I have an Epson workforce 500 AIO and it recently started feeding the paper crooked and it jams every time.I have checked the paper path and no paper. what do I do now? I dont want to pay epson for support.
  • 4,472 Answers
First thing I would try and do is cleaning the pick up rollers with some alcohol and lint free cloth or q-tips. See if this helps at all. Also if the paper being used isn't new or has been subjected to too much humidity that could cause a problem as well.
Thank you,
Lee
Posted on Oct 05, 2010
Paper jamming and pulling to one side when feeding through the document feeder
Clean the rollers. Your drivers may have an option to do a rudementary cleaning.
Or it's time to tear into it with some coton swabs and 90% rubbing alchohal.
Also look for debris in the path of the paper.
Oct 24, 2013 | Epson WorkForce WF-2520
Workforce 630 paper jam
Epson Workforce 630 has two paper loading areas. One at the bottom and one at the top, back of printer. Make sure you set the printer to correct paper source, or just make sure paper is loaded in both trays to see if it starts taking paper in either one.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
Jun 17, 2017 | Office Equipment & Supplies
Torn paper- how can I disassemble epson workforce 610?
Before you do a complete teardown, use a flashlight to examine every possible point in the paper feed path where the paper is jammed. There may be an easier way to clear it. In some cases I have had to clear a paper jam bit by bit using tweezers.
Oct 15, 2012 | Epson Workforce 610 All-In-One InkJet...
PAPER JAMS ON EPSON 615
Hi, Disconnect the printer completely from the PC and from power.Reboot the PC.Check through the paper paths for any obstructions and remove any stuck papers manually.Connect printer to power and PC and turn it off and on.Avoid filling feeding tray to capacity.Try printing now. Hope this helps.Thanks!
Dec 26, 2011 | Epson Workforce 615 AllInOne Printer
Paper won't feed properly and jams. the paper starts to feed then twists and jams.
There are a couple of possibilities. First is a little piece of paper could be stuck somewhere along the paper path and is causing one of the feed rollers to not grab the paper evenly, which will make the page twist on most of the models in this series, if you pull the paper out and take a flashlight and look up the feed path you will usually see anything in the feed path near/on the rollers at the top.
Another possibility is one of the feed rollers is old and worn out (If machine gets heavy use) and it will cause same issue.
Also light paper stock can sometimes be too thin for the rollers to grab properly and cause it to twist and slide around. This is usually more of an issue with gravity/drop feed printers but can also occur on front feed style too. Usually 20lb stock is good, but if thats doing it, you can try going to a 24lb.
May 06, 2011 | Epson WorkForce 600 All-In-One InkJet...
Paper i feeding wrong, it starts then backs up a
Generally whenever paper goes "crooked" it's because something is partially obstructing the paper path.
It could be a small piece of plastic, or paper from a previous jam that tore off and stuck.
I would suggest looking at the paper path (use a flashlight) to see if there are any obstructions and then carefully remove any found.
I've also seen where the side plastic has become broken, or has a sharp edge sticking out that will cause the paper to misalign.
Hope this helps!
Sep 01, 2009 | Epson Office Equipment & Supplies
My Dell AIO Photo 926 Printer feeds the paper crooked and jams then says to load paper even though there is paper in it. How do I fix this problem?
Try cleaning the paper feed rollers with a cloth dampened with alcohol. Also check for a piece of paper that may be stuck at the place where the paper goes crooked.
Jul 25, 2009 | Office Equipment & Supplies
Epson jammed paper
Check for the compatibility of the paper you're using by visiting www.epson.com and selecting your region. Also, I might add that make sure paper is properly loaded.
Dec 24, 2008 | Epson Stylus Multifunction Inkjet Printer/...
Paper feeding crooked and jamming in my Canon IP6600D printer.
Try doing a thorough cleaning of all the rollers in paper path making sure that there also no scraps or obstructions in the path.
Aug 31, 2017 | Canon Pixma iP6600D InkJet Photo Printer
Paper Jam
there maybe some obstruction on the paper path, inspect visually any sign of abnormality in this area, replacing the ink would not cause this.
it is touching something thats why t is crooked, either small piece of paper, dirt, caked ink, or hardened ink on the roller, feeding unit may have some plate mis adjusted, misaligned feeeding tray as well. try this
cheers
Aug 12, 2008 | Epson Stylus CX4200 All-In-One InkJet...
42 people viewed this question
k24674
jasbo
jasbo
