Question about LG DLE3777 Electric Dryer
MY LG DLE5977W at first would have trouble turning the drum. If I gave it a "push" (manually turned the drum from the inside, about half a turn), and then started the dryer, it would run normally. This continued for a few weeks, and last night it just stopped working altogether. I'd turn it on, and after a few seconds it would shut off automatically. There was a burning smell (not electrical, more like hot clothes) from the inside of the dryer. I cleaned it all out and made sure the lint was removed from the inside of the dryer (even removed the drum) and when I try to use it, it will continue to turn off after a few rotations of the drum. The "cooling" light is on as well. No error codes were generated during a diagnostic test.
SOURCE: Dryer won't work, Check Filter light is on
I had exactly the same problem with my newish LG dryer. I deduced that the dryer's computer essentially needed to be rebooted. I pulled the plug for a minute or so, then plugged it back in. It works perfectly now.
Posted on May 06, 2007
  • 1028 Answers
SOURCE: frigidaire electric dryer; model # FDEB34RGS1
front drum seal needs replacing pop clips at front of dryer top ..lift top remove 1 secrew each side of front from the inside..remove wires lift panel off clips ckd front panel around door area for felt seal may also have embedded plastic drum glides a felt seal also goes around bottom half
Posted on May 06, 2008
aborcass
  • 2651 Answers
SOURCE: Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Posted on Nov 16, 2008
  • 6 Answers
SOURCE: LG Gas dryer doesn't dry clothes in one cycle
Have you checked your outside vent while it was running to see if the dryer was venting 100%. If your clothes are hot and humid I would say clean your vent pipe has a blockage and needs to be cleaned out. Also as far as the burning smell you could take the front off (unplug first) the dryer of by removing 4 screws one above and one below the latch and two at the bottom and there are two clips one at the top left and right push in with a puddy knife and lift the top up a couple inches and lift the front up off the bottom holders. Then you will have access to vacuuming the lint that is floating around the burner.
Posted on Dec 28, 2008
  • 496 Answers
SOURCE: LG DLE2514w electric dryer has loud thud every turn
Most model dryers are supported at thge rear of the drum with a bearing configuration, but usually the front of the drum is supported by some lining pads or guides. These help hold the rotation of the drum concentric. It sounds like your drum is not spinning concentric. My guess would be that some new guides might need to be installed.
Hope this helps...
Posted on Sep 02, 2009
My LG DLG2526W gas dryer wont start
I had a problem like this and our fix was to reach in and turn the drum a half a turn and push the start button. it worked for us because the motor had a dead spot on motor and once moved pass that spot, it did its job. you may have a different problem but, try it.
Sep 03, 2014 | LG DLG2526W Gas Dryer
My lg tromm dle5977w dryer check filter light stays on and drum wont turn just makes humming noise
If the drum will not rotate then the drive belt is broken and should be replaced
May 26, 2014 | Dryers
Dryer drum needs several manual pushes to start
or just a bad belt cheap but labor intensive
http://www.youtube.com/watch?v=7OVBi0LcrzQ
Apr 29, 2013 | LG DLE2532W Electric Dryer
Dryer makes loud humming noise but drum doesn't turn when I push start.
Check to see if the drum will turn by hand. If so, leave the door open but push the light switch button down and start the unit. Once you hear the humming sound, manually turn the drum with your hand to start. If the drum turns normally, you have a bad motor and needs to be replaced. If the drum does not turn, something is jamming the motor and needs to be disassembled and inspected.
Good luck
Oct 03, 2010 | LG DLE2514 Electric Dryer
Drum won't turn-belt is good-motor
If you can manually turn the drum, the motor's start windings may be bad.
If you can't get the drum to move, check to see if a sock or other small item is stuck between the drum and the inside of the front of the dryer. If you see nothing, it's possible that one or more of the four drum rollers is/are seized.
Jul 15, 2010 | LG DLE2532W Electric Dryer
LG DLE5977W electric dryer hums when attempting to restart
This is usually the motor but not always. Remove the belt. Check for obstructions in the blower fan housing. Manually rotate the shaft of the motor.
If the motor is very stiff, or impossible to rotate manually, and the blower fan housing is clear, you need to replace the motor. If the motor rotates freely, run the motor momentarily with the belt removed and the blower in place. If the motor runs fine with the belt removed, there may be a problem with the idler pulley or the clothes drum. Try to rotate the drum by hand. If it is very difficult to move, correct any problem with the rollers, pulley, rear bearing, then reassemble the dryer and try it again. If the motor hums but doesn't rotate on its own even with the belt removed--yet you can turn it freely by hand--you usually need to replace the motor or the motor start capacitor. You can also enter your model # for diagrams and illustrations at www.appliancehelponline.com
Mar 31, 2010 | LG DLE5977 Electric Dryer
Dryer drum does not turn
look on The back of the dryer. If their isn't a removeable back panel then lay dryer down and look inside for the belt or pulleys. One or both are probably bad.
Jan 01, 2010 | LG Dryers
Dryer DLE5977W washer WM2277HW just bought used ones no operating manuals help need one for each piece where do i get them
Follow the links below with Internet Explorer ONLY, opening these files may require the free download of additional software for viewing:
WM2277W Then Click on English Manual
DLE5977W Then Click on English Manual
Aug 28, 2009 | LG DLE5977 Electric Dryer
ELECTRIC XL LOAD CAP DLE5977W
You gave me the best info to let my repair man know the problem. I cannot get to the belt and have been told it is a pretty big job and my dryer is still under warranty..so they are fixing it for me this week. Thank you for the information, it was helpful.
May 02, 2009 | LG Dryers
LG DLE3777 Electric Dryer Logo
97 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
