I wan't to shut my computer off - Computers & Internet
  • 7,733 Answers
Go to :
1-Start
2-Turn off
Posted on Oct 05, 2010
After connecting my Dynex DX-E402 wifi router to my desktop computer and running the Quick Setup on the router website I still cannot connect to the internet nor will my Netflix-ready DVD player connect to...
Typically wireless routers have one port labeled WAN and four additional standard network ports. The WAN port should be connected to your broadband device, typically a cable modem or DSL modem. You can configure your router with a direct connection to any of the standard ports connected to your computer. Your router must be configured to DHCP automatically with its connection to the modem through the WAN port. So to repeat, outside world to MODEM, then WAN port on router, the wired or wireless connection to your computer.
Nov 03, 2017 | Dynex DX-E402 Router
Tip
How to configure a Router?
How to determine the WAN configuration or Interntet configuration of a SOHO Router?
1. Connect the computer to the Modem via Ethernet cable. Make sure you are able to going online 2. After confirming you are online. Go to Start->Run. Type "cmd" on the Run window. 3. Type "ipconfig" on the command prompt or Black window or DOS window 4. You will be getting IP address,Subnet Mask and Default Gateway
There are 4 possibilities of IP address you can get
i)Public IP address under PPP adapter. -Router has to be configured in PPPoE mode to get a WAN IP. This will require a Username and Password from ISP ii) Public IP address under PPP adapter and Private IP address under Ethernet adapter -Router has to be configured in PPPoE mode to get a WAN IP. This will require a Username and Password from ISP iii)Public IP address under Ethernet adapter -Router has to be configured in Dynamic IP or DHCP mode to get a WAN IP -If it is still not getting a WAN IP address. * Click Mac clone on the router's WAN configuration * Power-cycle modem and Router. iv)Just a Private IP address under Ethernet adapter -Router has to be configured in Dynamic IP or DHCP mode to get a WAN IP -If it is still not getting a WAN IP address. * Power-cycle Modem and router.
After determining the WAN mode, it is time to configure the Router
1. Connect the Modem to the WAN port of the router. Connect the computer to the LAN port 2. Go to Start->Run. Type "cmd" on the Run window. 3. Type "ipconfig" on the command prompt or Black window or DOS window 4. You will be getting IP address,Subnet Mask and Default Gateway. The Default Gateway will the IP address of your router 5. Open a Web browser and type http://192.168.1.1(where this is the default IP of the router. This will be different from each manufacturer) on the address bar. 6. Go to WAN settings or Internet settings and select the options based on the above mentioned possibilities
on Aug 26, 2010 | Computers & Internet
Sir, we have HP prolient windows 2003 server (standard edition ) SP2 we are using both LAN/WAN connection in some of the clients using dual IP address. All the client machines are running smoothly but...
hung.
it's virus infected.
OS corruption..
or has hardware issues (had disk going bad?)
why not get it serviced, by a tech.?
reload the OS? if it can't reload the HDD is bad or PSU .
May 16, 2017 | HP Compaq ProLiant ML370 G3 Server
My wireless wont turn on on my dell d600
PLEASE CHECK IN DEVICE MAMAGER IF WAN CARD IS DETECTED OR NOT IF IT IS NOT UPDATE THE LATEST WAN DRIVERS FROM SUPPORT.DELL.COM IF IF STILL NOT ABLE TO DETECT GO TO SUPPORT SITE SEARCH FOR MANUALS OF THE PRODUCT RESEAT THE WAN CARD AND TRY IT AGAIN , IF STILL NOT WORKING WAN CARD HAS GONE BAD CHANGE THE WAN CARD ,
IF WAN CARD IS DETECTED IN DEVICE MANAGER JUST UPDATE THE LATEST DRIVERS AND TRY IT AGAIN AFTER RESTARTING THE COMPUTER ,
May 14, 2010 | Dell Latitude D600 Notebook
Trying to hook up router. What is the wan for and the 4 inputs
The WAN port is the physical interface that provides input and output to and from the device that provides Wide Area Networking capability .. i.e. the modem that connects to your Internet Service Provider. The usual choices are a DSL modem, a cable modem or a Wired router or a wired switch.
The 4 other inputs are wired inputs and outputs for wired Local Area Network connections.
The WAN port normally connects to the Internet. It is not necessary to connect anything to the WAN port to have a network. But without one of the usual devices, you will not have access to the Internet.
The LAN ports connect to the network interface port on the individual computers that are part of the local network. One port connects to one computer.
A large system will have routers connected through the LAN ports to the WAN ports on sub routers and so forth.
Nov 25, 2009 | Dynex DX-E402 Router
It lost its LAC and right now my computer is running on the wireless even though it's not wireless.
Your router's cable is connected in the wrong connection.
1. Remove the cable from the wireless connector
2. Insert it into one of the ports of the router that has LAN not WAN.
3. You will be able to connect your wireless and wired computers to the router.
This could have blue for WAN or Yellow for WAN and then the rest can have yellow for the 4 PCs to connect.
Sep 28, 2009 | Dell Inspiron 530 Desktop Computer
I can get a computer on the LAN but not the WAN. All the other computers work fine but I just got a new one and am having this problem.
The WAN (Wide Area Network) port is used for access to the internet through the use of a DSL or Cable modem.
You can't connect a pc to the WAN port it must be connected to one of the LAN ports.
Jul 12, 2009 | Cyberguard SG530 (SG0064US) Firewall
A problem caused theprogram to stop working correctly. Windows wi
Your problem is a little hard to say. Have there been any power outtages or has you computer been powered-off rather than the regular shut-down procedure. Windows registry and programs can be thus corrupted.
Also computer viruses can disrupt programs so please run for example
Mcafee's free online anti-virus to rule-out a virus problem.
http://us.mcafee.com/root/campaign.asp?cid=45694
Even if you have an anti-virus installed, it needs to be running the latest virus definitions.
You could also try in programs accesories system tools to select "system restore" and bring back your computer to a date where you understand the problem was not happening. (Try this one last)
Jul 11, 2009 | Computers & Internet
How to enable WAN IP in a DI-604 Router for 3 computers
"I wanna make the 2nd pc a server but it isn't accessible through the WAN ip. "
Well that explains everything. If you want to get to 192.168.0.102 from the internet, you need to tell the router where to send packets. You do this by going to the ADVANCED section and configuring Virtual Servers. For example: If you are setting up the computer at 102 as a ftp server, ftp uses port 21. The name would be FTP, private IP would be 192.168.0.102, Protocol is TCP, and the Private and Public ports would normally both be 21. Don't forget to Enable the rule.
What this does is tell the router that when ever a request comes in on port 21, it should forward it to 192.168.0.102. To access the external side of the router you need to go to 70.55.84.233 (according to the image you posted)
Jan 03, 2009 | D-Link DI-604 4-Port Cable/DSL Router...
Router
i asssume that you have connected the ethernet port of the modem to the wan port of the router. if that would be the case, yes you need to connect the computer to the lan port of the router to get internet access. that it if you want your computer to be directly connected to the router. but if you're planning to connect wirelessly, you just need to make sure that your router and computer have a wireless capability and your computer.
Jul 04, 2008 | Blitzz Technology BWA711 (B3WL000900)...
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
