Question about Maytag Washing Machines
Mhwe300v starts flashing 'suds' or f21- cleared drain and filter. washer fills & washes then 'suds' or f21 appears still. is this the timer?
  • 5,911 Answers
"F21" is a Long Drain error code. This is an indication that you may have an obstruction somewhere in the drainage system. Most commonly, this is an indication something is lodged in the drain pump or the inlet line running from the wash tub to the inlet side of the pump. If you've already checked the drain pump reservoir, then make sure the inlet side of the pump is not obstructed. This does not have anything to do with the timer.
NOTE: The washer will not complete a wash cycle until the conditions causing the error are corrected. A "SUD" or "SD" (Suds lock) error code can also often occur in conjunction with the "F21" error code. This is due to air being detected in the drainage system, which can occur if the pump is not running, or if you have an obstruction BEFORE the pump. You need to remove the inlet hose from the pump to ensure it is also not blocked. Correct your drainage system fault, and the SUD error (if displayed) should go away.
NOTE: If these preliminary measures do not correct your problem, you may have to replace the drain pump. It does not take much to damage the pump impeller or motor. Since the error code is generated if the drain cycle exceeds 8 minutes, if the pump is damaged and can't pump at the required volume, the error code will continue to appear until the pump is replaced. If the pump requires replacement, the following link explains how:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
These are very simple repairs that you can perform yourself without the assistance of a repairman.
If the wash tub is full of water, you may want to use a wet/dry shop vac to pull a vacuum on the drain line and drain the wash tub. This will minimize any potential mess you may have to clean up.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
NOTE: The error codes are not listed in the owner's manual. For an explanation of all the error codes, each one of these washers comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information provided and if you have questions, please post back and let me know. I hope you find this information helpful.
NOTE: Later model Maytag washers are manufactured by Whirlpool, so these instructions do apply.
Posted on Oct 05, 2010
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
Error message SUD and F21 even after unclogging the filter
Push the pause/cancel button twice to clear your message. Then run through a rinse/spin cycle. Next try a normal load without any detergent. SUDS is usually from too much detergent. If this fails, checked the hose for kinks. Check connections and if all that fails, you will probably have to replace the pump. Good Luck!
Feb 04, 2014 | Maytag MAH6700AWW Neptune Front-Load...
What does it mean if the washer is not draining and has a flashing f where the time shows?
I have the manual for this machine. Under "Code 21" it says the following:
"F21" (Drain Problem) Select STOP twice to cancel the cycle. Unplug washer or disconnect power. Check the following: Is the drain hose kinked? Is the drain hose frozen? Is the drain hose clogged? Is the drain hose more than 96" (2.4 m) above the floor? Plug in washer or reconnect power. Re-select cycle and press START. If the problem remains, call for service.
For "SUDS" code, the following:
"SUD" (Suds Routine) When excessive suds are detected, a suds routine automatically starts. This routine removes extra suds and assures proper rinsing of your garments. "SUD" is displayed during rinsing to inform you that Suds Routine was activated. Use only HE (High Efficiency) detergents.
Here is some more information that may help you as well:
"F" Codes other than F20, F21 and F22 Select STOP twice to cancel the cycle. Select DRAIN & SPIN if there is excessive water in the washer. Re-select cycle and press START. If the problem remains, call for service.
I hope this is of some help to you, Please rate and comment, Thank You
Joe
Sep 07, 2011 | Kenmore HE2 Plus Front Load Washer
I keep getting the code F21 & sud.... not draining... any ideas
Hello & Welcome to FixYa
F21 error is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Kevin
Jul 31, 2011 | Whirlpool Washing Machines
Won't finish cycle 21 F- flashing on panel
F21 error code is indicating that it is taking too long to drain water.
Your details indicate that you are using too much detergent or the wrong type of detergent and causing excessive suds. The drain pump can not pump suds out. The washer requires HE (High Efficiency) detergent formulated for front loading washers.
Cut back on the detergent and it will most likely operate correctly.
NOTES:
* After four (4) minutes the "Sd" error will be displayed, and then four (4) minutes later the "F21" error code will be displayed.
* Press STOP two (2) times to clear the display.
Possible Causes:
- Using too much High Efficiency (HE) detergent and causing too much suds.
- Using NON-HE detergent causing too much suds.
- Kink in drain hose
- Debris or foreign objects in drain pump filter.
The drain filter is located behind the lower access panel.
NOTE: Disconnect the power cord before removing the lower access panel and cleaning out the drain pump filter.
Remove the two screws (key#21) securing access panel. The filter cap (key#14) is removed by turning it counter clockwise. NOTE: Be sure that all the water has pump out before removing the cap. Have some large towels handy because there will be water coming out the filter/pump once you remove the cap. Check and clean the filter and remember to reduce the amount of detergent and the washer should perform as designed
Hope helps (remember to rate and comment this free answer)..
Jun 10, 2011 | Kenmore HE2 Plus Front Load Washer
The water is not fully draining from the wash cycle. flashing F1,F21, 5D, please advise. Washer was purchased two years ago. thanks
F21 F 22 CCU /touchpad/LED assembly unable to transmit/receive data to/from the CCU central control unit
Possible causes/proceedure:
1. Check the touch-pad/LED assembly by selecting different
cycles and changing the modifiers and options available to
confirm the touch-pad/LED is responding.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the
touch-pad/LED assembly and Central Control Unit (CCU).
Sud: Suds lock (overdose of detergent detected during wash cycle)
The motor control unit senses a suds lock condition by analyzing the
current draw on the drive motor. If "Sud" is displayed a potential Suds
Lock is detected. This may signify a bad pump, an extra heavy load,
excessive detergent, or excessive suds.
¦ If too much detergent was used:
-Run the unit through a Rinse/Spin cycle.
-Run a Normal cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged
or kinked.
3. Check wire harness connections to the drain pump,
pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic test or any
cycle.
First remove the bottom panel and grab yer tech sheet. It gives the faluts and directions to diagnose or correct as shown above. Clear the pump filter.
Watch this video that shows how from my main man Double H
Dec 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a Kenmore HE2t front load washer model #11047561604 serial # HLY1661717 I'm trying to wash a load of clothes and it's giving me a message F21 and it is flashing, I un- plug the washer and try to...
The F21 error code indicates a long drain. Here are some tips that should help you resolve this problem:
  • Check your washer drain to make sure that it is draining properly.
  • Check the drain hose for kinks and clogs. Make sure that it is installed properly per the instructions in your owner's manual. An improperly installed drain hose can prevent the washer from draining properly.
  • Check for excessive suds in the washer tub. Excessive suds can prevent the washer from draining properly and will result in the F21 code. Make sure that you are using the proper amount of HE (High Efficiency) detergent to prevent excessive suds.
Remove any clothes and then use a wet/dry shop vac to drain any water out of the washer.
Arrange shallow pans and/or towel in front of the large item filter shown in the second image below to catch residual water when you remove this filter.Remove the large item filter as shown below. It is likely that you will find a clog in this area that is preventing your washer from draining.
If you do not find any clog or restriction in the large item filter and none of the other issues discussed above apply to your situation, then you could have a failed drain pump. If the pump is damaged and will not pump out water then it will need to be replaced.
Aug 17, 2010 | Kenmore Washing Machines
F21 code flashes
Lets see what an F-21 is shall we? F21 Long drain Possible cause: Clogged filter, clogged/failed pump, suds detected by control.3a5b94a.jpgb4a897e.jpg55f108d.jpg
Jun 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door wont open f21 alarm
F21 indicates that the washer is having problems draining. Check the drain hose to see if it is kinked or if there is an obstruction in the hose.
SUD comes on every time excessive suds are detected. Not using the proper detergent will set this off faithfully. The machine will run a cycle to remove the excessive suds before completing the wash cycle.
You need to clean the drain filter by removing the 3 screws in the bottom of the front panel. Then you will see a white twist cap. Remove the filter and clean it out.
Mar 09, 2010 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet washer flashing sud then f21 ????????
The "SUD" error is in direct relationship the other error code. "F21" is a Long Drain error. The following link explains:
http://www.fixya.com/support/r1484065-f21_error_code_whirlpool_duet_kenmore
If something is preventing water from pumping through the drain pump, you will often get a "SUD" error as air is developed in the pump. Make sure you double check all the drain lines as well.
If you have questions, or require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
135 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
