Question about Panasonic Microwave Ovens
How to get the plate to rotate - Panasonic Microwave Ovens
  • Anonymous Mar 22, 2014
    plate rotates while heating but not when food is cooking
  • 5,911 Answers
I'm assuming you are talking about the turntable tray. If it's not rotating, make sure your microwave does not have a feature that allows you to disable the turntable rotation (refer to your owner's manual). If it's not a simple operator function, you more than likely have a defective turntable motor. The motor is located under the bottom of the microwave oven. It is a simple repair that requires minimal tools. If you wish to attempt a repair yourself, please post your complete model number (located aorund the door opening) and I can locate a part number for you. I hope this helps you.
Posted on May 28, 2008
THE PLATE HAS STOPPED ROTATING THE OVEN COMES OIN AND HEATES UP BUT THE PLATE DOES NOT ROTATE
the small motor that turns the plate has failed. it needs to be replaced
May 11, 2017 | Microwave Ovens
Frigidaire microwave plate won't turn
The motor for the rotator is bad. It has to be replaced.
May 06, 2013 | Frigidaire Microwave Ovens
Center will not rotate
The glass plate is driven by a motor underneath. Power may not be getting to the motor or the motor may have failed
Jan 17, 2013 | Emerson MW8102SS 1100 Watts Microwave Oven
Siemens HF26066GB plate is moving when door closed and not moving when open
Have a shop look at this---there usually is a recessed safety switch inside the jam that will prevent the unit from working with door open--sounds like the problem may be with it.
Nov 03, 2012 | Siemens HF26066GB 1000 Watts Microwave...
I hv a 24ltr Sharp Carasoul Microwave. Few days back, its plate stopped working, but its heating the food fine. Why has the plate stopped rotating? Will the food be evenly heated even though the plate...
The turntable system typically consists of the motor, the coupler, the turntable support with rollers, and the tray.
Here is a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
You order Sharp parts Encompass here or call them toll-free at 866-779-5835.
> Will the food be evenly heated even though the plate is not rotating?
No.
Sep 07, 2010 | Sharp R-1480 Microwave Oven
Plate will not rotate
Yes there is a small gear reduction type motor that drives the turn table. The motor can be replaced.
Jan 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Glass plate does not rotate
on the bottom of the micro underneath the shield there is a small moter for turning the plate.. also if the plate and roller are not centerd correctly it will not turn ,.. remove the plate and balence a glass on the triangle in the center of the micro shut door and start micro observe if turning ..also some micros have a button selection on the control to reverse the micro plate rotation and stop it --check these things and get back to me..
Aug 10, 2009 | Microwave Ovens
Noisy rotating plate
check d rotating motor,
May 29, 2009 | Microwave Ovens
Revolving plate no longer rotates . All else works, it continu;es to cook, but we need to move the items of food from time to time
Remove the plate, and check if the square shaped gear that normally spins the turntable is rotating.
If it is rotating, then replace the turntable gear.
If it is not rotating that means that the motor that spins the microwave turntable does not rotate, and must be replaced.
Mar 01, 2009 | Amana Radarange Microwave Oven
Microwave Ovens Logo
105 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
