Question about Maytag Neptune FAV6800AW Top Load Washer
What does it mean when the signal light is lit and it keeps beeping? Do we need to do a repair or maintenance. Once when the signal light was on and it was beeping, the washer was open and the spin light was on too.
  • 526 Answers
This could be a Control Board issue or a Console Ribbon cable connection to the Control Board socket.
Re-powering the machine will probably not clear the issue. If a repair company is called make sure the bring out a Control Board and Console for your FAV9600A .
If was an issue with my machine I would check the ribbon connection from the Console to the mating socket on the Control Board. I'll see if I can post a pic...........Rich What does it mean when the signal light is lit and - 07bf898.jpg
Posted on Oct 09, 2010
Have new headset, why is the base unit keep beeping at me
Here is an explanation of the beeps you are hearing:
• One beep every 10 seconds is caused by a low battery
warning. Recharge battery by returning it to the base charge
cradle for one to three hours until charge light stays lit or
quits blinking.
• Two beeps is an out of range warning. Move closer to the base.
• Three rapid beeps every 30 seconds indicates your mute is
on. Press the mute button once to turn mute off.
• When an optional lifter is connected, three repetitive beeps
indicate a call is coming into the headset. Press the call
control button on the headset to answer the call.
Plantronics CS70 User's Guide
Good luck from Headsets Direct!
May 19, 2011 | Plantronics CS70 Wireless Headset
I put a new proccessor in to my acer desktop and it turns on but i get no signal on my monitor and the cd drive beeps once every 10 seconds and the hard drive light is at first lit up and then it goes...
hi there tommy,hmm you may need a new installation of windows(or whatever Operating system you may be running on your system),let me know if you have fixed your issue elsehow..
Regards, Finphillips
Please rate me
Dec 22, 2010 | Acer Aspire™ T180 PC Desktop
Unable to power on computer
When you here this signal sound beeping this is an RAM memory error. Try to open your CPU casing and remove the RAM, clean the RAM with rubber eraser.
After that insert the RAM and try to turn on the unit. Once you can hear again the loud sound beeping the RAM are bad or faulty already. So you need to replace the RAM.
Jul 25, 2010 | HP Compaq d530 SFF PC Desktop
As i switch the ps3 on it beeps to come on and then it beeps to flash amber then switches itself to red. It has been an ongoing problem
PS3 amber light flashes with beeps means your PS3 had hardware errors and need some maintenance. Do you know, send back to game shop is too expensive and waste your time. Learn the correct repair skills and fix it by yourself is the ultimate method. Here is the repair guide for you to learn :
DIY PS3 Repair Guide
Not only such amber light flashing problem, you can repair other red and yellow light related issues as well.After you purchased the product, you will be guided to the step-by-step videos and ebooks for you to work with.
Jul 19, 2010 | Sony Playstation 3 (PS3) Console
Hello I saw the break alert light lit on my
Usually when th fluid level low light comes on, it is because the fluid is ging to the front calipers to fill the pistons that push the brake pads against the rotors. This is because the pads are worn down and probably need replacing.
As for the 3 beeps, it is not related to the brakes.
if it is 5 beeps, it is the air bag or pretensioner.
When the ignition is cycled (turned off and then on), the air bag indicator will remain lit for six seconds and then go out. If an SRS fault exists, the air bag indicator will then flash the two-digit LFC. The air bag indicator will flash the LFC five times, then it will remain illuminated for the rest of the key cycle. The RCM will also communicate the current and historical DTCs through the data link connector (DLC), using the scan tool. If the air bag indicator does not function, and the system detects a fault condition, the RCM will signal the GEM to activate an audible chime. The chime is a series of five sets of five tone bursts. If the chime is heard, the SRS and the air bag indicator require repair.
Mar 02, 2010 | 2002 Ford Ranger Regular Cab
The dryer won't run. Dry, extra dry, and coold down process lights are lit.
Hi, the lights are signaling a control fault the is concerning the logic sector of the control board/timer. you will need to make sure that the wiring harness is connected to all points and it should be in good condition. if there are no apparent issue with the wiring harness, replace the control.
May 29, 2009 | Fisher and Paykel DEGX1 Electric Dryer
No signal to monitor / Beeping
Listen to the pattern of beeps, or look at the back of the computer to see the pattern of the diagnostic lights ( 4 lights just under the keyboard/mouse connectors) and check out this site to see what they mean:
Beep Code Meanings
Diagnostic Light Meanings
May 29, 2009 | Dell OptiPlex 160L (160LMIN) PC Desktop
Power On / No Boot
Is it POSTing? Do parts make noise and then theres a Beep? The beep means it finished the Power On Self Test. Once it posts then it will show splash screen or black screen with it testing hard drives disk drives etc.. If no post is the led lit that says A/C is connected? before you attempt to turn on? If no post and good ac to rear connector then you probably need a new motherboard.
James Mac
Aug 31, 2008 | Acer TravelMate 2300 Notebook
Maytag Neptune FAV6800AW Top Load Washer Logo
32 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
