Question about ASUS M2N68-AM SE2 Motherboard
I bought a barebones kit that has this motherboard. When I power it on, the system trys to turn on for about 5 seconds then the whole system shuts down. I called Asus support, they had me remove the cpu and power up the motherboard and same thing happened. They said the motherboard was bed. I bought another motherboard and installed it and have the same problem, runs for 5 seconds and shuts down. What could be causing this issue? Two bad motherboards?
  • Charles Parker Oct 05, 2010
    Its Asus M2N68-AM Plus Motherboard w AMD Phenom FX 64 and X2 64
    President:
  • 1,768 Answers
This could be a cmos battery or you need a bios update.
You will possibly need to call the manufacturer or go to the site and see if there is a bios update.
The cmos battery possibly needs to be replaced if this doesn't work then you will need to get a new board. This board is defective and if this is your second board then go to another manufacturer.
Posted on Oct 05, 2010
  • cicak_poyo Nov 20, 2010
    try to change new power supply.. because you have change the motherboard (including battery and bios) still not working.. or you can try your processor to another CPU, still not working mean your processor is not correct function...
My Shuttle Barebone K48 will not even power on.
Try to run it with only one stick of memory in at a time. If the memory doesn't work the computer won't even go into the POST. It only takes one failed stick to stop a computer.
Mar 07, 2012 | Shuttle KPC K48 Barebone
Resets by itself
This might be an error / fault, somewhere at the motherboard. I myself have bought 2 identical new systems years ago. They are exact copies of each other, but one started (especially when wintertime was comming) started to reboot without any indication or warning. Sometimes it happened at booting (still black DOS-screen), sometimes when Windows XP was running a few seconds, or even later. However, after 1 reboot it seldom happened the computer would reboot again.
I've swapped all components piece by piece, and noted the problem was located at the motherboard.
So far I couldn't pinpoint the exact source of the problem, but I'm 100% confident it's an electronic component-failure problem. I think it might be a thermal problem at the PCB, something like a loose contact. Maybe something like this, together with bad caps or malfuntion of MOSFETS. But it's definitly something at components-level.
Jan 19, 2012 | Shuttle XPC Glamor SG31G2 (SG31-G2-BK-V2)...
How do test my power supply?
Here is a link to a site that really covers power supplies quite thoroughly.
http://www.motherboards.org/articles/guides/1487_6.html
Sep 29, 2011 | Shuttle SN78SH7 Ultra Barebone Kit ...
System shuts off within seconds of turning on and fan starts
Motherboards are designed so that holding in the power button for 4-5 seconds shuts the system off. The On/Off key getting stuck or something shorting the pins on the motherboard that the On/Off switch is connected to can cause this behavior.
Open the case and remove the little two wire connector (usually one red and one black wire) that runs from the motherboard to the front panel switch. Then carefully touch both the pins on the motherboard at the same time with something made of metal such as a paperclip or small screwdriver, remove it as soon as the computer starts to power up. If it still shuts off, you probably have a motherboard malfunction. If it starts normally, the switch needs to be replaced/repaired.
Aug 21, 2011 | Audio Players & Recorders
Bought 2 Jetway barebones system from newegg... they both have the JNC98-525E-LF motherboard... one works perfectly... the other resets regularly every 10 seconds... tried different RAM, no HDD etc......
Swapping power supplies is always a good test. If you can't switch the supplies between the systems, then you'll need to swap the motherboards as you said. From your description, it does sound like one of them is flaky. But since the thing's under warranty, why not just send it back and save the effort? You'll wind up doing that anyway.
Jun 25, 2011 | Jetway JNC98-525E-LF Intel Atom D525...
Asus A7V600_X Motherboard
do you have a jumper on it set to master? Do you have the right cord? Is it pluged in right?
Oct 01, 2009 | ASUS A7V600-X Barebone Kit / ATX Mid-Tower...
Can I buy just a motherboard for an hu 61
you can buy replacement motherboards for you HU61 you have to look for a mini itx board. you can check on the net for mini itx boards.
Aug 06, 2009 | AMD FIC Ice Cube HU61 Athlon 64 Small Form...
Backup server won't boot up
Is it USB or SATA drive? In the BIOS there is an option to allow USB boot device.
Jan 15, 2009 | ASUS K8V SE Deluxe Barebone Kit / ATX...
Barebones troubleshooting
Lex -
I would first check your ram, make sure its the right type and rating for the motherboard. Although most systems will beep at post for a memory issue, sometimes reseating the memory alone can clear up a startup hang.
If the memory is seated okay, the right type and speed rating, try using a different video card in the system. Its possible that the system is starting up normally, but not being displayed.
If neither of those help, minimize the system. Plug in just the bare minimum needed for operation - Power supply, processor, heat sink & fan, a single memory stick, a single hard drive, video card(if its not integrated on the motherboard). Plug in a monitor and the power cord, then see if the system boots.
If all that still fails, verify that the CPU fan AND the Power Supply fan are spinning when power is on. If so, this points to either a bad memory stick(try another), bad processor(if available, try one at a slower or faster speed), or bad motherboard.
Hope this helps!
-thinstatic
Jun 13, 2008 | MSI MBOX KM4M-L (ms-6734bb-040) Barebone
Samsung PC J5225 shuts down after 3 - 5 seconds
It sounds like the tv power supply has problems. you probably should call a service center about a repair.
there are "safety" features built in to any tv with a "crt" type of screen that will not allow the tv to run when there is a problem.
Oct 20, 2007 | Samsung PCJ522R 52" Rear Projection...
ASUS M2N68-AM SE2 Motherboard Logo
173 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
