Question about Amana ARB8057CSL Bottom Freezer Refrigerator
Hi my botton frezer no working the compressor its hot
  • 316 Answers
Compressors are normally 100-120 degrees when being cooled by a condenser fan motor. If there is no fan motor near the compressor then it can run up to 180 degrees, so the compressor temp by itself doesnt mean much. You can take an ampmeter and clamp it around one of the wires to the compressor to see if it is running, drawing anywhere from 1-2.5 amps or trying to start, in which case it may draw up to 20 amps every 3-5 minutes.
Posted on Oct 05, 2010
Ref/ and frezer not cooling. Hot Point
Check for power to unit by unplugging and plug lamp into outlet to see if you have power. If running it is possible it is stuck in defrost mode if you can locate the defrost timer take screwdriver and advance timing knob until you hear click and compressor should start. If this works you will have to replace timer and probably heaters and thermostat. The next worse problem is bad compressor.
Jul 14, 2017 | Refrigerators
Kenmore sidebyside 53552200 stoped cooling and defrosted completly light still works both frezer and refrigerator not getting cold
It could be stuck in defrost. Check your defrost heater, and see, if it is still hot. If it is, then the defrost timer is stuck. When it goes into defrost, everything, stops working, but the defrost heater and light. As long, as the defrost timer is on, nothing else will work, as far as the compressor, freezer fan, and any cooling/freezing.
Sep 07, 2014 | Kenmore Refrigerators
Frezer works not frig
Contact a professional to check if there are any restrictions between the freezer and refrigerator unit. The freezer should drop cool air into the refrigerator portion to help cool it down. Is the compressor running and do you feel it being hot?
Aug 06, 2012 | Frigidaire FRT17G4B Top Freezer...
MOTOR IS RUNNING BUT NOT GETTING COLD
you say motor do you mean the compressor, if so is it making any heat if so it says it is trying to work. common problem if so is a frost build up in frezer on back panel keeping cold air to circulate to refrig. from freezer. also check to see if freezer blower fan blowing air. back to compressor, it has large return line should be cold and a smaller high side line usually 1/4 inch and this should be hot if compressor is doing it's job.check cooling motor by compreesor also to much heat will shut it off.
Nov 08, 2010 | Refrigerators
WAS WORKINIG FINE NIGHT BEFORE WOKE TO IT NOT WORKING FRIDGE AND FREZER BOTH I DID HERE THE FREZER FAN RUNNING STILL. THE COMPRESSOR TRIES TO GO ON BUT SHUTS OFF RIGHT AWAY.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 31, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Hey guys, fridge went warm, frezer fan is on- think it is the relay. would top of compressor still be hot?
heatman101
Aug 26, 2010 | Refrigerators
Compressor not working warm fan inside frezer run
Heat exchanger was iced over, took a hair dryer and melted ice. I think defrost heater element is bad will check it this week end. I put a new computer in the frige about 3 mounths ago and will check if it has gone bad. The compressor is working fine.
Jun 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frezer not freezin fridge not cooling
try to change the clickson and relay on the compressor and if it still doing that there are two problems to look for or a blokage in the system or the compressor are broken
May 13, 2009 | Maytag Appliances Magic Chef 18 cu. ft....
Burning Smell
Keep it unplugged and look for burned wires, or rubber wires hardened from extreme heat. This will be a good start in finding what is going wrong. One more thing to check is if the compressor is heating up after running for a while. Let it run for 20 min or so, shut off the power and feel the compressor. Is it hot?
Jan 12, 2008 | Frigidaire 14 cu. ft. / 396 liter Upright...
Amana ARB8057CSL Bottom Freezer Refrigerator Logo
132 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
