Question about Coleman Roadtrip Grill LXE 9949-750
Propane will not come thru burners
Propane tank is over half full and is turned on as well as both burners. The ignition spark is visible but cannot hear fuel sound or get any flame. The last thing I did to the grill is to thoroughly clean and scrub the entire grill with soap and pressure water.
  • still hungry Jun 16, 2008
    Roadtrip Grill brand new. Attached Propane canister as instructed.Followed matchless lighting instructions. Turned on Burner to High. Did not hear propane coming through burner .
  • Anonymous Jul 25, 2008
    I would get propane coming thru for just 5-10 seconds, then it would drop off to just a minimal flame. I read the response about the air lock and it made sense. I just picked up the propane tank and shook and turned it around a bunch and now it works great. Thanks!
Most propane problems are due to a new valve on the top of the tank. It is designed to only allow a minimal flow until the line is pressured. This prevents fire flair up from broken or leaking hoses. Always turn the bottle on and wait before trying to light a burner. If the burner is on first, the propane will never come out at full flow or if you have a leak in the system, it won't pressurize sufficiently to allow full flow out of the bottle. There is never "air" in the tank.
Posted on Jan 13, 2009
I have the same sort of problem, the left burner will not burn correctly.
I cleaned the spider out of the left orfice and it works great.
It was very easy to take apart and clean all the components.
I blew out all the lines with compressed air and cleaned the jet or orfice with very little disassembly.
Less than an hour to clean and back up and BBQing.
I hope the other guys that have this same problem can see this, it will save them from buying a new grill.
Good Luck
Posted on Jun 28, 2008
Sounds like your propane tank has an air-lock(the gas is trapped in bottom of tank with air on top of it)you need to take your tank into service depot and get them to purge the tankof all the air in it.
Posted on Jun 05, 2008
  • 3 Answers
Did you check for a block in the lines, what you could try is holding the connector to the propane tank straight while tightening it on, i had the same problem with my bbq full propane tank and no propane through the burners
Posted on Jun 01, 2008
The grill is too slow when grilling. It doesn't seem to get hot enough
Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Aug 01, 2014 | The Holland Grill HGG421408LP Epic Gas...
Grill troubleshooting
It's not getting hot enough.Turn off propane. Disconnect propane tank from barbecue. Open burner valves for about 20 seconds. Close valves. Reattach propane tank. Slowly open propane tank valve. Turn on burner and ignite
Jul 31, 2014 | Holland Grill Classic II (NG)
We replaced the regulator and the grill still does not have big flame always seem to be on low despite knob adjustment
Jul 30, 2014 | KitchenAid Superba KFRS271TSS Stainless...
Cannot get and flame.see spark from starter new tank
Jul 27, 2014 | Char-Broil CharBroil 4638310 Grill
Jul 15, 2014 | Weber Grilling
Poor flame after changing tank on gas grille
Jul 05, 2014 | Weber Genesis E-310 Gas Grill
Weber spirit won't get hotter than 300. What's wrong?
Jun 19, 2014 | Weber Genesis Silver C Grill
My weber genesis E 330 thermometer never goes higher than 400 degrees F Why?
Jun 04, 2014 | Weber Genesis Silver B Grill
I have a Weber Q grill, propane tank is full but propane is not getting to burners. I do have a spark when I press the ignition. Where is it likely to be plugged up?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
You problem could be or probably is with the regulator...not enough gas pressure...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Aug 20, 2010 | Weber Q300 Grill
Coleman Roadtrip Grill LXE 9949-750 Logo
3,566 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Treefrog15
Treefrog15
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
