Question about Singer Inspiration 4210 Mechanical Sewing Machine
The needle is entering the machine far to the left. The needle is in correctly and the bobbin plate has not shifted. It appears that the device holding the needle from above has shifted (it shifts easily from side to side but rests only to the left where it hits the edge of the bobbin plate).
    Genius:
  • 1,788 Answers
Is your needle position selector stuck? Try moving the dial back and forth a few times. Have your oiled your machine lately? You manual is available on Singerco.com and is free to download. Good luck
Posted on Oct 05, 2010
Why doesn't the machine pick up the bobbin?
You may have fuzz in your bobbin case or under the plate. If you have canned air, spray it out. Are you using a pre-wound bobbin or one you wound yourself. I've found pre-wounds to be the best. Make sure your thread is pulled thru the bobbin case correctly and your needle up top is threaded correctly too. It's real easy to miss either one. Also, be sure to use a good backing when using fuzzy fabric. What size needle are you using. Too small of a needle may cause this also. For standard embroidery or sewing usually use an 11. Hope maybe this will help. Kindest regards,
Jody
Apr 20, 2015 | Singer Quantum XL-1000 Computerized Sewing...
I can't seem to get the bobbin holder in there correctly to get the machine to sew properly.
While I know it can only go in 1 of two ways, maybe the problem isn't in how the bobbin is in, maybe it is the route of the thread.
My assumption is you don't seem to pick up the bobbin thread and it bunches. If so the carefully follow the thread to needle you may have by passed the place you put that thread so it maintains tension.
Check that carefully, sometimes that gets overlooked.
Jan 16, 2015 | Sewing Machines
My machine will sew one or two stitches then the threads get all tangled under the plate. appears to be the top thread, not the bobbin
Try these suggestions
1. Change the needle--use a needle that's for the fabric being sewed
2. Rethread the machine--top --make sure to use every thread guide
3. try a different bobbin--make sure bobbin is inserted correctly into the bobbin case, & make sure the bobbin is turned the correct way in the bobbin case
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
Aug 20, 2013 | Baby Lock Ellure
Timing is off
Unless someone has worked on the machine it is rare for the timing to be off. What symptoms are you seeing that makes the timing appear off? Other, more common, things that can appear to be timing related include: 1) incorrect needle or needle is set wrong 2) wrong bobbin or bobbin isn't seated correctly 3) upper thread is through the needle incorrectly (left to right, right to left, or front to back) only one is correct
Jan 16, 2013 | Brother CS6000i Computerized Sewing...
When I set the machine up for free motion sewing the bobbin thread snarls
try changing the needle- Correct needle insertion is mandatory for proper use of your sewing machine.
Raise the needle bar to the highest point, then loosen the needle clamp screw to remove the old needle.
Place the new needle in the needle clamp with the flat side of the needle facing the back, (round needle, the groove in the needle should face away from the shaft).
Push the needle all the way up as far as it will go. Then tighten the needle clamp screw.
check to make sure the bobbin is wound correctly & inserted into the bobbin corectly
clean under the needle plate area & in the bobbin area for lint or loose threads
if these suggestion don't help then it would be a good idea to
take the machine in for a check up
Jun 02, 2012 | PfaFF Sewing Machines
My bobbin case will not stay - it turns to the
it sound like you dont have it in correctly take the needle plate off and replace the the bobbin case making sure that the bobbin case stays in place all the way to the right while you put the needle plate back on hope this helps
Jun 28, 2010 | Brother CS-6000
Bobbin
IMPORTANT: Always use a metal bobbin, or the magnetized bobbin case will not be able to function properly, resulting in a lack of tension on the bobbin thread.
9a8cb19.jpg Step 1:
Turn the handwheel counter-clockwise until the needle is in its highest position. Raise the presser foot lifter. Pull the slide plate forward and remove the empty bobbin.
Step 2:
Place the filled bobbin into the bobbin case, and pull about 4" of thread from the new bobbin. Make sure that the bobbin turns clockwise when the thread is pulled, or you will not have correct tension when you begin to sew.
Step 3:
Hold the needle thread loosely with your left hand. Turn the handwheel toward you, first lowering the needle, and continuing to turn the handwheel until the needle comes to its highest position.
Step 4:
Lightly pull up the needle thread and pick up the bobbin thread which will appear through the needle plate slot. Then pull both threads to the back of the machine leaving a 4" thread tail. Push slide plate back in.
Hope this helps. -samson39
Jul 22, 2009 | Singer Sewing Machines
Need manual for Kenmore sewing machine, model 148-600.
hi! there, since there no model you can relay on this basic set up an old mechanical sewing machine,set your upper thread as shown65a8465.jpgfollow the red loop thread from sppol to needle,then lift needle cover plate take bobbins and follow bobbins thread directionec848a5.jpgthreads inside bobbin clockwise rotation when you pull outthe insert bobbin to shuttle race casas shown
hold bobbin like this 33ea7ef.jpginsert
this to shutttle race case as shown ignore arrow
ebd49c7.jpgthen
after inseting bobbins closed needle plate cover
manually rorate hand wheel to hook up lower thread bobbin by upper thread bobbin if two thread appear on plate needle adjust tension dial to # 3 to 4 and stich dial to # 12 this for straight stich try sew manually first to observe thread under bobbins if free rotate and no accumulation of thread loop you sew w/ foot pedal or push buttin..happy sewing and have a nice day thanks
Mar 31, 2009 | Sewing Machines
Breaking thread
1. Make sure you are using the correct needle and thread for type of fabric and it is installed correctly. Make sure bobbin is threaded evenly. 2. Tread path - make sure the machine is correctly threaded. Then, with your finger, feel for burrs, nicks or roughness on any metal parts that contact the thread. Open the slide plate, remove the bobbin and inspect the bobbin case and hook. Remove the needle plate and examine the needle hole. Sand any rough areas with fine emery paper and blow away grit. If burrs or nicks remain on the needle, presser foot, needle plate or bobbin case, replace them with exact replacement parts, if they remain on the thread guides, take-up lever, bobbin hook or tension regulator, take the machine for professional service. 3. Loosen thread tension by adjusting tension dial. 4. Clean feed dog, bobbin case, and tension discs. Unplug the machine. Use a small, stiff brush to wipe dirt and lint off the machine head and the needle bar area. Raise the presser foot and the needle to the highest position, open slide plate and remove the bobbin and needle plate. brush away dirt and lint from the feed dogs and bobbin case and remove any tangled thread with your fingers. Use a soft cloth to clean between the tension disc on the tension regulator. 5. Also check tension on presser foot
Dec 31, 2007 | Consew 206RB
Singer 7442 - Needle hitting bottom
FIRST DETERMIN NEEDLE BAR POSITION TURN STITCH REGULATOR TO LARGEST STITCH, THEN TURN HAND WHEEL TIL' NEEDLE IS ABOUT TO ENTER NEEDLE PLATE.
AT THIS POINT THE FEED DOGS SHOULD BE JUST AT OR JUST UNDER PLATE. IF SO NEEDLE BAR IS, IN CORRECT POSITION,AND TIMING WILL BE SET AT THE HOOK.
TO SET TIME REMOVE NEEDLE PLATE TURN HAND WHEEL SO NEEDLE IS IN LOWEST POSITION. USING A SMALL RULE RAISE NEEDLE BAR 3/32 OF AN INCH ( OR 3 MM FOR A METRIC RULE) .HOOK POINT SHOULD BE IN CENTER OF NEEDLES WIDTH. LOOSEN THE 2 SHAFT SCREWS
SLIGHTLY,TURN HOOK TIL CENTER OF NEEDLE. TIGHTEN SCREWS. IF NEEDLE BAR IS OUT OF TIME. BRING HOOK TO CENTER OF NEEDLE AND LOOSEN SCREW IN LEFT COVER. RAISE OR LOWER NEEDLE BAR TO SET 3/32OF AN INCH. THE 3/32 MUST BE VERY VERY CLOSE.
Nov 26, 2007 | Singer 7442 Mechanical Sewing Machine
Singer Inspiration 4210 Mechanical Sewing Machine Logo
141 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
