Question about Sanyo DS27510 27" TV
My sanyo tv will not switch off video to tv. I have a universal remote that I have used for 3 years with it.
3year remote..individual much used buttons can wear out,try new remote
Posted on Oct 05, 2010
Need remote codes for sanyo tv
press the helpful button Step 1 Insert two AA batteries into the universal remote control if you haven't already done so and then turn on your Sanyo TV. Press and hold the "TV" button on the remote until it lights up.
Step 2 Input the following three-digit codes into your remote control one by one using the remote keypad: "004," "013," "049," "108," "110," "180" and "209." The TV will turn off when you enter the correct code for your particular Sanyo model.
Step 3 Press the "TV" button on the remote once more to confirm the code after you've identified the correct one. You can now use the universal remote to control your Sanyo TV.
How to Set Up the Codes for Sanyo Television and Remote
4 digit codes for TV sets including LCD Plasma and Panel TVs GE universal...
http://www.remotecodelist.com/remotes/sanyo/sanyo_rmtu100.html
Jan 27, 2016 | Sanyo Televison & Video
Can you switch from tv to video input on sanyo ds31520 tv without a remote
no you require the remote or a universal remote or sometimes a cable remote that has been programmed to work the volume on the tv set will have an input button .
Sep 29, 2009 | Sanyo DS31520 31" TV
Sanyo ds 27510 tv no remote want to setup my tv with an antennea,wont switch from video 2
If it has a MENU button, press it and use the volume up and down to manipulate the choices, press menu again when you get to channel setup. you want AIR if using off air or Cable for cable. Next screen should say start and press menu again, the channels will start to cycle. If htat doesnt do it, you have a new model than the one I just did tonight. OneForall remotes will probably not have the setup button you need to autoprogram. Best bet is to find a Sanyo made universal remote or other Sanyo remote on Ebay as alot of the buttons are proprietary to manufacturer. Some TV's are useless without their own remote if not on a external tuner (cable SAT or digital)
May 13, 2009 | Sanyo DS27510 27" TV
Unable to get remote to switch to tv/video RCA remote tv is sanyo
It took me forever to figure it out. Press the input key, just below the 9. The TV channel should be on 3. Make sure you put your DVD in and press play manually, so you can see that it is on.
Hope that helps
Apr 03, 2009 | RCA 3-Device Universal Remote with...
Can't switch from aux to video.
The universal remote will not work because there has to be an input button on it.
Aug 24, 2008 | Sanyo DS13204 TV
Sanyo MTS TV
Hello
Most universal remotes should have a TV/Video button. Look carefully on the remote. Or get another brand remote.
Also depending on your Sanyo model there may be a TV/Video switch on the front of the set. Look for a possible small cover along the bottom.
Feb 26, 2008 | Televison & Video
Sanyo stuck on video mode
Yippie, I figured out a solution that worked!!! I have a univeral remote from comcast, on that remote near the bottom left is a small button that says (input) tv/vcr, press that one time and whala!! the tv video screen was gone, I had to manually change the channel from the tv channel button on the unit. once I changed the channel to 3, my universal remote worked... the button is the second one from the bottom left... I was on hold with sanyo for a long time and just kept trying on my own, so good luck!!!!
Jan 13, 2008 | Sanyo DS27510 27" TV
Sanyo DS31590 31" TV Can I get the tv to go into tv/video mode without a remote but from the tv menu directly?
Nope. Remote control is required... However some universal remotes come with this button available in the preprogrammed code. I had a cheap GE universal remote that I used to replace the original when my 2 year old smashed it. I now have a sony universal remote and it's default code (one of them) for Sanyo tv's also works for the video/input button.
Dec 19, 2007 | Sanyo DS31590 31" TV
Sanyo tv codes
The codes listed by Sanyo for my TV won't work in my star Choice remote.
I tried 017 021 039 056 057 058 and 140 as listed by Sanyo.
Any ideas?
Dec 18, 2007 | GE JASRM24912 Remote Control
Need code for sanyo tv
Welcome to FixYa.
SANYO TV Codes: 0154, 0159
Please be informed that the codes vary with different make and model of the universal remote that you have. If none of the codes above work, please post back with make and model of your universal remote included.
Thank you for using FixYa.
Jas247
Sep 01, 2007 | Sanyo DS31590 31" TV
Sanyo DS27510 27" TV Logo
109 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
