Question about Gateway Computers & Internet
My Gateway MS2274 won't turn on. What do I do?
I had the same problem on the same laptop. I took it to a local computer repair shop and it was a problem in the power switch/button. They ordered a replacement part and installed for like $40. Good luck!
Posted on Nov 22, 2010
  • Gateway Master
  • 7,733 Answers
Check the cable if possible with another PC or check it with a A/C checker.
If is good open your PC and change the internal battery. If this not work is prblably thar the MOBO is burn.
Posted on Oct 05, 2010
2 Suggested Answers
  • 9 Answers
SOURCE: Well I have a Gateway
Try connecting an external monitor and see if your see anything. If you can then most likely your LCD monitor on the laptop is dead. Also try FN+ the monitor toggle key to see if you can get video.
Posted on Jun 20, 2011
I need to replace the network card. How do I do that and what product do I need to buy? Thank you
as far as i see you the network jack is built into the motherboard,
you'd either have to replace the mother board
or purchase a new usb exterior network jack
http://www.ebay.com/itm/GATEWAY-NV52-MS2274-NV5214U-AMD-motherboard-55-4BX01-051-MBWDJ01001-48-4BX04-01M-/251327720635?pt=Motherboards&hash=item3a844cacbb
Oct 29, 2013 | Gateway NV5215u Notebook
Gateway nv ms2274 turns on, no fan, no screen booting up blue led on and battery on - any ideas?
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Mar 21, 2013 | Computers & Internet
Should my fan constantly run when my gateway ms2274 powers on
The fan normally runs in sync with high CPU usage. So, I would say normal. Go ahead and blow out the system with canned air it has become noisier than usual.
Oct 25, 2012 | Gateway NV5214u Notebook
Packard Bell Motherboard Replacement
Geez I hope not. I abhor Peckerd-Bell.
(Why?
Want support?
Ya gotta pay $$$$$$$. A computer manufacturer I like to stay so far away from, that when people say the name, I say,"Who?")
Gateway then Acer. When did peckerd-bell get involved?
http://www.ebay.com/sch/i.html?_nkw=nv5214u+motherboard
http://www.skyline-eng.com/index.cfm?fuseaction=product.display&Product_ID=7400
http://www.aliexpress.com/store/product/Gateway-MS2274-NV5201E-NV5202H-NV5207U-NV5214u-Motherboard-48-4BX04-01M-MB/906865_519039566.html
Now tell me about the P.B. thing in a Comment.
Regards,
joecoolvette
Aug 25, 2012 | Computers & Internet
Ggateway ms2274 shutting down wont start up
onehugo, has the inside of the laptop been cleaned out?
The Gateway MS2274, is also known as part of the Gateway NV52 series of Notebook PC's.
Look on the bottom of the laptop, and post the Model Number.
(Examples, NV5207U, NV5211U, NV5212U, and so on)
http://support.gateway.com/us/en/s/notebook/2009/gateway/nv/nv52/NV52nv.shtml
(Clicking on Product Views, then on the different product views given, will show you the ms2274 is part of the NV52 series )
The laptop uses the same cooling system as most laptops.
1) Cooling Tube:
Slightly flattened copper tube, sealed on both ends, and filled with Nitrogen.
At one end of the Cooling Tube there are two small metal plates. One plate sits on top of the Processor. The other plate sits on top of the graphics chipset.
At the other end of the Cooling Tube a Heatsink is mounted.
2) Heatsink:
For this series it is a rectangular finned object. Small strip of metal with Tall, Thin fins protruding from it.
3) Fan Assembly:
Fan set inside a backwards D shaped shroud. (Surrounding cage)
The Fan Assembly draws air up from the bottom, then exhausts the heated air out of the side of the laptop.
Operation:
The two small metal plates absorb heat from the Processor, and graphics chipset.
The heat is then absorbed by the Cooling Tube.
The Cooling Tube transfers the heat along it, up to the Heatsink
The Heatsink absorbs the heat, then radiates it away with the Tall, Thin fins.
Air flow from the Fan Assembly, helps carry heat away from the fins of the Heatsink.
This is an up close example of the cooling system used, on the Gateway NV52 series of Notebook PC's,
http://www.laptopneeds.com/parts/show/120817549354/
Scroll the page down to the photos.
The bottom photo shows the cooling system, as it looks removed from the laptop, and the side that contacts the Processor, and graphics chipset.
Here I am able to show you the metal plate surface, that contacts the Processor, and graphics chipset.
With this design there is only one large metal plate to do both jobs, instead of two small separate metal plates.
Coming from the end of the copper Cooling Tube, and going to the Left;
1) You will see a small square, covered partway with a gray Thermal Paste.
(Thermal Paste makes a triangle shape)
This pad sits on top of the Processor/
2) Coming to the left a little further you will see a rectangular copper pad, with gray Thermal Paste smeared on it. This pad sits on top of the graphics chipset.
[ The Processor and graphics chipset, are the two hardware components inside a computer, that give off the most heat ]
Also here you will see at the side of the (Black) Fan Assemblies shroud, is the finned Heatsink.
Point of this long 'dissertation'?
Want you to see the cooling system, and especially the fins of the Heatsink.
Air is drawn up by that fan, and pushed through the fins of the Heatsink.
ANYTHING the fan draws up with the air, is pushed through the fins of the Heatsink
Dust, dirt, hair, food crumbs, lint, ...you name it, is drawn in.
This coats the fan blades, fan's center hub, and surrounding cage. (Shroud)
Also clogs the fins of the Heatsink.
This drops the cooling capacity of the cooling system, tremendously.
The Processor, and graphics chipset overheats.
When a Processor overheats it turns off. (BIOS turns it off)
No Processor operating, no computer.
After a few times of this error codes are logged in. BIOS won't turn the Processor on, until the problem is fixed, and error codes are cleared.
Solution is to clean the inside of the laptop out.
Laptop partially disassembled;
Use an ESD wrist strap, ($3 to $6), and connect it's alligator clip to a good ground source.
Use compressed air for computers, a soft small brush, (Makeup brush?). and Q-tips.
No sir/ma'am.
Using compressed air at the Fan Assemblies opening, at the bottom of the laptop, (Air Intake Duct) WILL NOT DO THE JOB CORRECTLY.
It will just shove the gunk further into the fins of the Heatsink.
Use compressed air at the side of the laptop, and the exhaust port?
Even WORSE!
Also;
You see I mentioned Thermal Paste.
The bottom of the two pads on the large metal plate, on the Cooling Tube, (Whew!), is not perfectly smooth.
Neither is the top of the Processor, and graphics chipset.
A magnified view would show imperfections.
'Pitholes, Valleys, and Hills'.
When the two surfaces are mated together, (Pads on top of Processor, and graphics chipset), they create Air Pockets.
Air is an Insulator. Not a Conductor.
Thermal paste fills these imperfections, and is an excellent Conductor of heat. Transfers the heat well.
After time the Thermal Paste dries up. Caused by age, and the heat of the Processor, and graphics chipset.
Fresh, new Thermal Paste should be used.
The top of the Processor, and graphics chipset, plus the bottom of those two pads on the metal plates, should be cleaned THOROUGHLY!
Then fresh, new thermal paste is PROPERLY applied.
Software problem? Windows is messing up?
NO
You stated the laptop is shutting off, BEFORE the operating system is started.
[ You press the Power On button. This is tun presses against a momentary contact switch. The Power On switch.
The first chipset to receive power is the BIOS chipset.
BIOS looks to see what devices are connected, does a Ram Memory count, turns the Processor on, then hands the computer over to the O/S.
The Processor isn't turning on, or isn't staying on ]
I can post links to the NV53 series of Notebook PC's, for a Service Manual, and pictorial guide, for disassembly.
With this info you can crossover easily to your NV52 series.
If you wish to clean out the inside of your laptop yourself.
There is ALSO other needed information I will state along with them.
Post back in a Comment.
Regards,
joecoolvette
(Apologizes for the long solution )
May 17, 2012 | Gateway Computers & Internet
Gateway Model No Ms2274 won't power up
Computer does not boot upThe problem maybe the RAM, it is faulty or just needsreseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up thenremove the RAM module/s and take them to your friendly computer repair shop andget them to test the RAM for you.Just like you sometimes need a mechanic to repair your car,sometimes you do need a technician to diagnose and identify the fault or faultson your computer. Not only does a good service technican have the experience todeal with this type of problem, they also have the equipment that allows themto look at things the average computer user can't see, and he has a collectionof replacement parts that can be used to quickly test individual components onyour computer.
Apr 23, 2012 | Gateway Computers & Internet
Well I have a Gateway Laptop Model MS2274 and it won't turn on. The light of On/Off is blue so it's on, but the screen remains pitch black. I connected it to recharge it and the light turns on too....
Jun 20, 2011 | Computers & Internet
I am looking for a power cord for a gateway laptop ms2274 19 volt
If you have one in your area, go to Microcenter and get a Kensington K33404 universal power supply. they come with multiple tips for all laptop makers and also have variable power setting. I use one with my HP and my brother with his Toshiba. They are only $25 at Microcenter. Or go to www.microcenter.com and order one on-line.
Jun 11, 2010 | Computers & Internet
Trying to disassemble MS2274 Gateway laptop--
you need to replace the DC Jack it will involve soldering a new part. most time the whole laptop need to be taking a part to get the it, so unless you are ready for a big challenge take it a tech.
May 08, 2010 | Gateway Computers & Internet
My gateway laptop keeps shutting down. it is brand new
How long have you had it on. If you are not venting the heat out away from the processor, it will shut down to protect it. I suggest either take a small fan and blowing towards the computer. Or they make a chill pads for laptops about thrity dollars.
Oct 12, 2009 | Gateway (MS-6946) Modem
Computers & Internet Logo
2,593 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
