Question about 3M Scotch Disc Cleaner for CDs, CD-ROMs, DVDs and DVD-ROMs (av-100) CD / DVD Cleaning Disk
I lost instructions for the scotch disc scratch remover. How do I use it for a xbox 360 game
Scratches on my Xbox 360 game disc
There are many ways to remove the scratches also the cover up the scratches.In order to remove them i have heard that toothpaste does the trick.Apply the toothpaste on the scratches then leave to dry in warm water for 30-40 minutes.
Or you can borrow another copy of the game from a friend and install it on your hard drive then when you put your original game in the scratches become useless.
Oct 06, 2012 | Atari Dragon Ball Z: Burst Limit for Xbox...
Tip
How to play a scratched disc on xbox 360 or some other consoles
Note: I have only experienced using this trick on the XBox 360 Console.
One common problem that video game players have all the time are scratched discs. A helpful way around buying a brand new game or a disc scratch remover, is to first:
a.) Borrow the same version of the game from a friend
OR
b.) Rent the same version of the game from a store
Now, take the unscratched disc, and install it to your hard drive.
And lastly, now you can put in the scratched disc and go to "Game Library", choose the game, and select "Play from Hard drive."
The reason this trick works, is because when you play your disc from the hard drive, it uses minimal memory from the disc itself.
NOTE: Installing a disc to your hard drive does NOT replace having to put in the game to play it.
You still need a copy of the game in order to run it from your hard drive. I believe this is some security feature so people don't go around copying the games and not buying them.
Also, I would NOT install the scratched disc to your hard drive, for this will not help your problem at all.
on Jan 23, 2010 | Video Game Consoles & Games
My Xbox 360 keeps scratching my game discs?
Sounds like the xbox console needs the laser adjusted or secured as per the other comments. For any discs issues, read on.
Check to see if there are any scratches or laser burn marks on the discs.Scratches or marks on discs will render game discs unplayable or will freeze the game and will often show a message stating "Disc Read Error" or something to that effect. Best remedy for starters, is to clean the discs and make sure there are no scratches or marks left on the play-side of the discs. A common problem that XBOX owners are reporting is; if the console is moved during play, a whirring noise is heard and then when the disc is removed, very visible laser burn rings are found on the disc.
Laser burn, looks like complete or partial circular scratches around your disc. This occurs to discs when the games console has been moved whilst playing. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but a professional disc repair service is normally required to fix laser burn scratches or damage to XBOX discs.
For further help on XBOX disc repairs or to get XBOX discs repaired back to "As Good As New Condition", visit:
www.discREPAIR.ie
Check the "More Info" & "FAQ" Sections for further details on disc repairs and related matters.
If this laser burn scenario is consistently happening to your game discs especially if the console has not been moved or bumped against while the disc is in play, the games console itself may require repair. You should contact Microsoft for assessment and guidelines.
Hope this Helps!!
Apr 07, 2010 | Microsoft Xbox 360 Console
We've lost 2 game discs in the xbox 360 in the last 4 months, the disk would get scratched until it freezes. First time the xbox was destroyed, second time xbox still ok but game disc has deep circular...
Check to see if there are any scratches or laser burn marks on the discs. Scratches or marks on discs will render game discs unplayable or will freeze the game and will often show a message stating “Disc Read Error” or something to that effect. Best remedy for starters, is to clean the discs and make sure there are no scratches or marks left on the play-side of the discs. A common problem that Xbox owners are reporting is if the console is moved during play, a whirring noise is heard and then when the disc is removed, very visible laser burn rings are found on the disc.
Laser burn, looks like complete or partial circular scratches around your disc, also known as “the ring of death”. This occurs to discs when the games console has been moved whilst playing, from an upright to a horizontal position or vice versa or simply knocked against or the wires may have been just tripped upon. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but a professional disc repair service is normally required to fix laser burn scratches or damage to XBOX discs.
For further help on Xbox & Xbox 360 disc repairs or to get XBOX discs repaired back to "As Good As New Condition", visit:
www.discREPAIR.ie
Check the “More Info” & “FAQ” Sections for further details on disc repairs and related matters, or send your discs for repair.
If this laser burn scenario is consistently happening to your game discs especially if the console has not been moved or bumped against while the discs is in play, the games console itself may require repair. You should contact Microsoft for assessment and guidelines.
Hope this Helps!!
Feb 09, 2010 | Microsoft Xbox 360 Console
How to repair nba 2k9 for xbox 360
When I have problems with scratched DVD's or games, I use the scratch remover cream that goes on your disc, Leave it on for a few minutes to dry, then wipe it off with a very smooth cloth... Its about $7 or $8 I think.... Good Luck, Like I said this usually works fine for fixing scratched discs
Oct 18, 2009 | 2K Games NBA 2K9 for Xbox 360
X-box 360 screen says " to play this disc put in xbox 360 console"
That might be something related to your Xbox 360 console itself or the disc you are trying to play on, so first have a look on the Xbox 360 game disc itself and check whether there is any kind of scratches or flaws on it.
If you find a scratch or a flaw on the disc that seems to be the reason and just to check it you can put any other game in your Xbox 360 console and try it once more, if the other game is working fine that definitely assures that it's a fault with the game disc & check on the scratched discs page on our web site for more information about the reason for this issue to occur.
In case there is no scratch or a flaw on the game disc try the following steps:
1- With no discs in the disc tray, go to the System section on the dashboard.
2- Select Console Settings.
3- Select Start Up.
4- Make sure it is set to Disc not dashboard.
If it is set to dashboard, select Disc and try the game again. It should work.
If is already set to disc or you tried setting it to Disc and still not working try the following steps:
1. Just clean the disc & put it back in your Xbox 360 console and see whether it's going to work again or not.
2. If it's still not working try also another discs to know whether it's an issue with the actual Xbox 360 console then or not.
3. If the other discs work fine you can try it then without the hard drive because it might also be something related to the hard drive.
4. If it is still not working so this game disc would be for sure faulty and you have the right to exchange it from the retailer you bought it from as it's not scratched.
In all cases if other game discs are giving you the same error message "To play this disc, put it in an Xbox 360 console" you need then to contact Xbox 360 customer support to send your console to get repaired or exchanged.
Aug 29, 2009 | Microsoft Xbox 360 Console
Ring on game
There is a known problem with xbox units scratching discs and Microsoft have a Disc Replacement Policy - check out
http://support.xbox.com/support/en/us/xbox360/gamesandmedia/games/discreplacement/DiscReplacementPlan.aspx
Mar 20, 2009 | Microsoft Xbox 360 Console
New XBox 360 putting scratch in games
the problem is the disc drive.
you have to open it up and put some stick foam " like a sticky strip of foam, insulator : on top of the drive .
the problem is that the disc touches the laser assembly while turning cheating a ring on the disc.
i can fix your games as well as the disc drive if you feel like is to complicated.
Jan 02, 2009 | Microsoft Xbox 360 Console
Disc scratching from xbox 360
A common problem that XBOX owners are reporting is if the console is moved during play, a whirring noise is heard and then when the disc is removed, very visible laser burn rings are found on the disc.
Laser burn, looks like complete or partial circular scratches around your disc, also known as “ring of death marks”. This occurs to discs when the games console has been moved whilst playing, from an upright to a horizontal position or vice versa or simply knocked against or the wires may have been just tripped upon. Discs are then impaired by a ring of laser burn, which is a circular scratch into the disc. Some home remedies may help with very light scratches on some discs but a professional disc repair service is usually required to repair any scratches or laser burn on discs. XBOX laser burn discs can be fixed!!!
For further help on XBOX & XBOX 360 disc repairs, visit:
www.discREPAIR.ie Get Scratched Discs Repaired Back to "As Good As New Condition".
Check the “More Info” & “FAQ” Sections for further details on game disc repairs and related matters.
If this laser burn scenario is consistently happening to your game discs especially if the console has not been moved or bumped against while the discs is in play, the games console itself may require repair. Check your garauntee and contact Microsoft for assessment and guidelines.
Hope this Helps!!!
Dec 05, 2008 | Microsoft Xbox 360 Console
My xbox 360 game keep getting scratched when i play
http://www.llamma.com/xbox360/news/Xbox-360-Game-Disc-Scratched.htm
Jan 14, 2008 | Microsoft Xbox 360 Console
3M Scotch Disc Cleaner for CDs, CD-ROMs, DVDs and DVD-ROMs (av-100) CD / DVD Cleaning Disk Logo
248 people viewed this question
Top 3M Electronics - Others Experts
Are you a 3M Electronics - Other Expert? Answer questions, earn points and help others
