Question about Maytag PAV2300 Top Load Washer
When you put laundry in to wash it seems to want to spin instead of aggitate and wash it is a maytag performa pav2300aww
    Problem Solver:
  • 15 Answers
You have to change a small black magnet it is into the back of the washing machine motor .
Posted on Oct 07, 2010
  • Anonymous Oct 07, 2010
    change motor black magnet it inside the motor from back
Aggitator does not spin
You will need to replace the top portion. Here is the part to order.
Nov 18, 2012 | Maytag Performa PAV2200
Maytag performa PAV2300AWW does not spin (wash cycle works fine). During the spin cycle the tub does not rotate...but i can hear the motor running...water drains...Pls help
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Maytag PAV2300 Top Load Washer
Spin Cycle is slow
new belt or there is a thrust bearing above the drive pulley that wears out.
May 22, 2010 | Maytag PAV2300 Top Load Washer
Grinding sound during agitation cycle on my Maytag Performa
Its probably you stator plate and rotor. But you need special tools for this repair. There a spring that is under 200 pounds of pressure and if you take the screws off that hold the plate its going to fly into you face if your dont use the special tools to depress the spring. Is it more of a clanking kinda of noise? DOes it olnly happen with heavy loads? Try this out. Fill the washer with water only. and get it into a wash cycle with water only. If there is no noise then put in like a load of towels. A heavy load. Now if you hear the noise now then its for sure you stator plate and rotor..hope this helps, but like i said you need those special tools to do this repair or injury can result from the spring part.
Jul 27, 2009 | Maytag Performa PAV3200
Maytag Performa PAV2300AWW screaching noise, belt problem, pulley broke
My Maytag Performa was making the loud squealing noise. I changed out the water pump/bearing, took care of the problem.
Putting a new belt on just help burn up the bearing (they needed replacing) and probably ruined the new belt. Probably seized the water pump bearing and the belt jumped and broke the motor pully. A washing machine motor is very strong, when that h20 pump bearing seized (or possibly some bearings jamed up) the motor kept on turning that belt and the plastic pully gave in. You'll need to replace that also. If the h20 pumb bearing is turning freely, likely the bearings jammed up but or now loose. That bearing should be tight, no slack or play in it. You can probably wobble the pully on it all around while turning it. The slightest slack is too much.
Oct 09, 2008 | Maytag Performa PAV2200
Maytag Performa PAV2300AWW Wahing Machine
Banging side to side during spin cycle.
Dec 31, 2007 | Maytag Performa PAV3200
Does not spin
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Clean this out and refit. Good luck. Plug off the wall first.
Sep 24, 2007 | Maytag PAV2300 Top Load Washer
Maytag PAV2300 Top Load Washer Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
