Question about Kitchen Ranges
Bosch HES235C Electric Oven. Seems that ever since we cleaned the oven its been a problem, When in use, the oven will default to error 31 or it will beep and say "excessive temperature" and shut off. The manual does not make reference to any error numbers, I have reset the oven many times but it doesnt cure the problem.
  • 161 Answers
SOURCE: Maytag Gemini electric oven
Well my friend these type ovens have eyes and sensers. It could be that you left something on the sensor when you were cleaning it. That is if it is not self cleaning. Self cleaning gets real hot and could affect your appliance in some way. It shouldn't but it might.
Posted on Aug 07, 2007
SOURCE: oven failed to work; F5 error message
please tell about the make & serial no. of oven.
Posted on Sep 30, 2007
jessee007
  • 310 Answers
SOURCE: Kenmore electric range 911.9369181
F8 Failure of Electronic Range Control (ERC) Replace Electronic Range Control/Clock (ERC)
I’m happy to assist further over the phone at https://www.6ya.com/expert/james_1cb31da1bc8c6102
Posted on Jan 01, 2008
  • 110 Answers
SOURCE: Oven will heat up, but then will not maintain desired temperature.
YOU HAVE A BAD ELECTRONIC RANGE CONTROL OR ERC
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Posted on May 30, 2008
hemantraj
  • 638 Answers
SOURCE: Hotpoint RGB747GER oven does not heat properly
www.repairclinic.com
Posted on Aug 18, 2008
I have Bosch self cleaning oven, door will nit open and control panel says error 43 what do I do?
SOURCE: Error 43Our Bosch range will not open after setting to self clean
Error Code: F43 Cause: Upper (or single) oven motorized latch will not unlock; Defective or jammed upper oven door or latch switches; Defective latch motor or its wiring. Corrective Action: 1. Check P24 connector on the power board. 2. Ensure door latch switches are operating properly. 3. Check that neither latch switch nor common wires are
pinched to the appliance chassis. 4. Check P10 connector and check if latch motor wire is pinched to the appliance chassis. 5. If F43 persists, replace power board
Posted on Apr 30, 2010
Error 43 on Bosch range how can open the oven door
Mar 26, 2018 | Bosch Ovens
No digital display and nothing works, like there is no power, however there is power going to oven What could be the issue?
Bosch HBL5450UC information from Consumer Reports
www.consumerreports.org > ... > Ratings
Consumer ReportsThis Bosch 30-inch electric wall oven has the following: ... We have had problems with it not working properly numerous times and have had it serviced directly ...
Aug 05, 2015 | Bosch Ovens
I'm trying to clean my Bosch oven, model number HES5052U, and twice now it gets 30 minutes into the self-cleaning cycle and then it shuts down... flashing Error 41. Everything seems to run smoothly until...
Allow the oven to cool before running self-clean. Always wipe out loose soils or heavy spillovers before running self-clean. If oven is badly soiled, set oven for the maximum self-clean time.
Here is the manual with "troubleshooting". Hopefully, it will help!
Operation Bosch HES5053U 31 100
Jun 29, 2017 | Bosch Ovens
Our Bosch electric oven is 5 years old. We
Either you have not refitted the door back correctly, or the door hinge springs are weak, a common problem.
This being the case, then the only solution is to replace door hinges.
Feb 11, 2010 | Bosch Ovens
Bosch oven function error e124
Can you provide a model number for your oven. Is it a single oven or double ? Wall oven or free standing range ?(conventional with cooking surface)
Unfortunately the error codes for Bosch are different depending on the model of the unit.
Thank you, I`ll look for your reply.
macmarkus :)
Jan 09, 2010 | Bosch Ovens
Bosch Double oven - top oven will not open - seems like it is locked
i am not aware of a bosch oven that locks the top door usually only main oven will lock if self clean pyro oven,the small oven never has this feature sounds more like a hinge problem check nothing is fouling the lower part of the oven door.
Dec 30, 2009 | Bosch HBL 755 Stainless Steel Electric...
Error when self-cleaning - oven locked
Here is the error code and things to check on your oven.
Error Code: F41 Cause: Upper (or single) oven motorized latch will not lock; defective or jammed upper (or single) oven door or latch switches; Defective latch motor or its wiring. Corrective Action: 1. Check P24 connector on the power board. 2. Ensure door latch switches are operating properly. 3. Check that neither latch switch nor common wires are
pinched to the appliance chassis. 4. Check that the solder joints in header P24 on the power board are not broken. 5. Check P10 connector and check if latch motor wire is
Regards
Alan Hood
ami-man
Dec 04, 2009 | Bosch HES5042US / HES5052US Electric...
Replacing interior oven light
Here is the manual for your unit:
Bosch HBN3550/01
The instructions are on page 31.
Hope this helps and please remember to rate this!
Dec 06, 2008 | Bosch HBN 3550 Electric Single Oven
Oven cleaning
Error 41= Data cable shorted to ground//remove cable and reseat
Jan 01, 2008 | Bosch HBL 442 / HBL 446 Electric Single...
Retractable function selector knob stuck
facia panel most probably need removed, not to bad a job, but oven need to come out... go to bosch, web site...search parts finder with your model , and you will see an exploded diagram, this may help yet you get an idea on how it comes apart.. failing that call an engineer...
Jul 02, 2007 | Bosch HBN 560570B / 560550B Electric...
Kitchen Ranges Logo
163 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
