Question about Conair HC100RCS Hair Trimmer
The trimmer is not cutting the way it should, the bottom blade seems out of place and I cannot put it back in place
    Problem Solver:
  • 5 Answers
Conair trimmers are only good for about a year and they are hard to put back once you have messed with them. does your blade pop off or does it have two phillips screws holding it in? If you take the blade off completely you should see two arms that are in there, you have to place the blades back on correctly and hold them together while putting the screws back in. be very careful not to tighten the screws too much. Oil your blades with 3-1 oil and then turn them on. adjust the trimmer and see if everything is level, if it is try cutting withem and see what happens. If the motor sounds good but the blades are pulling your hair rather then cutting it then you need to replace your trimmers because your blades are daul.
Posted on Oct 05, 2010
How do you convert the Echo grass trimmer model SRM-22ges to the brush cutting option?
There is a hole just above the grass trimming head that you can slip a screw driver into. Turn the head so that the inner and outer holes align where you can put a screw driver or other hard steel object in. Put it in there and then turn the head counter clock wise until it comes off, it may take a little effort to get it to move, but you should be able to do this with your hands. Once you get the trimmer head off, put the blade on and hopefully you still have the nut and washer accessories to hold the blade in place. You will need to place your screw driver back in the alignment hole to hold the head from spinning while you tighten the blade nut back down. Make sure it is tight, you don't want that blade coming off at ~10,000 rpm!
Aug 23, 2014 | Echo Garden
Putting a wahl 9307 back together
You will notice there is a little hook that the spring thing fits into on the device. You want the smaller part of the spring facing upwards and it should tuck in smoothly.
This is the smaller part of the spring facing upwards:
Then it gets tucked in as such:
Take note from the above photo that the square edges on the plastic piece go at the top of the blade piece and the rounded edges are at the bottom.
Then the bottom blade piece rests on top with the curvature facing upwards: putting-wahl-9307-back-together-g0fa4lo4hxabacpjggd4qk4j-2-5.jpg
The rest should be straightforward!
Jul 10, 2014 | Wahl 9307
My toutliner cutting too sharp
Adjust your blade. Remove it from the clipper, and then loosen (don't remove) the two screws that hold the blade and cutting edge together. Use a FLAT surface, like a ceramic sink top or flat piece of tile, and push the cutting edge down and angle the blade with the cutting edge facing the flat surface down to about a 30 to 35 degree angle. Use your thumb to hold in place until you can retighten the screws. Under a light, inspect to see if it is level (it will be noticeable if it isn't) or oil the blade and touch it to a clean dry piece of paper. If it is level, replace the blade on the trimmer, and edge your beard. It should be better than brand new. This also works when it doesnt seem like the blade is cutting sharp anymore. ALWAYS make sure the cutting edge is lower than the blade or you WILL CUT YOURSELF or YOUR CLIENT!
Mar 29, 2014 | Andis T-Outliner Hair Trimmer
I have Bosch hedge trimmer AH15 63-16C which has stopped cutting. It still seems to be working as it should and the cutters moving as normal but suddenly stopped cutting? Just wondering if this is fixable...
This sounds similar to a problem I have with my Bosch AHS 60 24s. The blades are moving but not independantly and therefore not in a cutting action. I took it apart and the bottom blade has slipped off the drive wheel. I put it all back as it should be but as soon as I used it again, the same thing happened. I'm not sure why this is happening, it may be that the motor end of the bottom blade has become slightly bent, so I will be trying to straighten at the weekend. The cost of replacement blades is prohibitive and time for a new hedge trimmer. Has anyone else had this problem and a different solution.
Oct 07, 2013 | Bosch AHS 45-16 Electric Hedge Trimmer
How do I take the blade off
Hold the peanut trimmer in one hand, place a your thumb on the blade with a wash towel pull the blade back, it should pop off. When replacing the blade, the blade has a plastic notch on the bottom where is round, insert that notch into the square hole on the trimmer and push back. it will snap on.
May 10, 2011 | Wahl The Peanut Hair Trimmer
Clippers have suddenly stopped cutting and seem to pull at the hair
Generally removing the two screws.. on the blade foot (don't do this over the sink unless the drain is closed!).. and taking the blade apart.. cleaning the trimmers with a small brush.. apply grease in the blade groove.. reassemble
Usually it's best to put those two screws back just get them in lose.. not quite snug..set the blade upside down on a flat surface..so it pushes the blade back away from the cutting end..level..then tighten those screws while you are pushing or holding down on the clippers cutting edge against the flat surface/table. ... oil the blade with the proper oil or a light mineral oil.
This usually will get them back to cutting properly..the blade should be oiled prior to each use...about two to three drops right along the visible part..or a light spray also hair should be clean.. dirty hair does not cut well at all..and the clippers will tug and pull rather than cut cleanly.
Lastly..if they see a lot of use. might be blade replacement time..
Best of luck!
Apr 13, 2011 | Oster 76076-010 Hair Trimmer
Flymo sabre hedge trimmer blades move but do not cut!
It sounds as if they have come off of the spindle inside and are not synchronised as they should be so the bottom blade is being pushed out of the way when trying to cut. You need to open up the head and unscrew the top to the small gearbox and make sure the bottom blade hasn't jumped up off of the catch point on the shaft.
Jul 23, 2010 | Garden
I had a one hook up on it and the whole blade popped off how do i put it back on
place the short blade on the bottom over the oblong piece then place the larger blade on top and screw back together, if there is a piece of foam inside make sure that is under both the blades and around the oblong piece (refered to earlier) which is sticking out of the top of the unit
Jul 28, 2009 | Conair HCT-426 Hair Trimmer
Clipper Blade
the bottom blade has to be put back in place. Unscrew the two top screws and remove the top blade. fit the the bottom blade on the plastic piece. Replace the top blade and screws
Mar 19, 2009 | Conair HC100RCS Hair Trimmer
Conair HC100RCS Hair Trimmer Logo
741 people viewed this question
Top Conair Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Julia Tatspaugh
Level 1 Expert
Andrew Taylor
Andrew Taylor
Are you a Conair Health and Beauty Expert? Answer questions, earn points and help others
