://waterheatertimer.org/images/Negative-pressure.jpg
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
3) Read pdfs above first, and then Add a comment with missing information below, for possible do-it-yourself help.
Does this water heater have a blower?
Is gas valve electronic? Or does gas valve have a dial?
If gas valve is electronic, have you checked outlet with circuit analyzer?
Did pilot light work correctly for a while? If so how long?
Where is water heater located? Hot attic? Closet? Garage? Is area dirty and dusty? Has air intake been cleaned?
What color is pilot flame? Clear blue or yellow-or-orange?
Have you inspected inside of combustion chamber for dripping water?
Aug 28, 2011 | American Standard 40 G Natural Gas Water...
Pilot wont stay lit
Hi, On a milivolt unit that has a thermocouple and standing pilot works on the basis of heating the bulb which produces a very small amount of electricity called milivolts. This is what generates these volts to keep the pilot on. Make sure it is tight at the gas valve, posistioned into a nice blue flame with a small yellowish tip. If it continues to drop out, you have a faulty gas valve and it must be replaced. You may want to compare the price of the valve to another unit, you can take model and serial #bers from the unit and the valve and compare prices.No one likes to hear this, but this is the problem if all else I have asked you to double check are good.Please let me no the out come. Good Luck, Sincerely,
Shastalaker7
Dec 08, 2009 | Cozy (W352E) Heater
My honeywell gas suspended garage heater will not come on when the t'stat calls for heat. It is a heat only unit and neither the fan nor the blower motor will come on. The Heater is getting power to it...
The pilot light has to be lit before gas valve will operate. That's a safety feature so the valve won't open and fill the garage with gas and possibly cause an explosion or fire. If you have a standing pilot and can't get pilot to stay lit, it's usually the thermocouple and it will need to be replaced. Once the pilot is lit, the gas valve comes on and heats the combustion chamber up to approx. 100° to 125° a thermostat controlled fan switch will close and bring the blower on.
Sep 08, 2009 | Mr. Heater Suspended Garage Heater
Cozy gravity one sided wall heater...pilot won't
how by extending the duct work will it make the gas valve work ?
if the pilotkeeps going out clean pilot jet , or if the power unit has gone in the gas valve then you would have to change the valve , don't get the flue bit ?
Feb 20, 2009 | Cozy (W352E) Heater
Cozy heater
That piece that fell out is probably the pilot orifice. It goes on the end of the pilot gas line when you screw it into the pilot assembly. Don't try to light the heater without the orifice. If your thermocouple is good and the pilot flame is set properly, the control valve could be bad. Be sure to hold the knob down for 60 seconds before releasing it.
Nov 08, 2008 | Cozy Enclosed Front Console Heater 70,000...
Cozy furnace
The pilot orifice could be dirty causing the pilot flame to be too small. Unscrew the pilot tube at the pilot assembly. The orifice is inside. Remove the orifice and blow it out with compressed air only. Reassemble and see if that fixes the problem. If the pilot flame is set too low, sometimes opening a door will cause a draft to blow out the pilot. If the thermocouple is good and the pilot flame is set properly, the control valve may be bad.
Oct 22, 2008 | Cozy Enclosed Front Console Heater 70,000...
Cozy Enclosed Front Console Heater 70,000 btuh Natural Gas Logo
135 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
