Question about Whirlpool Duet GHW9150P Front Load Washer
My washer will not agitate and shows a code of F25, Can you explain?
  • 2,382 Answers
Hi, to fix f25 (happened to me after 1 month and I purchased a floor model) the fix is easy and does not involve a circuit board even though there are many buttons that light up. A repair man would love to order you any part you want plus markup, suggest the balancing mechanism and you will have made a new friend. give it up if you know you had to push on the door , maybe take a running jump to get it to close.you cannot wash a months worth of clothes all at once 1. unplug unit 2. remove 2 to 3 screws from bottom of front panel 3. next gently check connections, some may need tightening but again be patient and use appropriate pliers but mainly use gentle pressure 4.many will discover how simple it would be to work on the washer especially if you opted for the pedestals (worth every penny) 5. notice the drain trap cleaning access white and circular and turns, with a towel underneath open and clean trap at least once a year ...before replacing panel do a test rinse and spin. you will notice that once the f25 code appears there is no resistance to turning the drum this only helps to protect certain parts, once the appropriate wire is no longer loose this resistance is no longer...test but still be patient wait while the machine goes through the motions. don't start pushing every button. drum starts turning properly then replace panel. there is taped to the panel a manual with a breakdown of all the error codes. remember this is a very expensive piece of merchandise and will do for you what dry cleaners would have done for you (yes it has a wash by hand button and the machine will not spin to remove water in clothes on this selection, it will only turn to agitate , just remove clothes, hand wring out into the drum then hang or place in a plastic bag and refrigerate for a day or so until you can hang items)** I was able to my surprise wash a 110 year old linen tablecloth using this feature (soak items that require special stain removers and rinse before putting them in this machine. this machine is fantastic BUT be patient, and do not overload and do not spin everything on the highest setting. In being patient I was able to wash a king size comforter and the slip covers of a 90" sofa (not together) the machine can do this, not every day, but choose the correct setting such as bulky or heavy duty and select appropriate settings. I know for the money one should not have to take off the front panel but remember the machine weighs 200 pounds and coming from whatever factory one can only imagine what happens to machines that are abused in transportation. The key is to be patient and use common sense, if waiting on the machine to finish or the door to unlock ( the reason for the multiple locking steps is to allow those who have decided to get into the machine the opportunity to get out) then I will use the dreaded word of multitask otherwise enjoy the experience.
Posted on Oct 05, 2010
F25 error code whirlpool washer did every thing I've found on the web even spent 300 on a control board and service tech still gives erro
im not sure why you replaced the mcu when an error code 25 is a rpm sensor loss , this is the sensor that tells the mcu that the drum is rotating and if so how fast , its been my experience if your getting this code then you either have an agitator blockage or a bad drive motor /sensor, happens most times due to water leak from front gasket worn down
Nov 12, 2015 | Whirlpool Washing Machines
What the F25 code
Please, head over to this link, it explains by a regular user on what F25 means and it have pictures.
http://neighboursappliance.com/f25-on-a-duet-washer/
Sep 22, 2015 | Whirlpool Dryers
Hi Have a WEC7500VW whirlpool front load washer shows a F25 code . Looked at the tech sheet in washer does not show that code what is it? Also washer will not spin out on high at end of cycle. Did the...
Not sure what you mean but if the washer doesn't spin then it's probably the switch that controls the spin action.
On most washers, when you open the lid or door the spin cycle stops for safety's sake. In many cases, there is a small extension on the door or lid that engages the switch when you close it. Look where the extension is supposed to engage and that's the switch. I was able to fix my broken switch on my GE washer by cutting the edge of the plastic on a pen and gluing it to the extension so it pushed the switch mechanism down further to start the spin cycle.
Hopes this helps.
Paul
Sep 29, 2014 | Washing Machines
Fault code F25 kenmore elite front load washer
three panels in washer,front, right side,and bottomback.replaced the bottomback panel and it has been working
Jun 01, 2014 | Kenmore HE2 Plus Front Load Washer
The code F25 shows up
Are you sure about that error code? My Maytag Neptune manual does not show any F error codes.
Jun 09, 2011 | Maytag Neptune MAH5500B Front Load Washer
My he5t is giving me f25 code. i have pressed stop and tried to drain but i get f25 again. do i need a new belt?
Here is the info on "F25":
f25_code.jpg?t=1177554999
When you open the top of the washer, look at the black rubber hose leading up to the pressure switch. If the hose is kinked, it will fool the pressure switch into thinking the washer is either full of water or it did not see a water level change after the water valves have been on for a period of time. These failures generate the F20 / F25 codes.
To Clear the F25 Fault. Disconnect & Connect the "Water Level Presure" switch plug, a couple of times, Give it a couple of light "Taps" Reconnect again, and see if that works, it should.
Feb 16, 2010 | Kenmore Elite HE5t Washer
Whirlpool Duet Washer drum won't rotate, can't rotate manually
How are ya? This is kind of technical information that i'm about to give you, so if you're not that technical then you should call a service technician to diagnose. Good luck and thanks for the inquiry :)
F25
DRIVE MOTOR TACHOMETER ERROR
If the control is unable to properly detect motor speed, the machine shuts down.
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
Possible Causes/Procedure
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
2. Unplug washer or disconnect power.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
5. Plug in washer or reconnect power.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
Aug 08, 2009 | Whirlpool WFW9200S Front Load Washer
F25 code for brand new washer
F25 is a keys stuck error code which must be covered under warranty..The only option is to replace the keypad..I suggest that you pester those customer support fellows so that you can get it fixed as it is a pretty complicated process to do it yourself..
Oct 23, 2007 | Kenmore Elite 45986 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
113 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
