Question about Nuova Simonelli Premier Maxi Espresso Machine
Recently bought a used premier maxi that was working when we picked it up. after hooking it up to our water supply and turning on the water to the machine the boiler overflows and is released through the center of the machine. when i turn on the steam wand a continuous flow of water comes through. if i turn the machines electic supply on and the water line the top pressure gauges shoot right into the red zone.....
  • 5 Answers
Your machine is overfilling. You need to replace the level probe.
Posted on Feb 26, 2013
    President:
  • 1,618 Answers
Check to make sure the distribution valve is in the closed position.
Posted on Oct 06, 2010
Simonelli premier maxi gauge
I have exactly the same problem please help us
Feb 01, 2013 | Nuova Simonelli Premier Maxi Espresso...
I have a premier maxi which recently stopped heating the water. When the coffee is brewed, it comes out cold. not hot water and no steam. What can the problem be??
First thing I would check is the reset thermostat on the right side of the machine above the element. Turn machine switch off then push in on pin you will hear a click.
Aug 06, 2011 | Nuova Simonelli Premier Maxi Espresso...
Nuova Simonelli Premier Maxi V , 2005...when water turned on machine constantly leaking from the pressure relief valve and the hot water valve.
Has the machine been in cold storage? If no then the inlet solenoid could be the culprit. There might be sediment keeping the valve open.
May 11, 2011 | Nuova Simonelli Premier Maxi Espresso...
Hi I have just bought a Nuova simonelli premier maxi and the warning light keeps flashing above the coffee pot sign. Any ideas welcome
Hi, is the water tank filled with water? Did you perge the system,remove air locks? Is coffee beans filled?
Sometimes when these machines are new or used and sit for a while, you have to purge the system.Try turning on power and when ready light comes on, use the frother knob to let out a steady flow of steam.
If this machine was always in use, then you may have to ``descale`` the system by running a solution of descaling liquid thru a few cycles.
Try this ,hope it helped you..
From-an Espresso fanatic...
Feb 25, 2011 | Nuova Simonelli Premier Maxi Espresso...
I would like to be able to adjust the flow of the water my nuova simonelli maxi machine. The water flows out of the machine in about 10 seconds and stops which is way to fast. Seems as though the...
Take the cup warmer off the top and find where the water line comes into the machine, follow this line to a tap that has a screw in knob. If you turn the know clockwise it will slow the flow of water to the hot water spigot.
Sep 06, 2010 | Nuova Simonelli Premier Maxi Espresso...
I have a 3 group 2002 premier maxi. the laft and
The metering jet filter on top of the heads are blocked or the solenoid coil is damaged.
Jun 18, 2010 | Nuova Simonelli Premier Maxi Espresso...
Pump runs for a minute - stops and water light
Make sure that the inlet solenoid is not blocked, the manual fill might be fine but the solenoid could be blocked.
Nov 01, 2009 | Nuova Simonelli Premier Maxi Espresso...
Doesnt work when its warm
The pumps in these are low resolution pumps and don't seem to take a lot of stress. We ran the same machine with three groups 362 days a year. You probably need to replace the pump. You should watch your gauges and be pulling 9 - 10 bars when pulling a shot. The top side of your gauges is water pressure coming in. Sounds like a new pump. Good luck.
Nov 18, 2006 | Nuova Simonelli Premier Maxi Espresso...
Open Questions:
See all Nuova Simonelli Premier Maxi Espresso Machine Questions
Nuova Simonelli Premier Maxi Espresso Machine Logo
177 people viewed this question
Top Nuova Simonelli Coffee Makers & Espresso Machines Experts
J.D. Browning
J.D. Browning
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you a Nuova Simonelli Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
