Service call (C0070) - Office Equipment & Supplies
  • 149 Answers
Check that the toner is installed properly. remove the toner bottle, close the door and wait for the motor to stop running (3 minutes) install bottle with the opening up
Posted on Oct 05, 2010
Minolta Di250 copier malfunction C0070; please help me my boss wont buy a new and i need it to make my application; please help me
Re: Error Code c0070
If the machine is throwing the C0070 code without the bottle being inserted than likely the worm gear of the little drive motor of the toner bottle holder is damaged.
If C0070 is only coming up with the bottle inserted, than the bottle may be wrong or damaged from previous attempts.
To reach the toner bottle holder ("hopper") mechanism you have to remove the rear cover.
Apr 02, 2014 | Minolta Office Equipment & Supplies
Minolta Copier Bizhub 1263/211Problem
C 0070 toner bottle mechanism defect.Remove the toner cartridge and clean using a vacuum cleaner the toner botle house and the sensor.
Mar 24, 2014 | Konica Minolta Office Equipment & Supplies
Error code c0070 konica minolta copier service code c0070
Sir/Mam
Power off the machine. Then remove the toner bottle, be careful the hole might be on the bottom and the toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If THE KNUB on the side of the bottle is damage put a new one in. That KNUB is what the toner motor uses to turn the bottle, if it damaged you get a code. If that does not work, you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad.
Feb 05, 2014 | Konica Minolta DiALTA Di200 Copier
Imagistics dl270 code c0070
A error code C0070 means that the toner bottle can not find home position. Did you just install a new toner bottle??? If so, carefully remove the toner bottle and close the front door and let the copier warm up... Once it is warmed up install the toner bottle again.... If it will not clear you have more of a problem with the toner hopper... Good Luck
Jun 08, 2012 | Pitney Bowes 460-4 Toner for Imagistics...
Minolta di250 error code c0070 this error code
This service code C0070 is a universal code used by Konica Minolta to indicate a toner bottle rotation failure. These machines add toner by rotating the toner bottle that you install in the machine. Most of the time this code is caused by a toner cartridge that has been installed incorrectly or has become dislodged from it's holder. To clear the code open the toner door and remove the toner cartridge/bottle from the machine. Close the toner door and turn the machine off then on to reset the code. Let the machine run. This may take several minutes and will allow the machine to bring the toner bottle receptacle into it's home position. Once the machine stops running completely, then you can re-install the toner cartridge. If the code does not come back you are ready to go. If the code came back after removing the toner but before you re-installed it then you have either a dirty rotation sensor or a bad toner drive motor and will need service.
If the code comes back after the cartridge is re-installed then there is either a priblem with the cartridge or with the toner bottle drive.
Most of the time though the problem will be resolved by the outlined procedure.
Good Luck and Thank You for using Fixya.
Sep 28, 2010 | Minolta DiALTA Di250 All-In-One Laser...
I have a device type di183f there is a problem code 70
I have a tip posted for your service code. Just search for minolta C0070 = C,zero,zero,7,zero
Mar 11, 2010 | Konica Minolta DiALTA Di183F Copier
Panasonic fp7781 error code c0070
Re install toner after shaking it up and reset main power
Oct 13, 2009 | Panasonic Office Equipment & Supplies
It is showing error code c0070
Insert correctly the toner cartridge,open the front door and press the service/trouble reset switch placed in the top left side. and close the front door.
Oct 06, 2009 | Minolta EP4000/5000 CS/PRO Copier
Is there a reset button, asking for service
What is the error code? Is it a C0070 code? If so that means that the toner bottle can not find home potion. Take the toner bottle out and let the copier come to ready and reinstall the toner bottle.
Mar 23, 2009 | Konica Minolta Office Equipment & Supplies
Error code C0070
This could be a easy fix for you. Did you just add a new toner? If so, try this..... Remove the new toner bottle CAREFULLY, mahe sure the hole in the bottle is in the upward position. Once you have removed the bottle, Close the front door and turn the copier OFF then back On. Let the copier come to ready and reinstall the toner agian as it is displayed on the front cover or box. Then close the front door and try to make a copy. It should work for you... If not you most likely have a problem with the toner motor or the home position sensor for the toner bottle. You may have to call a service rep. to handle that problem. Good Luck...
Jan 24, 2009 | Office Equipment & Supplies
142 people viewed this question
jasbo
jasbo
