Question about Microwave Ovens
We have a Jenn Air over the range microwave oven bought in 2002; the turntable no longer spins. What can we do to fix it?
  • 5,911 Answers
If the oven is still heating, but the carousel isn't turning, this problem is commonly attributed to a turntable motor that has worn out and may need to be replaced. The motor is attached to the center plastic piece (called a turntable shaft, turntable ring or coupler) under the middle of the glass tray. The following link explains how to access and replace the motor:
http://www.fixya.com/support/r3555716-replacing_a_turntable_motor_on_a_microwa
This is a very simple repair, that usually is not expensive. The price will be determined by the model and manufacturer. This repair can also be performed on an over the range model microwave oven WITHOUT uninstalling it.
You can refer to any of the following websites for comparison:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites listed have helpful exploded view parts diagrams to assist you with locating and properly identifying the part(s) you may need.
The average price for a motor is about $35 to $45. If your model number is not listed at all the sites, use the part numbers from the Sears site and use them for your search criteria. The model numbers don't always cross reference, but the part numbers do. If you need assistance identifying the correct part number, please post back with your complete MODEL NUMBER and I can assist you. I hope you find this information helpful.
NOTE: Even though the carousel may not be turning, you can still use the microwave while awaiting parts. You will need to physically rotate whatever you are heating about midway through the cook time to ensure even heating. Early model microwave ovens were not equipped with a rotating carousel and this was the common routine.
Posted on Oct 05, 2010
Turntable motor replacement in a jmw3430ws
The turntable motor is accessible underneath the oven. You may be able to purchase a replacement directly from Jenn-Air or an appliance parts supplier.
May 01, 2014 | Jenn-Air Microwave Ovens
Parts model
The parts to fix this are indeed no longer available, but if you could live without the turntable by rotating the plate halfway as needed, you may be able to replace the antenna cover as long as neither the antenna nor the cavity is damaged.
You can get a sheet of "universal waveguide material" and use the old one to trace and cut a new one. Sand the edges smooth.
It's part number 40QBP1012 and you can get it from Sears here.
If you decide to skip that and replace the oven, you can contact Jenn-Air with your model number and they'll be able to tell you if they make a "drop-in replacement model" for your oven. See Customer Care Jenn Air.
Otherwise, they can tell you the specifications.
- William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
May 04, 2017 | Jenn-Air JMC7000 Microwave Oven
GE Microwave oven turntable wont spin bushing can be tuurned freely and tray will spin when manually turned.
The turnable motor must be replaced, go to www.ebay.com Type: make and model of microwave oven, refine search to turntable motor.
May 07, 2012 | GE Profile Spacemaker Over-the-Range...
My Jenn air model JMC7010 turntable is not turning when in use. It turns very very slow if nothing on it, and It will make noise when put something on it. Can anyone help me to determine I can fix this...
Yor can Choose or Enter Your model number to make sure this fits.I looked for this for a very long time. I ordered several because it was so hard to find. I rated it a five because it fits prefect,
Amazon com NEW JENN AIR DOWNDRAFT ALUMINUM GREASE FILTER 71002111 FREE...
Feb 14, 2018 | Jenn-Air JMC7000 Microwave Oven
Microwave not heating
OK, you have two components that are faulty. the magnetron and the turntable motor as well. replacing these two components will fix both issues.
Jun 10, 2009 | Frigidaire FMV157GM Microwave Oven
MIcrowave quit on February 15, 2008. I can't get parts to repair
seems like you have to replace the control/touch panel module of the oven.
Mar 21, 2009 | Jenn-Air JMC7000 Microwave Oven
JMV8208 BAW Model 30" Jenn-Air Convection/Micro combo
have a good look at front to see reset??.press it once it comes back on unplug from the wall and & open it up and go to the part and give it a good clean with wd40, check the push pad for ware & tare dirt gathers and builds up
Mar 09, 2009 | Jenn-Air JMV8208A Microwave Oven
Jenn Air Microwave M169W will run but not heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
zcvzcv
Jan 28, 2009 | Jenn-Air JMC7000 Microwave Oven
Sharp R-930CS Microwave
Check to see the turntable it is seated properly. Try to spin it by hand. If it moves easily, it is not in the right place.
If seating it properly does not solve the problem, you'll need to take it apart to see what the mechanical problem is caused by.
It could be as simple as a clogged gear. Or it could even be a broken gear or bad motor. A visual inspection should provide clues.
Be careful. Disconnect it from the AC before taking it apart and do not operate the microwave disassembled as microwaves are harmful to humans. It can cook them!
Mar 24, 2008 | Jenn-Air JMC7000 Microwave Oven
Turntable no longer turns
Your problem is either a weak or slipping motor or a broken / cracked turntable coupler. If the coupler turns loosely without actually engaging the motor, it is bad. If the coupler is good or looks good, it's probably the motor. One test of the motor is to firmly grab the shaft with pliers and try to gently turn it. It should turn with some resistance and make a whining sound as it turns, since it is a highly geared motor. If the motor turns very very freely - or not at all - then it is bad. You can see an exploded diagram and order parts via the Jenn-Air (Maytag) Web site at http://services.maytag.com/abs/PartsStore.do?nextPage=psstartpage You will need to enter your full model, which is apparently one of the following: JMC7000ADB JMC7000ADQ JMC7000ADW Referring to the CABINET-BASE-CAVITY diagram found there, you will see: - REF 23 motor - REF 27 coupler One of those is likely the culprit.
Dec 06, 2006 | Jenn-Air JMC7000 Microwave Oven
Microwave Ovens Logo
41 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
