Question about Toshiba TLP-LV3 Projector Lamp for TLP-S10
Burned component on one of the boards that controls the fans
A friend of mine just gave me a projector however it come up with a fan error. Further investigation revealed that someone had removed one of the fans and installed it upside down which caused the propellor to be stuck. I was happy when I found that but disapointed to see that once the fan was reposisionned properly it still did not work. I then realized that there were some components on the board that were damaged.  I have taken photos of the board and close up photos of the burned components however I do not know where to look for those parts or wher I could find the complet board. the part number on the board is the following. FCDS312243850833 there is also a few other numbers like; 2JS73AC  and 0101. Could anyone help me with that problem thanks in advance
  • fendersquire May 31, 2008
    Philips Hooper XG20 Impact
    Problem Solver:
I have a TLP-S10 that got a fan error after I blew air through it to remove dust. I opened it all up and determined that all the fans actually work so i'm stumped. Since i have an identical projector and have it all opened maybe we can help each other. Send me a personal email if you want to solve our problems together...
Posted on Aug 26, 2008
  • 563 Answers
Hi fendersquire
You will have to provide me with the Make and Model of your Projector first please.
Posted on May 28, 2008
How to fix my fan fail error on my Acer X1161P projector? I have tested the fans and it seems like if it is a system problem, when it starts cooling down after the error they both start spinning...
Fans have 3 wires, power (red), ground (black) and third is RPM. If the fans internal RPM sensor isn't providing the speed reading to the electronics it thinks the fan stopped initiating an error shutdown process. You could possibly try an outboarded fan with the same wiring and voltage to see if that makes any change but if replacing the fan with an OEM fan doesn't fix it, then you have a board issue or wiring failure if the fan doesn't plug directly into the board.
Make sure you check every fan in the unit.
Jan 22, 2016 | PROJECTORS Acer X1161p - Dlp 3d Ready -...
I have a Toshiba TLP 260 Multimedia Projector --after a couple of minutes of being on the fan icon appears in upper left corner the projector will shut down indicator lights for the fan and on, goes red. ...
If all the fans are running and you are sure, than it sounds like you have a bad main control board. Double check that all the fans are running. If so you will need to replace the main controller, this is the board that the fans are plugged into.
Thanks the Projector Guy
Apr 21, 2010 | Toshiba TLP 260 Multimedia Projector
If I turn on the main power switch to my projector, the led's on the power switch and the 4 way (left, right, menu exit) switch come on, however, the power indicator does not nor does the lamp. I just...
I had the exact same problem, I followed the advice of Victorbello on this site, and found a bulging capacitor where he suggested to look. Read where below.
I soldered in a new one from Radio Shack ($1.50) and the projector works again.
PB6200 symptoms: Back fans were not working Bulb won't light (but is in perfect condition) LEDs on control light, but not three status LEDs Internal fan will not turn off.
Solution: The mainboard had a bad capacitor The board is the one where all 3 fans are connected, and which is facing upside down on top of the powerboard.
The bad capacitor on my projector was a 25V 470uf 10mm diameter, 16mm high, 5mm lead spacing capacitor.
"I recommend you to open your projector, unplug all connections to the fan board, turn it upside, and inspect the capacitors and other components. Bad capacitors have a bulge and/or a black stain or fluid coming out on the top."
Apr 11, 2010 | BenQ PB6100 Multimedia Projector
Mistub XD450. Bulb relatively new. Projector
Does the projector work normally when sitting right-side up? If yes, something could be interfering when the unit is inverted. The symptom you describe initially sounds like a defective fan (some fans put out a computer pulse telling the main board it's running--they have 3 wires, red, black, yellow(signal)). If the board doesn't get signals from all required components, it's programmed to shut down to protect itself.
Aug 29, 2009 | Mitsubishi XD480U Multimedia Projector
Can i bypass the control board and not get an error?
you can plug the other fans one by one into the working fan's socket to make sure the fans work. if they don't replace them. if they do, you have a main board issue. the fans have a 3rd wire that senses rpms, so they can't be rewired.
Aug 08, 2009 | InFocus X1 Multimedia Projector
Infocus screenplay 7200 fan failure with new lamp After powering on, red LED blinks 4 times which means fan failure of the fan that is part of the lamp module. Already returned initial new lamp and got...
Not sure if this helps with the 7200 bu had a 4805 with a failed fan issue. There are two fans inthe unit, one smaller one that cools the color (colour) wheel and the larger one that cools the lamp. This unit had a problem with the larger lamp fan not turning. Unplugged and disassembled the unit to get the fan out and tested the fan using a 9v battery and a couple of wires (best to uplug the fan from the controller board so you are not forcing voltage into the unpowered controller board... that said, I did it hooked up just peeling back the label in the centre of the fan and touching the wires to the solder contacts) The fan worked fine so figured the controller board was the issue, so this wasn't going to be a simple "buy a new fan" issue.
Here is where your mileage may vary...
I decided that it would be OK to just run the fan. Unplugged the fan and powered it from the 9V battery and assembled the unit and powered it up. Found that there was 7v available on the power board at the second pin that was alwasy on when the power switch was on (thats the positive 7 V pin, but measure it with a meter since we are talking about a different projector) and just wired the fan direct to pin 1 and 2 (1 is ground on the 4805, 2 is +7V) and so now whenever the main power is on the fan runs, so after ti cools down I just power off the main power when not in use... or let the fan run if the noise isn't an issue. Crude but effective fix.
Mar 13, 2009 | InFocus ScreenPlay 4805 Multimedia...
Cooling fan problem projector
I have a similar issue though mine isn't quite as extreme as yours. Got a couple things you can do.
1. clean out the projector with compressed air. You might have dust building up on components that is trapping heat.
2. Your fan might be burning out. Needs to be replaced. I'm still working on trying to figure out what tipe of fan it needs.
3. The temperature sensor might be going bad. This one is less likely and most complex to solve as it depends on how the system measures the temp. I haven't checked in detail yet.
4. Replace the whole unit or send it in for repair. Both options will be costly...
Jan 01, 2009 | Optoma H56 Multimedia Projector
Mine needed a "fan module" replaced. The part number is 60.J8613.011.
Cost was $60, plus $100 for labour.
Nov 05, 2008 | BenQ PB6200 Multimedia Projector
Fan inop
Hi there.
The problem is not with the fan its the main controller board, that for some reason becomes faulty with these models and stop supplying the fan with sufficient voltage to operate, not really worth fixing because locating one is hard enough and then the part costs $578 (as quoted for my one). What I have just finished doing to mine, is hard wiring an old nokia charger (transformer) inside the projector, connecting it to the underside of the power supply board (to the 240V inlet plug) which supplies the fan with its own power supply thus fixing the problem without spending hundreds. The down side to this is the fan will keep spinning as long as the projector is plugged in (could be fixed with a switch). This isn't even an issue for me because I always unplug it when I'm finished with it anyways, and it allows the bulb to be cooled for a lot longer than the factory set time, and also saving me from spending thousands on a new projector haha =), hope this help in some way or another.
Feb 09, 2008 | InFocus ScreenPlay 4805 Multimedia...
Benq pb6100, light bulb does not on, power ok
I fixed the exact same problem on my PB6200. Both back fans were not working, and the bulb would not turn on.
In my projector, the fan board had a bad capacitor. The fan board is the one where all 3 fans are connected, and which is facing upside down on top of the powerboard. The bad capacitor on my projector was coded C7302 on the schematics. It's a brown, 25v 470uf capacitor.
I recommend you to open your projector, unplug all connections to the fan board, turn it upside, and inspect the capacitors and other components. Bad capacitors have a bulge and/or a black stain or fluid coming out on the top. You can find pictures on the net.
Jan 22, 2008 | BenQ PB6100 Multimedia Projector
Toshiba TLP-LV3 Projector Lamp for TLP-S10 Logo
208 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
