Question about Garmin nuvi 350 GPS Receiver
Garmin Nuvi 360 - Acquiring Satellites
My Garmin Nuvi 360 has been working fine for a long time until the last trip.
It does not acquire any satellites. Tried the maintenance mode - remove errors does not work .. dont know whats wrong ...any help is appreciated..
  • 3 more comments
  • chrisjplee Jun 29, 2008
    exactly same problem , will not acquire satellites - just went without warning .tried re-booting several times - no joy . Dont know how to get hard re-boot to erase data .
    Advice welcomed
  • Anonymous Jul 28, 2008
    My device always trying to acquire satelite but not to avail.
  • shbn04 Sep 09, 2008
    I just got my Garmin Nuvi 760. Took 1 trip to Canada. No problem. Now I am in the US. I cannot get the satellite connection. Did update the softwares. Same problem.
  • cdiamonds Oct 23, 2008
    My Garmin Nuvi 360 suddenly stopped being able to find the satellites. It says "trouble tracking satellites". Sometimes, after 10 minutes or more, it will find the satellites but lose them again shortly after.
  • gwanrisman Feb 20, 2009
    Same problem. Happened without warning. Purchased in June 2007 and the problem happened on Feb.12, 2009. Same questions ... Are you indoor/outdoor ... Moved hundreds miles ... Current date. I'll try with upgrading software.
  • 3 Answers
I had a problem with my Nuvi 360 that it couldn't find the satellites. I couldn't solve the problem with resets or updated software, but a new, external antenna that plugs into the side of the folding antenna seems to have solved the problem. Available from Wireless Finest through Amazon.com - like $11.50. Great solution - can't beat the price.
Posted on Mar 03, 2009
  • 4 Answers
If you have already updated the firmware and the version of your GPS software in the System/About menu shows as something other than 0.0
Try inserting a small wire into the external antenna port that is on the side of the built in antenna.
I used a cat 5 cable that I had torn apart.
A few feet long should simulate an external antenna.
For me this got the internal antenna to work again.
For others this signifies that you may need to use an external antenna.
Apparently nuvi's have a tendency to stop working with internal antennas.
Posted on Oct 11, 2008
    Genius:
  • 1,673 Answers
Did you check to make sure that it is not in demo mode?
I've seen complaints that the unit is not working, and it was in demo mode.
If everything is set up properly and it still does not work, you will most likely have to send it to Garmin in the US.
Jerry G.
Posted on Jul 01, 2008
I have the same problem...not it asks me if I am indoors and if I have traveled hundreds of miles since my last use. My mom is having the same trouble with her nuvi 350.
Posted on Jun 02, 2008
Go ahead upgrade your firmware and softwares from Garmin website, it will upgrade it and it might work.
Posted on Sep 07, 2008
The touch screenon my Garmin Nuvi 600/650 won't work. What can i do?
This is a common problem with units having the serial numbers beginning with "14V", "12P" and "143". It's caused by a defective SHARP touchscreen and needs to be replaced. Please see this link for more info:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Jan 21, 2010 | Garmin Nuvi 660 GPS Receiver
Acquiring satellites
Did you try reseting your nuvi?
Jul 09, 2008 | Garmin nuvi 350 GPS Receiver
Garmin Nuvi 660 cannot acquire satellites
Hi I had this problem and its an antenna fault, give garmin a call and see if yours is still under warranty, if it is they will tell you to take it back to the retailor who will call garmin for a RA Number and they will replace it there and then. If your warranty has run out then call garmin to ask about repairs
Best Of Luck
Jul 19, 2009 | Garmin Nuvi 660 GPS Receiver
Satellites not found garmin 755
is it getting to the satellites?
if not improve the battery level by charging properly.
Jul 06, 2009 | Garmin Nuvi 660 GPS Receiver
my friend has the same unit his will only acquire satellites when unit is plugged in the cigarrette lighter
Jan 24, 2009 | Garmin nuvi 200W GPS Receiver
Trouble acquiring satellites
Garmin nuvi
Apr 30, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin nuvi 250W
try pushing the reset button on the back of the unit and then it should restart and acquire the satellites
Dec 26, 2007 | Garmin nuvi 350 GPS Receiver
Not acquiring satellites
Go to the Garmin Website and see if there is a Software update Available Hope this helps ttech
Jul 24, 2007 | Garmin GPSMAP 60 GPS Receiver
Garmin nuvi 350 GPS Receiver Logo
896 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
