Question about GE Profile 22.2 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Black
The refrigerator temperature reading is getting warmer and the freezer reading is getting colder. I cleaned the coils in the back this weekend and this seamed to work but its doing it again.Is it possible that a bottom drawer that fell out of place onto the bottom vents of the fridge could be doing this?
  • GE Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 27, 2010
Temperature
Hello R, thank you for your question! Generally speaking it is recommended that the temperature knob is set in the middle for both the refrigerator and freezer compartment for top mount refrigerators. The temperature can be adjusted by moving the knob in small increments, allowing the temperature to stabilize. If you desire a colder temperature, then turn the knob towards COLDER, or for warmer temperature, turn the knob towards COLD. Turning the refrigerator control will change temperatures in both compartments. For example, if the refrigerator control is turned to a colder setting, the freezer control may have to be adjusted to a warmer setting. Turning the freezer control will only change the freezer temperature. Hope this proves to be helpful!
Jul 22, 2013 | Refrigerators
Just had a Samsung RFG29THDRS refrigerator delivered a week ago and noticed that things did not feel cool after being in the fridge for awhile (over 24 hours). Using a store bought refridgerator...
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 20, 2011 | Samsung Refrigerators
L G Multi Air FlowGR359SQ Fridge/freezer, freezer section keeps freezing up at the bottom then defrosts and spills water all over the floor no apparent drain ?
Clean drain under freezer coils.
NOTE: This
Then check to see if freezer control is turned WARMER, which makes the Ref. colder
Also this might be a common Defrost problem, Ice
Check cold control (thats where you turn it colder)
Leo Ponder
imufo2
Please VOTE FOR ME If this was helpful
Aug 01, 2011 | LG LRFD22850ST French Door 22.4 Cu. Ft....
I have a problem with Gorenje HZOS3366 Bottom Freezer Refrigerator. A temperature indicator shows e2 error and -12 temperature.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it seems
to be defective and not shutting off. If your temp is warm proceed with the following.
Leo Ponder
imufo2
Jul 30, 2011 | Gorenje K337MLB Bottom Freezer...
The freezer alarm keeps going off and the freezer temperature is reading 17, though it has kept everything frozen. The back, behind the panel, was all frozen and we defrosted it and it seemed okay fro a...
Leo Ponder
imufo2
Jul 29, 2011 | Liebherr C1650 Stainless Steel Bottom...
Where is the defrost timer located?
I have a top freezer configuration. I adjusted the two dials because I was trying to save some power because the refigerator was only beling used on the weekends. However the next weekend the the inside tempwerature was warmer than room temperature. After removing the back panel and vacuuming the coils, i plugged back in and it got cold but a few hours later it warmed back up. It has done this twice and I have left it unplugged because it was not needed. is there a possibility an automatic deforst cycle is stuck?
Dec 27, 2010 | Amana ABB1921DE Bottom Freezer...
GE GSS25LGMFWW side by side. Freezer will run till iced up then defrost everything in the freezer compartment. Why is it doing this?
hi, have you try adjusting the temperature:
To change the temperature, press and release the
WARMER or COLDER pad. The SET light will come
on and the display will show the set temperature.
To change the temperature, tap either the
WARMER or COLDER pad until the desired
temperature is displayed. The
freezer temperatures can be adjusted between
–6°F and +6°F.
Jun 14, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My refrigerator is a ge profile bottom freezer is it normal that its verry warm in the back
Do you have your condenser coils at the back ? Yes it is normal - How much air clearence do you have at the back ? If your unit is fairly close to the wall there is not much room for the heat to dissipate properly - those condensers do get hot and radiate heat - it is important for your fridge to get rid of heat and critical to its cooling properly. Make sure the condensers are cleana nd not clogged with dust - if your ambiant room temperature is hot your refrigerator will work harder and you will feel it getting warmer at the back - check to see if your compressor runtime is excessive or not and make sure your cooling temps are in the normal range - Freezer no warmer than 10F (optimal at 0F and colder) and refrigerator no warmer than 40F, optimal at 34F.
Sep 04, 2009 | GE Profile 21.7 cu. ft. Bottom Freezer...
Freezer cold but not freezing
Check the settings for the freezer control. Refrigerator temperature control normally controls the run time of the compressor. if the freezer control is set to low the refrigerator temperature will be fine and the freezer will be warmer. Setting the freezer control to a colder setting will hold back more cold air in the freezer and reduce the air volume supplied to the refrigerator. Check and make sure the condenser coil is clean.
Jun 08, 2008 | Liebherr Premium CTP 3153 Top Freezer...
GE Profile 22.2 Cu. Ft. Side-by-Side Refrigerator with Bottom-Mount Freezer - Black Logo
126 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
