Question about HP Pavilion dv6000z Notebook
Labtop I have a labtop and I want to add more ram to it i dont know were to start i need step by step instructions on how to do this i have a 512mb and i want to install a 2gb but dont know how to install i have enough to buy the product but dont want to pay for installation
    Scholar:
  • 187 Answers
You can do the installation yourself as it's pretty straight forward (all you will need is a screwdriver to remove the cover plate that covers the RAM). You can identify the RAM plate by looking on the back of your laptop. The RAM plate will have a small (and I mean, very small) picture of a RAM chip next to it. Once you've found it, you will see two screws (these may be hidden by labels or rubber pads). Simply remove the screws, remove the plate, take out the old RAM chip, and pop in the new ones. If you need to identify the type of RAM to purchase, I'd recommend either consulting your laptops documentation (or the documentation on the manufacturers website if you don't have a hard copy), or by; 1. Downloading Aida32 http://archives.mysteryfcm.co.uk/?f=System/Diagnostics/Aida32 2. Popping along to Crucial www.crucial.com Crucial requires ActiveX, and will automatically detect the type of RAM required for your system.
Posted on May 27, 2008
Installing two ram( ddr400 512mb and pc400 512mb )
If you are referring to computer RAM always put the largest ram module closest the CPU central processing unit
try to keep the same brand and type of ram the same ie: ddr ddr3.......
you will be able to read the ram type on the ram already inside
make sure you secure the ram modules by pressing the levers down firmly at both ends of of there sockets
make sure your computer is turned of before you attempt this
be sure to wear an earth strap before touching anything inside your computer
the ram modules sockets are located near your cpu
If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules.
hope this helps you
Mar 21, 2012 | Computers & Internet
How to install 512mb ram for toshiba A25-S279
look on the underside there is a slot for inserting ram in it . but u need to open the back cover to see it and insert in it .
if your product is under warranty i recommend dont do this on your own contact service centre
Apr 05, 2010 | Toshiba Satellite A25-S279 Notebook
RAM for AVERATEC 3120V
Max for this form factor is 512mb. It can be upgraded. Here is step by step instructions
http://www.gearhack.com/Forums/DisplayComments.php?file=Computer/Notebook/Max..ing_Out_Memory_on_the_Averatec_3120V_Slim_Notebook
you can buy the ram here for about 18 bucks with a credit card and free account setup
http://cgi.ebay.com/Viking-512Mb-PC13364X64CL3-512MB-PC133-SDRAM_W0QQitemZ120445441132QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1c0b1b946c&_trksid=p3286.c0.m14
Good Luck! Your Amigo!
Ruben
Jul 28, 2009 | Averatec 3120V Notebook
Need to increase the ram on the VGA Card
My friend you can add RAM on your VGA by purchasing another Higher Video card  RAM. you can buy 512mb (265 - 512 bit) VGA Card to increase your VGA RAM.
Jun 18, 2009 | ASUS P4P800-X Motherboard
I added ram but it isnt showing up
you cannot add a 512mb with a gig RAM sticks must be of the same size(mb) and installed in pairs
Apr 12, 2009 | AOpen AX4B-533 Motherboard
Need to add RAM
Located here is the actual specifications of your W3052.
http://www.emachines.com/support/product_support.html?cat=Desktops&subcat=W%20Series&model=W3052
The DDR means "double data rate", SDRAM is "synchronous dynamic random access memory" and DIMM is for "dual inline memory module". These are the way manufacturers describe the specific speed, type, and packaging of the memory. You need to get the correct combination for your computer in order for it to function properly. The PC2100 is NOT correct, at the very least it will slow your computer down, and possibly will not work at all. You should use PC2700.
If you wish to add another 512MB taking your computer to 1GB total, then you only need 1 module, a 512MB, like the one that came in the computer. Do not purchase a 1GB module expecting it to work properly with the one already there. It probably won't. If you want to max out your computer's memory taking it to 2GB, then you will need to purchase 2 each 1GB modules, and remove the existing 512MB module.
When you go to the computer store, you ask for either "one five-hundred-twelve megabyte, PC2700, DDR, SDRAM DIMM memory module" or "two one-gigabyte, PC2700, DDR, SDRAM DIMM memory modules".
The part numbers from, Kingston, one of the major add-on memory makers are shown here:
512MB = KVR333X64C25/512
1GB = KVR333X64C25/1G
Mar 28, 2009 | E-Machines eMachines Desktop PC
Need to add Ram memory
Hey,
This is really easy on this model of acer laptop
  • unplug the power adapter and remove the battery from the laptop
1. Remove the two screws fastening the RAM cover.
2. Detach the RAM cover from the main unit.
3. Pop out the memorys and remove the memorys from the memory sockets.
Let me know if you need anything else.
Thanks,
Ekse
Feb 17, 2009 | Acer Aspire 3680 Laptop
Can i run ati radeon HD3650 512mb on asus k8N motherboard
firstly you need to make sure *********** board has a PCIe slot or a AGP... this is where your ATI HD3650 will go...see the graphic 512mb has nothing to with your main system RAM which is also 512mb.. so they wont be any problems as such and both will work together without any problems... but i suggest you to add another 512mb to your system RAM.. the difference between DDR and DDR2 is that... DDR2 is a bit newer and is faster in terms of memory read/write/access... do let me know if u have any futher problems....
Jan 27, 2009 | ATI RADEON X1650 Graphic Card
1024 RAM
You will need to remove the 2-512MB ram that are installed on your computer and buy 2-1GB sticks. There is no other way around this. Download CPU-Z program to find exact memory module needed before you buy the wrong one. Good luck.
May 19, 2008 | Toshiba Satellite A135-S4527 Notebook
RAM
1st......Operating System?????
2nd.....Run Device manager to ascertain RAM installed
3rd.....Download Sandra Lite to find M/B specs.(Free Download)
4th.....Check if RAM is SODIMM,SDRAM,DDR,etc
5th.....Open PC case to ensure RAM slots available.
6th.....Purchase correct RAM.e.g.128MB->256MB,256MB->512MB,512MB->1024MB
Check to see if RAM slots are paired or not
If paired....2X128MB=256MB
2X256MB=512MB
2X512MB=1024MB
Feb 02, 2008 | HP Pavilion MX75 17" CRT Monitor
HP Pavilion dv6000z Notebook Logo
78 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
