Question about Sharp Televison & Video
I have a standard definition, CRT-type, Sharp TV, model no. 32C540. It recently stopped working. It will not power up. Pressing the front panel power switch, or the remote power switch produces nothing but the sound of a relay switching. 'but no power to the set'. I tried bypassing the power relay, and the degaussing coil relay but 'no cigar'. I suspect a Switching I.C., full-wave rectifier, or MOS Switch, but don't want to buy parts blindly.
  • 3 more comments
  • Hector E. Rodriguez May 28, 2008
    Thanks. I agree it's a power supply issue. I do have the repair manual, and accompanying block diagrams, and schematics. I suspect switching I.C. (ref. no. IC701), or MOS (ref. no. Q701, or the rectifier diode bridge (ref. no. D701). These are part of the primary switching to the power transformer from which all the set's voltages are derived. Thanks again.
    Thanks. I have checked the outlet, and also switched to a different outlet. The power cord is fine. The sound is definitely not from the fly-back transformer. It is from the power relay being energized, but no 125 volt being switched across its terminal. I've bypassed the relay to eliminate it as the problem. I am aware of the dangerous voltages. I've gotten two quotes from Sharp Authorized repair centers (approximately $190). Thanks again.
    Thanks.
    I have a standard definition, CRT-type, Sharp TV, model no. 32C540. It recently stopped working. It will not power up. Pressing the front panel power switch, or the remote power switch produces nothing but the sound of a relay switching. 'but no power to the set'. I tried bypassing the power relay, and the degaussing coil relay but 'no cigar'. I suspect a Switching I.C., full-wave rectifier, or MOS Switch, but don't want to buy parts blindly. P.S: It is not a PROJECTION T.V.
    Thanks. Apparently the full-wave bridge rectifier is fine since the DC supplies, i.e. +13v, +8v, and S+B, must be present for the System Control IC (IC2001)to function, and Regulators IC101, 1403, and 751, ( +5v, +5-B, and +9v-B respectively). Because of this I can also rule out the MOS switch Q701. I've narrowed it down to IC701, (switching for transformer primary to provide +130v to rest of set through the Power Relay RY7002. Thanks for the help.
    Genius:
  • 2,035 Answers
The problem may in the power IC or mos transistor or even the gas in tube is weak, check the ckt board and replace the board as changing the single component may create the same problem later its better to change the board than to change individual components .........
Posted on May 28, 2008
    Genius:
  • 1,226 Answers
REmove the suspected parts then test it independently start with the most easy part to remove. then test.
Please do also the continuity test from the power input to the projection .
melnavz
  • Emelio Navaja
    Emelio Navaja Jun 02, 2008
    Thank you for using fixya.
  • Emelio Navaja
    President:
  • 2,712 Answers
From the symptoms you describe, it seems the high voltage flyback autotransformer has failed. The sound comes from the flyback unit.
But first, check that the AC outlet at the wall is actually working and viable. That is the first step. Next, try a different power cable (if you have the removable type). If these two are ok, then it is most likely a problem with the autotransformer or any one of the power components. It is difficult to say exactly which may be faulty without actually inspecting the parts and testing them.
I would recommend getting a repair guy to take a look, as I do not recommend opening up the set if you have no prior experience. There are voltages inside that can KILL.
Ask him to give you a quote, and if you find that the rate is too high, it would probably be better to just buy a new set.
Hope that helps..
  • Swilin Sampson
    Swilin Sampson May 28, 2008
    Well, check each component for continuity, and by process of elimination, you should find the defective part..
    Good luck with the repair!
    Genius:
  • 3,587 Answers
Hmmm...well...you are most likely dealing with a power supply issue..I'd suspect the capacitors, or the actual rectifiers before messing with the control devices..
My recommend..get your hands on a service manual and schematic, before opening up a can of worms on this one.
  • 1 more comment
  • Patrick Michaels
    Patrick Michaels May 28, 2008
    easiest is to determine if the diodes are good..everything else downstream depends on a dc voltage..just check to see if there's enough there for the rest of the circuit to operate..
  • Patrick Michaels
    and thankya for using fixya
  • Patrick Michaels
    fine..and are you going to reward someone with some moola here?
Cant read text from screen because too blurry on my sharp 32c540 tv
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the the home page, to get gathered some pages which has the details of practical experiences of the author of that site. The search result will display about 20 Nos of related posts. Press the "All posts" at the bottom of the list, then you can select them one by one.
Dec 08, 2016 | Sharp Televison & Video
Ask for a resistor value of r704 on sharp model 21v-fk200m
Sharp 36C-230 36" TV Repair Questions,... - Fixya - Answer
www.lpjaz.com/support/p217124-sharp_36c_230_36_tv
I forget my password TV sharp model 21s-fx10a · Sharp Standard. ... What is thevalue of resistor R704 in SHARP TV model 21V-FK200M circuit diagram.
[WML]sharp 21v-fk200m flat screen crt
www.elab.ph/forum/index.php?topic=41147.0;wap
sharp 21v-fk200m flat screen crt. Pages: (1/4) > >>. bobet20: pahelp po mga master,may problema ako malaki,,,sunog po resistor sa power supply r704,,syaka
Dec 28, 2015 | Sharp Televison & Video
Resistor value of R704 of Sharp tv model 21v-fk200m
How do i unlock sharp crt tv model 21v-fk200m? i forgot the ...
www.fixya.com/.../t25439922-unlock_sharp_crt_tv_model_21v_fk200...
Feb 17, 2015 - Question about Sharp Standard (CRT) Televisions .... What is the valueof resistor R704 in SHARP TV model 21V-FK200M circuit diagram.
Sharp value 2 watt resistor Standard (CRT) Televisions ...
www.fixya.com > ... > value 2 watt resistor > Standard (CRT) Televisions
value of r707 sharp model #27c241 R707 is 27 ohm 1/2 watt carbon resistor,if you ... What is the value of resistor R704 in SHARP TV model 21V-FK200M circuit ..
AV not work
This can be require resoldering of tuner section as if on most sharp models VIDEO is non lockable, this only means that you can conveniently find VIDEO through pressing of CHANNEL KEYS on the front panel. Thanks for using Fixya.
Oct 04, 2013 | Sharp 21" Multi System Stereo TV
What is the screen resolution to the sharp 32C540 ?
480i is the highest resolution of your tv. The tv has composite, s-video and component inputs in the back. The manual states that with component connections are dvd compatible allowing you to enjoy the highest quality image playback than using s-video. Dvd's resolution are 480i or 480p. I'm guessing it's more 480i than 480p since the tv is a crt tube tv and does not have any of the digital inputs for higher resolutions.
Jul 06, 2011 | Sharp 32C-540 32" TV
The stand by timer light on the front panel is flashing red why? and how to stop?
This is because there is some internal problem in the TV.
try pressing the POWER button on your remote control or on the TVfront panel.
If the problem persists, see “Contacting Sony“ at the
end of this section.
Thanx
Jul 28, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How to switch to antenna usage without a remote for a sharp model 27K S100
several answers:
1get the original remote control
2get a universal remote control and maybe you can get menu from there.
3get menu on front panel of the tv and search for the option.
4send the tv to autoprogram. Good luck!
Mar 22, 2009 | Sharp 27K-S100 TV
Front panel button turn tv on and off
If both the remote and the front panel buttons do not work, I would be thinking that it is a problem with the TV's main uPC area. This type of fault can be involved, and would require factory level service where the fault can be properly analysed.
I can tell you in advance, that this type of fault can be expensive to service.
Jerry G.
Jul 30, 2008 | RCA TruFlat 27F520T 27" TV
Televison & Video Logo
66 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
