Question about Hardware & Accessories
How can I get the programming instructions for the Utilitech Wall Digital Timer Model #LW60418?
Utilitec LW60418 is same as 0141224
See How to install and program Utilitec LW60418
Posted on Oct 05, 2010
Utilitech TM-029 wall timer: I've installed the
Do not run any timer warm... replace with switch, and/or buy another timer.
Copy following link to identify timer and download instructions:
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
This timer is rated 15 amp 1875 watts.
Safe maximum is always 80% rating plate: is 12 amp and 1440 watts.
Add up total watts on circuit.
Add a comment and say what you discover.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Jun 29, 2013 | Hardware & Accessories
Pushed reset button and will not respond. Red on light stays on
11/6/12
Copy following link for Utilitec LW60418 timer.
Same as Westek TMDW10, and Stanley 30418
This timer is reset with one-button.
Unlike some timers that require 2 button push.
Push in reset button firmly with paper clip, and hold for several seconds. Repeat.
This action will clear timer memory.
If reset does not restore functionality, then timer could be bad.
This timer has 1 year limited warranty.
Suggest buying new timer at Lowes, and returning defect timer in new package.
Nov 05, 2012 | Intermatic Inc. ST01C Digital In-Wall...
Utilitech wall timer LW60418 -- cannot get it to go into automatic mode
Reset timer using reset button, and then try again.
If timer is defective, then buy another one at Lowes and return defect in new package.
Open following link for timer wiring and programming instructions:
Jun 23, 2012 | Hardware & Accessories
I have a Utilitech In Wall Digital Timer Lowes Item #: 141224 | Model #: LW60418, purchased from Lowes. I've lost the instructions and can't figure out how to set the timer after a power...
Open following link for Utilitec timer manual:
This timer should have a back-up capacitor so that programming is kept in memory during power outage.
Power outage is known cause of timer failure. When power turns on, the surge knocks out electronics.
People writing to fixya report electronic timers and electronic water heater controls stop working after power outage. Probably many other electronic devices are affected too, but that would be out of my specialty.
Troubleshoot says 'in case of operational failure, press reset button to clear all settings and restart.'
If timer has failed, buy another from Lowes and return defect in new package.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 11, 2011 | Intermatic Inc. ST01C Digital In-Wall...
INSTRUCTIONS FOR UTILITECH SELF-ADJUSTING WALL TIMER MAKE NO SENSE! iNSTALLED, BUT HAVE TO TURN PORCH LIGHT ON MANUALLY EACH DAY; ALSO COMES ON SOMETIMES IN THE MIDDLE OF THE NIGHT! HELP!
1) Sounds like you have timer wired correctly.
The wiring is confusing for many people, so it's apparent you're a quality electrician.
2) There are no repairs for defective timer, but timer can be reset using reset button.
Reset will clear program conflicts and overlaps that cause timer not to operate as expected.
3) Model number of Utilitec timer is not given, so expert has to guess which fork in the road you want to choose.
4) If you have 0192773 timer and want do-it-yourself solution, open following link for larger print and photo illustrations that make programming easier.
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
5) If you have 0141224 timer, then open following link for larger print instructions.
6) At any point, you can add a comment and ask very specific question about any part of the instructions for either in-wall Utilitec timer, or any Utilitec timer, or ask a question about almost any 60Hz timer on the market today.
That comment sends an e-mail, and then I will respond.
I have tested both Utilitec in-wall timers.
Aug 31, 2011 | Hardware & Accessories
I put in a Utilitech 01411224 timer.Can the timer be set to come on at 9;00pm off at 6;00 am each day? Do you need to hook up the ground?
Open following link for programming and wiring instructions:
Yes, the timer can be programmed to turn on at 6am and off at 9pm all days of week.
The ground is not necessary for timer to function, however other wiring has to be correct, and white wire connects to neutral, black wire connects to Hot, and red wire connects to wire going to switch.
Timer replaces single-pole light switch only and cannot be used for 3-way switching.
Jul 19, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Is it possible to set this model(LW60418), for turn on/off at sunset /sunrise? Ron, Weymouth, Ma.
No, Utilitec LW60418 timer is not made for astronomic dusk-to-dawn operation.
However Utilitec LW60419 / 0192773 is made for astronomic operation.
Following link shows timer, manual, and wiring instructions:
http://waterheatertimer.org/Program-wire-Utilitec-LW60419.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Dec 18, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Hardware & Accessories Logo
817 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
