Question about GE WSXH208A Front Load Washer
When u open the door there is a rubber seal that keeps the water from coming out of the washer..this rubber ring is tore and water flows out of the washer door and onto the floor...can i get a replacement
    President:
  • 670 Answers
You can get a replacement at repairclinic.com. Here is a link
http://www.repairclinic.com/SSPartDetail.aspx?s=t-WSXH208A-%3d%3di1089524&PartID=1089524
Posted on Oct 05, 2010
A piece of the rubber circling the door opening tore off
that rubber is part of the bellow that seals the opening to the drum. if it is just a small piece that tore then u might be ok. if it is leaking from the door or underthe washer then u will need to replace it. I have whrillpool and the bellow for mine was $85
Apr 07, 2014 | Miele Novotronic W1918A Front Load Washer
I recently purchased a home which this washer was included. It has a moldy odor. I cleaned it out under rubber ring but seems to keep coming back. What can I do?
The door seal will need to be replaced. Once the mold sets in deep it will keep reappearing every couple weeks or so. Here is a link that will help with the door seal. It's a different model but a similar procedure would be used. Replacing a door seal
Nov 05, 2010 | Kenmore Elite 45986 Front Load Washer
Amana NFW7200TW washer - door seal ring has detached
The ring is a clamp that keeps the rubber part, called the bellow, attached to the front panel of the washer. To reinstall hook the edge of the bellow around the lip of the opening in the front panel (the hole through which you put your laundry). Then take the clamp and seat it in the groove of the bellow behind the lip of the front panel. The spring on the clamp should pull the bellow tight to the opening of the panel.
Like so:
Jun 11, 2010 | Maytag NFW7200TW Front Load Washer
There is a piece of rubber that tore off from the seal
yes new seal needed..go to espares.cu.uk if you live here...or utube on how to do
Apr 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
After my washer spends the rubber comes
Do you mean the door seal has come loose.
Disconnect the machine from the power. Open top hatch by removing two screws in the back and sliding top lid back and up to remove.
Check down from the top of the machine and feel around the door seal. Make sure there are no holes or tears in the seal. Try and refit seal. there is a metal ring around the drum and also around the front panel where the door seal joins. Make sure the are tight and fit in properly.
Let me know if I didnt understand the problem.
Good luck.
Ash
Oct 22, 2009 | Samsung WF448AAP Front Load Washer
Wire ring that holds rubber seal on next 100 washer has come off
Bosch Nexxt 100 Series WFMC1001UC Front Load Washer how to put back on wire ring, with a spring for tension, that holds the inner rubber seal in place.
This video will show you how to change a door seal on this Bosch front loader washing machine and also how to get back on, the metal ring around the seal.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 24, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Leaking door due to the wire ring that holds rubber seal
Bosch Nexxt 500 WFMC3301 Front Load Washer how
to get the metal ring back on.
This video will show you how to change a door seal on this Bosch front loader washing machine and also how to replace the metal rings.
Oct 06, 2008 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Kenmore HE 110.4751 front load
soild metal part fits in groove around door boot spring goes in at bottom they can be tough to get back on after inserting in groove around seal you'll have to stretch the spring and pop it under at the same time band will try to come back out and roll seal back off lip..good luck
Jul 16, 2008 | Kenmore Elite 45986 Front Load Washer
Washer door seal is loose
The rubber seal fits over the lip around the door opening. Carefully seat the rubber seal all the way around the door opening first. Then, place the wire hoop in the crease where the rubber seal fits over the lip. Insert the hoop with the spring pointing at the bottom. Starting at the top and work your way around the door opening to the 4 and 8 o'clock positions. While holding the hoop in place, stretch the spring apart enough to allow the rest of the hoop to snap into the crease at the bottom of the door opening. You may need a second pair of hands to help you with this. Good luck and I hope this helps you.
Sep 16, 2007 | Kenmore Elite 45986 Front Load Washer
GE WSXH208A Front Load Washer Logo
98 people viewed this question
Top GE Washing Machines Experts
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
