Question about Epson Stylus CX4800 All-In-One InkJet Printer
Epson CX4800 dried ink
How can I remove dried ink from the black ink jet. cartridge removed and when new one installed black will not print.
    Scholar:
  • 187 Answers
You can use the "Clean Print Heads" function if your printer allows and provides such an option. You can find this option via the printer proprties (Start > Printers and Faxes, right click your printer and select Properties. The clean options will usually be on the Maintenance tab)
Posted on May 28, 2008
Epson Stylus Photo R220 Ink Jet Printer won't print with new ink cartridges
Silly question: Did you remove the plastic tape from the bottom of the cartridges when you installed them?
Apr 30, 2012 | Epson Stylus Photo R220 InkJet Printer
The printing is running normally but the paper is coming out blank, no light , no codes. I run the power cleaning 3 times already, can you tell me what to do?
Remove the cartridges and hold a piece of tissue paper under the jets to **** ink through them. If this does not work, stand the cartridges in about 1/4 inch hot water for a while to soften dried ink. (if they are new cartridges, did you remember to remove the seal over the jets?)
Jan 24, 2011 | Epson Stylus CX4800 All-In-One InkJet...
I have an Epson CX4800 that just stopped printing. I followed the Troubleshooting steps on the Epson site (including new ink cartridges) but nothing has helped. the print job does reach the printer - but...
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Jan 28, 2010 | Epson Stylus CX4800 All-In-One InkJet...
I have installed a new black ink cartridge. "Ink is out" comes up when I try to print. It is properly installed and is the second new black ink cartridge this has happened with. The "On" and 'Ink" lights...
I have installed all new cartridges. "Ink is out" comes up when I try to print. It is properly installed and is the second set of ink cartridge this has happened with. The "On" and 'Ink" lights do not stop flashing. The printer does not see the new cartridges.
Jan 04, 2010 | Epson Stylus CX4800 All-In-One InkJet...
HOW DO I CHANGE INK IN AN EPSON SX200
Hi
Thanks for using FixYa. Turn the printer on. Now raise the lid of the cartridge cage and wait for the cartridge carrier to slide out. Lift the cartridge holder lid and remove the cartridge. Before installing the new Cartridge, remove the tape from the ink opening point on the bottom. Now insert the new cartridge into the cartridge case and close the cartridge holder lid. Close printer cover. After doing all the above steps, print a test page.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 26, 2009 | Epson Stylus CX4800 All-In-One InkJet...
We repalced the black ink cartridge but it wont print black
Most ink jet cartridges have "multiple" protectors to keep the ink from leaking or drying out and the electrical connectors from getting damaged before they are installed into the printer. You should be removing a plastic cap device for the ink, and typically, a piece of clear tape that protects some copper traces on the back of the cartridge. Make sure both are removed. If it still does not work take it back to who you bought it from and have them check to make sure there is ink in your new cartridge. Typically, you can shake it and hear a liquid sound. Good luck.
Toby White-Beebe
Dell Certified Lead Systems Expert
Jul 08, 2009 | Epson Stylus DX4450 All-In-One InkJet...
Epson CX4800 cannot clean the print heads
Please remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Please snap the cartridges back into the cartridge carrier and please try to print a printer self test.
May 27, 2009 | Epson Stylus CX4800 All-In-One InkJet...
I've got the Epson Stylus DX 8400 printer. when I put the cartridge,this message come up: "ink cartridges cannot be recognized." txs
I had the same problem too.  I went to the Epson website and they gave instructions to shake the cartridge 4-5 times prior to installing.   It worked!!!  I tried alot of things before I saw that I needed to shake the cartridge.  Definitely give this a try if you haven't already.
Dec 27, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Not printing
Have you checked if your cartridge protective tape is removed. There is this transparent tape in your ink cartridge contact area especially for HP printers, you need to remove it so you can print.
It would be helpful if you put in the actual unit with your question...
Mar 10, 2008 | Epson Stylus CX4800 All-In-One InkJet...
New printer clogged
do the cleaning cycle>go to printers and faxes right click on CX4800 go to printing preferences go to utility/maintainance and head cleaning do it 3 times
Feb 01, 2008 | Epson Stylus CX4800 All-In-One InkJet...
Epson Stylus CX4800 All-In-One InkJet Printer Logo
119 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
