Question about Home
Can ceramic tile be installed over old ceramic tile?
  • 5 Answers
If your existing tile is installed over concrete and you have no loose or hollow sounding when tapped on then yes you can but I would not reccomend it if they are over wood or Gypcrete.. And Iif they are glazed I would also use an angle grinder with a diamond blade and cut shallow grooves in tile to help adhesion of mud. Or buy liquid anti fracture membrane and roll on existing tile and let dry overnight. I've done dozens of jobs where customer did not want to remove old tile and never had a call back
Posted on Feb 03, 2015
  • 3,740 Answers
You can install tile over tile. However here are the risks. The new tiles will require at least 3/16" of tile adhesive UNDER the tiles when put in place after they have been pressed into position. Additionally the trim around the tiles willhave to be removed and elevated the distance of the tile thickness and the 3/16" grout distance. The tiles if on the second floor of a home will easily losen due to the expansion and contraction of the home and the difference in the 2 types of tiles expansion and contraction rates.
It is not difficult to remove old tiles. You use a flat bar type scraping tool and the old tiles usually will pop right up off the floor. You will have to break maybe 2 tiles to get started but after that they are easy to remove.
My experience in my own fully tiled in all rooms 2900 sq ft home in the tropics is that I have to remove the old tiles as over time the new tiles losen on top of the old tiles. I have tried it several times and have had at least 1 tile come loose each time.
Thanks for choosing FixYa,
Kelly
Posted on Oct 05, 2010
Heavy duty construction adhesive
Ceramic is particularly difficult to bond to due to the polished surface. The shelf you describe is probably heavy, but you have no dimensions or weight provided. I see these shelves fail frequently when they are only "glued" to the wall. It should have been installed to the wall first with a bracket arrangement, then the wall flashed and tiled around the shelf (presuming you have tile walls).
I would recommend that you use stainless steel brackets fastened into the walls (may require using toggle bolts - be sure to run the bolt through the bracket first!) to support the shelf. Use brackets at each wall, then use silicone sealant over the fastener heads. Use the largest brackets that the shelf will allow, you might be able to just epoxy the shelf on top of the brackets rather than trying to install fasteners into the shelf piece, which might break it.
This vendor has nice stainless steel brackets:http://www.gsproducts.co.uk/stainless-steel-corner-angle-brackets/
Apr 19, 2017 | Home
Tip
Tips on how to Get ready the Subfloor intended for Ceramic Tile Installs
Ceramic along with porcelain tile are generally among the most rigid supplies intended for floors. They require the subfloor that's which will take into account that, without any fluctuation and also motion. If ceramic and also porcelain tiles are generally set up on the wrinkled surface area, a person manage the risk connected with allowing the tiles to be able to break and also loosen. Locations recommendations on tips on how to get ready the subfloor for a tile assembly.
one. The installation of ceramic tile along with porcelain tile with a real piece
Repair many splits along with wrinkled pads from the real subfloor before the assembly - specifically crucial in the event the tile will be becoming specifically bonded to the real.
If connected with subfloors along with great splits, look at the chance of removing a large portion of real piece along with replacing that using a brand-new one as an alternative to patching all the splits.
Intended for negative splits from the real piece, smooth that along with real filler, and also related substance.
In the event the real subfloor will be brand-new, that have to be still left to be able to treatment 29 days and nights previous to tiling.
Personal hygiene will be paramount. Aside from virtually any surface area supplies, you'll want to take away virtually any grease intrinsic and extrinsic stains, and also alternative contents that have tarnished the piece because most effective it is possible to.
Bare cement backer snowboard can offer powerful, flat working surface to put in tiles on for those who have the real wood subfloor.
only two. The installation of ceramic tile along with porcelain tile with a plywood subfloor
The plywood subfloor have to be structurally seem along with capable to help support the assembly. Tile floors are generally hefty along with tile is a very difficult substance. It is going to bust and also dislodge in the event the surface area bends less than the fill.
Don't forget which you are required an extremely flat working surface to be effective on. If desired, stone dust the plywood into level the subfloor.
Plywood have to be set up over an acceptable subfloor along with have to be a minimum of one 1/8? heavy if put together with the subfloor. Interior-grade plywood along with particleboard are not deemed strong sufficient for a tile assembly.
three. The installation of ceramic tile along with porcelain tile over plastic floors
Non-cushioned plastic along with linoleum which is structurally seem along with unencumbered with high motion can certainly take action just as one suitable subfloor.
Padded plastic seriously isn't the perfect subfloor. You need to take away the plastic ground along with virtually any remnant adhesive utilised to the plastic assembly.
In some instances, it is possible to eliminate the plastic once more, however , not the adhesive. Use the skinny placed which is endorsed from the backer snowboard maker.
If it seems hard, you might want to lay out the backer snowboard along with thinset.
several. The installation of ceramic tile along with porcelain tile over a pre-existing tile ground
It is possible to sometimes keep the tile ground set up along with employ thinset specifically over that, and also take away the tile using a hammer, dependant upon the best way high the ground must sit down relative to be able to doors and also other internal factors.
In the event the current tile ground is focused with a mortar mattress, it really is very difficult to eliminate the tiles with no removing beautiful mortar mattress.
If you're the installation of specifically on the older tile floors, uncertain " up " the existing tile along with stone dust document. Clean using a degreaser along with analyze a little community suddenly intended for bonding.
In addition, test the height from the ground while using height of doors along with showcases. Any good thinset enable you to set up the brand-new ground.
Incorrect to order subfloors
Subfloors in order to avoid intended for tile installs are generally those that are inclined to bend, increase, contract, and also warp. Virtually any high motion may loosen the tile along with soda the grout. Incorrect to order subfloors have to be succeeded and also taken care of using a suitable underlayment. Here's a list of no-go subfloors:
Padded plastic
Border set up plastic
One layered plywood
Flake snowboard
Particleboard
Computer chip snowboard
Hard wood (strip) floors
Luan plywood
OSB planks
Masonite
Linen steel
Which kind of subfloor considering the installation of the ceramic tile on?
Continue to searching for the ideal tile to your renovation venture? Please click here to be able to consider the amazing group ceramic along with porcelain tile.
Wholesale Ceramic Tile from China Manufacturer Best price
on Jul 31, 2015 | Building Materials
What is the best glue for ceramic tiles?
Thinset mortar is used to adhere ceramic tiles and it can be found in your local home store (Lowes, Home Depot, etc). You'll need a slotted trowel to create ridges in the mortar before applying the tile. The troughs between ridges create a suction when the tile is pressed onto the mortar. Also, if your tile will be installed with grout lines (a gap between each tile), remember to pick up some separators. They are small "x" shaped pieces that are placed between tiles temporarily to maintain alignment and uniform spacing.
Feb 17, 2017 | Saws
HOW DO I CLEAN THE FLOOR AFTER REMOVING THE TILES?
Haze remover, has acid in it so use proper gloves, talk to your local store........Home Depo
Aug 18, 2014 | Daltile Bathroom Accessories Resin Soap...
Tile Saws question
Since tiles are so thick, brittle, and made of ceramic, a special saw must be used. An ordinary circular saw for wood or metal would either break the tile or get so hot that it would seize up and stop cutting. However, ceramic tile is not cut well with sharp blades. The wet tile saw was invented to address all these unique properties of ceramic. It doesn't overheat, uses a relatively dull blade with no serrations, and can be transported to a job site and set up on top of an existing table or sawhorses.
Aug 27, 2008 | Dewalt DW8306 36-Grit. 4-1/2" Blue...
Home Logo
1,203 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
